Old Sep 04, 2012, 08:46 AM
RICHARD3851 is offline
Find More Posts by RICHARD3851
Joined Jan 2005
Originally Posted by JimDrew View Post
The problem is that we don't lock any channel to any flight control surface. Every channel is treated the same... so, every channel has rates, expo, multi-point curves, etc. There is no "1=aileron, 2=elevator, 3=throttle" type of hard coded configuration. The Tx emulation just fills in the variables as you are use to seeing them for the transmitter of your choice, but you can make any output set to any input.
A problem? I think this is what will make this transmitter a truly desirable product, otherwise it's just another Spectrum.
Richard
RICHARD3851 is offline Find More Posts by RICHARD3851
Old Sep 04, 2012, 12:34 PM
Uff-Da RC is offline
Find More Posts by Uff-Da RC
Joined Dec 2007
Will the XPS -3216 be in field flash-able?
I assume it will be, so then will flashing the TX maintain all programmed models, and just enable the new features in the new flash for every model? Or will it encapsulate the programmed models, and if you want the new features, you will have to recreate your model, or upgrade, and recheck before flying?
Uff-Da RC is offline Find More Posts by Uff-Da RC
Old Sep 04, 2012, 02:19 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
ya, fair enough.
Richard
locking down channels to flight surfaces would make it the "just another spektrum"... any input to any output is rather epic. but due to this flexibility, it can't block or warn against sequence programming a flight surface, which means you can program maneuver sequences just to annoy the fun police and those ARF monkeys...
theKM is offline Find More Posts by theKM
Old Sep 05, 2012, 12:41 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
I "think" it was said a while back the xdp will be able to wirelessly program the tx from your laptop.So yes,field programmable.That is a nifty lil device that xdp
Manta1 is offline Find More Posts by Manta1
Old Sep 05, 2012, 12:49 AM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
Yes, it is possible to assign 'functions' to any switch. The function list is currently hard coded to 'snap roll', but I can add things as requested. The problem typically with things like this is that speed of the aircraft plays an important part of a successful maneuver. I am also a bit concerned (from a liability stand point) about having a slow roll, 4 point roll, 8 point roll, etc.
Provide the "framework" and some instructions and let customers program their own functions. Wouldn't that release XPS from the liability issues, even if customers shared their functions among themselves?
Pete
PGR is offline Find More Posts by PGR
Old Sep 05, 2012, 07:40 AM
Joined Jan 2005
Pete
I agree with Pete leave it as user programmable as possible
Iíd find a program to gradually richen the needle over the course of an 1 Ĺ hr flight to compensate changing fuel levels useful (just another example of what might be possible).
Old Sep 05, 2012, 02:56 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
I am currently building a club trainer of about 630 sq in powered with a 15 diesel with a 12 oz tank which will give 1 Ĺ hr flight time, it would be useful to be able to program the elevator to gradually increase the amount of down trim over the duration of the flight as the fuel burns off.
I still donít understand why anyone would care if I have a snap roll, or a Lomcevak switch on my transmitter, if it would be fun for me? If the fun police, and ARF monkeys donít want to have them programmed into their transmitters then donít.
Richard
I think you could do this with the timer configuration. You can set events to occur, but the trims are not part of the event queue. I will see how difficult that would be to change/add. I have not looked at that part of the code in a long time, but I need to because the trims are hard coded at 4, even though the config space is setup to handle trim for each channel (all 32).
JimDrew is offline Find More Posts by JimDrew
Old Sep 05, 2012, 02:57 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Richard
Well, I didn't quote what this was in reference to:
Maybe put a fail safe in the firmware that will not allow the use of these sequences on channels that are controlling flight surfaces, or are assigned to the control sticks.
This is not possible because we do treat every single channel as a separate entity. So, doing what was recommended would be a problem.
Old Sep 05, 2012, 02:59 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Absolutely! In fact, the neat thing about it is that the transmitter has built-in XDP functions. So, you could update your buddy's transmitter as well as his receivers, and change settings, failsafes, etc.
You would have to download the firmware from our website and reflashing occurs via USB<>serial cable (plugs into the DSC port) or via an XDP.
Old Sep 05, 2012, 03:00 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Pete
No a bad idea, Pete. I will consider that for the future.
Old Sep 06, 2012, 11:49 AM
Joined Dec 2007
Thank you Jim, This sounds like a great way to keep my TX and RX and fail safe settings all up to date at the field. Just have the TX updated before I go.
The only other feature I would like more info about is the availability feature of this TX. That might be the only feature you are not commenting on
Old Sep 11, 2012, 01:48 AM
Swen is offline
Find More Posts by Swen
Passion
Joined Sep 2009
I remember something like the telemetry reporting the signal strength of the receiver, or am I wrong?
If so, if there are more receivers in service in a plane in master-slave configuration, will it give the signal strength of all the receivers?
Swen is offline Find More Posts by Swen
Old Sep 12, 2012, 12:30 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The signal strength is actually the transmitter (as the receiver sees it). The MASTER receiver is the only receiver that can handle telemetry information.
Old Sep 15, 2012, 09:22 AM
Graeme Marion is offline
Find More Posts by Graeme Marion
Brisbane Australia
Joined Mar 2003
Jim,
Will this unit work as it should with your new transmitter?
Or will I have to buy a Futaba transmitter to get the benefit of head tracking.
http://www.hobbyking.com/hobbyking/s..._Goggles_.html
Graeme Marion is offline Find More Posts by Graeme Marion
Old Sep 15, 2012, 02:13 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
If you use it as 5.8GHz, it should work just fine. I think the FCC is finally cracking down on these illegal devices. I got a generic notice warning about importing non-compliant devices, and since we don't import anything, I am sure this was aimed at others that do.
Sold XPS 2.4GHz JR Transmitter Module (9x) az_heliguy Aircraft - General - Radio Equipment (FS/W) 19 Apr 05, 2012 12:07 AM
For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. penceaviation Aircraft - Electric - Jets (FS/W) 9 Oct 13, 2011 08:55 AM
Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 12, 2011 09:30 AM
For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 24, 2011 01:48 PM
Sold TransMitt transmitter bag / warmer**price drop** aerosheldon Aircraft - General - Radio Equipment (FS/W) 5 Mar 31, 2011 01:40 PM
