Old Apr 26, 2012, 10:23 AM
R.I.P. my 70" FB Slick
Wildman777's Avatar
Moody, AL
Joined Jan 2006
I'm anxious to get the new transmitter and do a complete switchover to XPS myself. I spent some time repairing a broken flap switch and antenae on my well worn DX7 the other night, so it should last me a little longer, but I really need this new TX!!
-Dustin
Wildman777 is offline Find More Posts by Wildman777
Old Apr 26, 2012, 02:58 PM
Sylvania, Ohio, USA
Joined Apr 2000
cross trimmimg
If trim switches are unassignable, does that mean that cross trimming will not br possible?
John Carle is offline Find More Posts by John Carle
Old Apr 26, 2012, 03:22 PM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Trim switches will be assignable, but this is not something that I have implemented at this point.
JimDrew is online now Find More Posts by JimDrew
Old Apr 26, 2012, 10:16 PM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by air mail rcg View Post
Are they here yet??????????
Hey!Thats my line!!
Manta1 is offline Find More Posts by Manta1
Latest blog entry: Lil repair work.
Old Apr 26, 2012, 11:23 PM
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Jim,
Your specs say the Tx can be powered with 6v-24v. Does the Tx come equipped with a battery, or do we supply it? If we do, what are the dimensions of the battery area and what type of plug is required?
Paul
FlyingW is offline Find More Posts by FlyingW
Old Apr 26, 2012, 11:46 PM
Tony37803's Avatar
United States, TN, Maryville
Joined Jun 2011
I am certain in the previous thread that Jim had 90% decided to go with the red JST plugs. I imagine the battery compartment is likely to be sized so as to hold a 9.6V NiCd pack. Also, no charging port. Battery life is expected to be astounding, depending on mAh of the battery. DAYS are possible with the right pack.
I'm certainly not trying to speak for Jim, I just know how hard it is to wait until the next afternoon/evening for an answer.
Tony37803 is offline Find More Posts by Tony37803
Old Apr 27, 2012, 02:50 AM
Ipoh, Perak Malaysia
Joined Jul 2006
Jim,
If I may make a suggestion, can you make the motherboard/ io-board with enough input capabilities so that the more crazy among us (like myself) may drill the case and add on additional 3-way switches and/or rotary dials, etc? Does the cpu that u are using have additional input lines or can they be multiplexed or added on somehow without slowing the system too much?
chewy
chewytm is offline Find More Posts by chewytm
Old Apr 27, 2012, 10:33 AM
Lake Havasu, AZ
Joined Jun 2005
No battery is included. The input connection is a red two pin JST plug (common for small Lipos). The battery compartment is designed the traditional 8 AA type drycell batteries or Nicd/Nimh battery pack. Typical current draw ranges between 60mA and 90mA (full power), depending on the frame rate. So, a 2200mAh 2S Lipo is lasting about 24 hours of continuous on time. Obviously, we don't fly that way and since it has auto-power off, it won't let itself be left on by accident. So, the battery will last a long time.
Old Apr 27, 2012, 10:55 AM
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by chewytm View Post
Jim,
chewy
The 100 pin dsPIC I am using has no additional I/O available. I am using all but 7 pins, and those were not needed so they are blocked in the PCB layout. All control inputs are analog, so it is possible that you could use a switch assembly with multiple switches and resistors to obtain different input values based on which switches are toggled.
Old Apr 27, 2012, 11:21 AM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Jim,
I know we covered a lot of battery options in the old thread, but what do you recommend as the best pack for this TX?
Also, glad that it will have an auto-shutoff feature. I used to have a low discharge lipo in my 9303 (the Rhino 3S 2650 3C TX-lipo from Hobby King). I left it on a couple times, and even with the audible beep from the TX, I still didn't realize I had left the radio on and drained the lipo both times. Wound up damaging the middle cell and had to trash the lipo. I use Sanyo Eneloops now, but the 8-cell AA holder has to be crammed in there to fit.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Latest blog entry: Nico Hobbies
Old Apr 27, 2012, 02:09 PM
Lake Havasu, AZ
Joined Jun 2005
I have been using an 1100mah 2 cell pack during my development as I haven't had need for anything bigger.
Old Apr 27, 2012, 02:26 PM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
How about a 2S A123 pack?
Bob
bruff is online now Find More Posts by bruff
Old Apr 27, 2012, 02:51 PM
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Originally Posted by JimDrew View Post
We are not giving or attempting to predict release dates for any active or future products. However, we will continue to announce products that are in development.
IIRC, it has been almost 2 years since the first system announcement.
Just out of curiosity, what is the expected development time for a system such as this?
ltc is offline Find More Posts by ltc
Old Apr 27, 2012, 03:18 PM
Pusher jets rule!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Cool, I can get one of those easy enough from Jack.
Bob
Bob,
Would a 2S A123 fit in the battery box? I would think it would be too wide. But if a 2S 1100 fits, I have two of them on hand I could use, and would not need to buy a new lipo.
Pat
Old Apr 27, 2012, 04:07 PM
Lake Havasu, AZ
Joined Jun 2005
Bob
It won't fit, no matter how much you try! Perhaps one of the Hobbico versions will fit just fine.
Sold XPS 2.4GHz JR Transmitter Module (9x) az_heliguy Aircraft - General - Radio Equipment (FS/W) 19 Apr 04, 2012 11:07 PM
For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. penceaviation Aircraft - Electric - Jets (FS/W) 9 Oct 13, 2011 07:55 AM
Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 12, 2011 08:30 AM
For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 24, 2011 12:48 PM
Sold TransMitt transmitter bag / warmer**price drop** aerosheldon Aircraft - General - Radio Equipment (FS/W) 5 Mar 31, 2011 12:40 PM
