Old May 15, 2012, 10:51 PM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
Originally Posted by jgunpilot View Post
I've got one of those receivers sitting in my shop, along with a mRCtone transmitter. I had it in a PAA Loader called a Bootstraps. It forced me to learn about electronics.
I learned to fly RC in 1956 with a Bootstraps and a Lorenz twotube receiver. I still have it in the attic, almost repaired from the last crash. Never had the heart to throw it away. Too many nice memories.
Speaking of autotrim, I had a Micropro with autotrim almost 20 years ago. Never found a use for it. I always prefered to land and adjust the linkage instead of the servo. Just old fashioned I guess but it has worked for the last 55 years.
ChuckA is offline Find More Posts by ChuckA
Old May 16, 2012, 07:40 AM
hook57 is offline
Find More Posts by hook57
hook57's Avatar
United States, IL, North Aurora
Joined Sep 2009
Chuck,
True and valid, I typically do the same to preserve the servos neutral/center point. However, with a new model or one not flown in awhile, things are different and it really can be advantageouis to hold the aircraft in a position via the stick(s) and press one button that will adjust the trims. Feel the model out, land, adjust the linkage, and your off again. Also, in some cases (as in mine) flying a single stick with five digits (one hand) gets a bit nervy when you have to let go of the stick to reach a trim lever; so again, not necessary but there are advantages.
hQQk
hook57 is offline Find More Posts by hook57
Old May 16, 2012, 04:17 PM
Vapor52 is offline
Find More Posts by Vapor52
Joined May 2007
I adjust my linkage when building or setting up, on maiden only minor tweeks are needed and this auto trim sounds great.
Vapor52 is offline Find More Posts by Vapor52
Old May 16, 2012, 07:44 PM
dirtybird is offline
Find More Posts by dirtybird
United States, AZ, Queen Creek
Joined Aug 2004
I set my aircraft up ex actually as the instructions that come with the ac specify. I don't know what some of the guys that write the instructions are smoking because I have some wild rides before I got the thing tamed down.
Auto trim would be a great help.
dirtybird is offline Find More Posts by dirtybird
Old May 19, 2012, 03:00 AM
fredtrex17 is offline
Find More Posts by fredtrex17
SAINT PORCHAIRE/ FRANCE
Joined Apr 2009
Hello,
when we can buy it in FRANCE ??
Better thanks.
FRED
fredtrex17 is offline Find More Posts by fredtrex17
Old May 19, 2012, 03:38 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
When your new president says, "Oui!"
JohnathanSwift is offline Find More Posts by JohnathanSwift
Old May 19, 2012, 03:42 PM
Joined Aug 2004
Originally Posted by fredtrex17 View Post
Hello,
Better thanks.
FRED
If you are asking about autotrim get the Graupner MC-24 .
It you are asking about the transmitter who knows ?
Old May 19, 2012, 05:57 PM
E_ferret is offline
Find More Posts by E_ferret
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
Originally Posted by hook57 View Post
Chuck,
hQQk
with regard to preserving the servos neutral point, here is a possible reason for changing the neutral point from time to time. On a feedback pot, the deadband zone is where the track will wear out the fastest due to the slight over-run oscillation. by changing the neutral point you effectively increase the working life of the servo.
E_ferret is offline Find More Posts by E_ferret
Old May 19, 2012, 06:09 PM
Joined Aug 2004
This is a particular problem with some JR servos that are set up with 0us deadband.
Most standard servos with a deadband of about 13us this will not be a problem.
Coreless or digital servos with a deadband of around 3us can be a problem if connected to a large unbalanced control surface.
Old May 20, 2012, 12:49 AM
Joined Apr 2009
Hello, excellent !!
A+FRED
Old May 21, 2012, 07:36 AM
hook57 is offline
hook57's Avatar
Joined Sep 2009
That is true E, aside from finding/having deadband my preference is to keep the center/neutral point as is. If I am using a somewhat older or well used servo, I may offset the neutral for that reason. However, I typically put those in a sport flyer by then, or if their digid or coreless servos I do send them in. You made a good point though, thanks.
hook
Old May 21, 2012, 11:39 AM
hebertjj is offline
Find More Posts by hebertjj
United States, TN, Knoxville
Joined Jan 2001
Jim,
I'm not clear on programming RXs and updating TX firmware. Is an XDP required or is this function included in the TX now? Will an XDP be needed for anything with the new TX & RX?
Thanks again
hebertjj is offline Find More Posts by hebertjj
Old May 21, 2012, 11:44 AM
Greenland
Joined Mar 2012
Hello, excellent !!
A+FRED
Hm, maybe, on second thought, it's "Oui! Oui!"
I don't know, sometimes you guys get me confused-I mean, who could think Jerry Lewis is funny?
All in good humor: http://www.bing.com/videos/search?q=...ail&FORM=VIRE1
Old May 22, 2012, 07:58 PM
skubacb is offline
Find More Posts by skubacb
skubacb's Avatar
Tucson, AZ
Joined Aug 2006
I like 500 planes in radio storage since I have over 80 flyable planes. There are more out here like me so over 100 makes sense. 500 makes it so there will never be anyone complaining.
On the XDP Jim stated that the TX can program the RXs like an XDP but the XDP is used to wirelessly program the TX.
Have people waiting on this. They were students but it has been so looong.
skubacb is offline Find More Posts by skubacb
Old May 27, 2012, 01:41 PM
FlyingW is offline
Find More Posts by FlyingW
Build more, websurf less
FlyingW's Avatar
Long Valley, NJ, USA
Joined Dec 2001
Saw this in another thread. Two 18650 sized lithium cells in a Tx intended for eight nicads.
Hopefully a similar fit in our XPS unit for two A123 1100mah cells.
FlyingW is offline Find More Posts by FlyingW
Sold XPS 2.4GHz JR Transmitter Module (9x) az_heliguy Aircraft - General - Radio Equipment (FS/W) 19 Apr 04, 2012 11:07 PM
For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. penceaviation Aircraft - Electric - Jets (FS/W) 9 Oct 13, 2011 07:55 AM
Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 12, 2011 08:30 AM
For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 24, 2011 12:48 PM
Sold TransMitt transmitter bag / warmer**price drop** aerosheldon Aircraft - General - Radio Equipment (FS/W) 5 Mar 31, 2011 12:40 PM
