Old May 10, 2012, 09:57 AM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
I take it you left the pads for the flash rom on the board, any glue devices that needed to be added back to the board?
village_idiot is offline Find More Posts by village_idiot
Old May 10, 2012, 11:26 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by Doffen24 View Post
Is this speed for the SD card with the fast Extreme SDHC Class 10 Card or the newer UHS Class 1 ?
According to Sandisk you should have speed, on these cards, up to 10 MB/s (80Mb/s). I do not know about your Baudrate or how many clock cycles needed for one command, but it sure seems enough, so whats slowing things down
You only get fast speed with SD-media card doing multi-block reads and writes. Run a speed test program on any type of media. I have tested old, class 6, and class 10 cards. The single block speeds are horribly slow - like slower than floppy disk speeds. You don't see that great performance until you are reading/writing 4K and larger size chunks. Single blocks (512 bytes) are just super slow, and due to the limited RAM for buffering there is no way to read/write multiple blocks.
JimDrew is offline Find More Posts by JimDrew
Old May 10, 2012, 11:33 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
No, the FLASHROM is still there - it was just reduced from 12MB to 4MB. That 4MB (32Mbit) contains the speech and audio data, fonts, graphics data, language text, etc. These are things that stay permanently with the transmitter. I removed two of the three FLASHROMs to make room for the micro-SD card socket. There is still also an EEPROM for temporary storage of the current model, and other items loaded from the SD card. FLASHROMs require huge portions to be erased and reflashed every time any data byte needs to be changed. EEPROMs can have individual bytes changed without having to erase/reflash big chunks. EEPROMs also have a 1 million cycle life span, where FLASHROMs are only good for 10,000 flashes before they are ruined. So, it is best to use EEPROM for things that are going to get frequently updated, like trims and such, and then written back to the SD card (or FLASHROM) when the transmitter is shut off or the model changed.
Old May 10, 2012, 01:08 PM
j_whitney is offline
Find More Posts by j_whitney
j_whitney's Avatar
United States, CA, Castro Valley
Joined Dec 2005
Personally, I rarely have more than 4 or 5 models ready to fly. Storage is a huge issue for me. I don't think anyone in my club has more than a dozen. And that is probably fairly average. You guys with more than that are probably more the exception than the rule, so anything over say 2 dozen model memory storage is just icing and bragging rights.
j_whitney is offline Find More Posts by j_whitney
Old May 10, 2012, 01:47 PM
Grich is offline
Find More Posts by Grich
Grich's Avatar
Joined May 2002
50 of my models are ready to fly and most use a 3s 2200 or 1350. a few use 4s and a few use 6s 5000's no bragging, just bought a new one for my birthday for many years. by the way no wife and no kids! Im just a big kid with a lot of toys.
Grich is offline Find More Posts by Grich
Old May 10, 2012, 03:20 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
True, we may be the exception, but if you can accomodate 100 models as easily as 20, why not do 100? That way those of us who do want more than a dozen models stored in our radio can do so without issue.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old May 10, 2012, 03:32 PM
j_whitney's Avatar
Joined Dec 2005
Pat
It sounded as if Jim were running into overhead problems with file size. Fewer models = larger allowable file size.
Old May 10, 2012, 03:52 PM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
I have 2 or 3 setups stored in my TX for a few of my slope planes. The different setups are for different lift conditions and in one case the setups are for with and without camera.
Yeah, I could do the same thing with one setup and flight conditions if the TX didn't make that level of programming so cumbersome, but my transmitters do so I just use different model setups.
That said, I still can't imagine that I'd ever need more than 100 model memories. Truth be known I'd probably never fill 50.
Pete
PGR is offline Find More Posts by PGR
Old May 10, 2012, 04:17 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I think the problems he was talking about was with regards to sorting. Not 100% sure though. I see no reason why have 100 model memory would present a file size problem.
Pat
Old May 10, 2012, 05:18 PM
E_ferret is offline
Find More Posts by E_ferret
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
looks to me that if you can afford 100+ models fully populated and ready to fly then buying a second or even third transmitter is not a great financial hardship.
E_ferret is offline Find More Posts by E_ferret
Old May 10, 2012, 05:46 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
ah.. but then you have to remember to take the correct tx for the models you are taking to the field...
Much better if just 1 tx that has all your models. Backed up to a PC and a spare tx (in event of failures.
30 Models on the 11x is not enough.. 100 would do me I think..
BulletMaster is offline Find More Posts by BulletMaster
Old May 10, 2012, 06:21 PM
Graeme Marion is offline
Find More Posts by Graeme Marion
Australia, QLD, Middle Ridge
Joined Mar 2003
I would welcome and be pleased with space for 100 models.
I back-up my models that have a complicated set-up onto a second memory spot.
Then if I re-configure the model's set-up and make a mess of it, I can go back to my original set-up.
My transmitter holds 50 models and doesn't have many spare slots.
Graeme Marion is offline Find More Posts by Graeme Marion
Old May 10, 2012, 06:35 PM
Vapor52 is offline
Find More Posts by Vapor52
Joined May 2007
I have 100 model capability on my 9C---I have about 25 in use----I fly 3 or 4 different ones regularly, but the others are there if I want them-----------rick
Vapor52 is offline Find More Posts by Vapor52
Old May 10, 2012, 06:49 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
To be clear, I was referring to the sort issue when you had a lot of model names. There is no sort issue when using FLASHROM to store models. So, the option I am looking at is restoring the original FLASHROM<>model code (for perhaps 500 models) and use the SD-media card as a means to back and restore models to FLASHROM. This way, we can sort internally without any speed penalty and 500 models should be plenty of space for most everyone anyways.
Old May 10, 2012, 09:00 PM
Grich is offline
Grich's Avatar
Joined May 2002
Yay!!!! Way to go Jim.
Sold XPS 2.4GHz JR Transmitter Module (9x) az_heliguy Aircraft - General - Radio Equipment (FS/W) 19 Apr 04, 2012 11:07 PM
For Sale Hacker / Spin 170 Controller, XPS Pro Dynamax, 15S 6800 XPS packs in 3S bricks. penceaviation Aircraft - Electric - Jets (FS/W) 9 Oct 13, 2011 07:55 AM
Wanted XPS 6800mah 65c 6s want to trade for xps 5000mah 65c and will pay difference sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 12, 2011 08:30 AM
For Sale 3s xps 5000mah 65c $60 shipped with warranty also 2s xps 5000mah 65c $45 shipped with sherlockshah Aircraft - Electric - Batteries & Chargers (FS/W) 2 Sep 24, 2011 12:48 PM
Sold TransMitt transmitter bag / warmer**price drop** aerosheldon Aircraft - General - Radio Equipment (FS/W) 5 Mar 31, 2011 12:40 PM
