Old Apr 29, 2012, 10:53 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by corocopter View Post
Ravivos
Excellent suggestions!
ALL TRUE!
Sito's craft is a special purpose craft with ground roll capacity not required here.
Theses suggestions reduce weight, parts count, cost, and complexity. Additionally a larger prop increase thrust to weight ratio. All improvements.
COG above the prop is the way to go, as well as a large slower turning prop, the only drawback is increased counter-motor torque from the larger prop mass, but that is offset by the additional thrust.
Kelly
The first step was to make it fly with simple helicopter gyro.
In that way there is no controller that mix the surface.
So Innerbreed have think that the top will be controll but lower will act as Yaw or contarotation.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Apr 29, 2012, 11:12 AM
corocopter is offline
Find More Posts by corocopter
Joined May 2010
I made some large edits to my last post. Please review.
OpenAero working on a cheap KK board is the way to go, use the Mems gyro add-on, which is cheap and easy and HappySundays is working the firmware as of yesterday.
Kelly
corocopter is offline Find More Posts by corocopter
Old Apr 29, 2012, 11:17 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Ok i can now say it.
I have confirmation from Alex (AlexInParis)
He will do a Sphere configuration for us in that project.
So a Multiwii controller will be use.
Eric
Old Apr 29, 2012, 11:19 AM
Innerbreed is offline
Find More Posts by Innerbreed
DotCoDotUk
Innerbreed's Avatar
Joined Mar 2012
thanks for the comments. the awesome solidworks is all down to Eric. thats why i work with him.
designs are still on going right now as we speak. an update from eric is close.
Innerbreed is offline Find More Posts by Innerbreed
Old Apr 29, 2012, 12:20 PM
Joined May 2010
The Major problem with nearly a vtol aircraft is having sufficient separation between the COG and the pitch and roll controls (p/r) vanes, in fact if they are too close together they will work opposite the intended direction.
If you use 4 lower vanes for p/r and install the motor upside down like the CrazyBall and stack your flight control computer then battery on top, this will move the CoG further from the p/r vanes. You could install 2 yaw vanes just below the prop, thus using 3 simple mems gyros.
It will hover well, but have poor horizontal high speed flight.
Kelly
Old Apr 29, 2012, 12:48 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Here is the Flaps cut ...
Old Apr 29, 2012, 12:51 PM
blindflight is offline
Find More Posts by blindflight
blindflight's Avatar
CA
Joined Dec 2003
You guys do good work and fast!!
blindflight is offline Find More Posts by blindflight
Old Apr 29, 2012, 01:04 PM
Joined May 2010
Dialfonzo,
How are these parts constructed, are you using some sort of 3d printing?
Nice workmanship.
Kelly
Old Apr 29, 2012, 01:14 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Dialfonzo,
Nice workmanship.
Kelly
Those flaps are made out of 1.5mm G10 plates (Fiberglass)
They are CNC
Thanks a lot..
Old Apr 30, 2012, 09:50 AM
paco1962 is offline
Find More Posts by paco1962
paco1962's Avatar
Bulgaria, Rousse Province, Ruse
Joined Feb 2011
Hello, this is my project:
paco1962 is offline Find More Posts by paco1962
Old Apr 30, 2012, 09:51 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
[]http://farm8.staticflickr.com/7050/6845963364_f2d98c983f_z.jpg[/IMG]
[]http://farm8.staticflickr.com/7057/6986689007_23b7715da7_z.jpg[/IMG]
[]http://farm8.staticflickr.com/7041/6983970763_b3b22fbcab_z.jpg[/IMG]
I think i sent you a Flickr email no ?
Nice project.
Old Apr 30, 2012, 10:37 AM
Joined May 2010
Paco,
That is a beautiful design. An excellent arrangement of components.
Can you tell us the CoG location please?
Have you flown the craft yet?
Kelly
Old Apr 30, 2012, 02:10 PM
paco1962 is offline
paco1962's Avatar
Joined Feb 2011
Paco,
Kelly
Hello!
The Center of Gravity should be really low, i do that by putting the battery in the lowest part of the sphere.
While experimenting i had to put the motor in the lower part, vertically up.
I have a 30 second flight
It crashed.
Mainly because of a bad pilot. In this model, while slowing the trottle the effectivity of the aeleron and elevator are lowered. My mistake was that I lowered the rudder under the critical, and the control crashed.
Now I'm going to undergo more experiments.
Old Apr 30, 2012, 02:26 PM
Joined May 2010
Hello!
Paco,
Can you please define the CoG location with respect to the Merdian > center< of the craft either in percent or millimeters, please include the diameter of the craft.
Thank you for your data, it is most helpful.
Kelly
Discussion Flying sphere TheZero Multirotor Talk 13 Dec 13, 2011 05:51 PM
Discussion Japan's Flying Sphere UAV jbrundt Electric Plane Talk 1 Nov 10, 2011 09:42 AM
Cool Japan Defense Ministry - Flying Sphere martinic Multirotor Talk 1 Oct 27, 2011 08:04 AM
Discussion Japan's Flying Sphere? Excogitate Electric Plane Talk 4 Oct 27, 2011 04:35 AM
