Old Apr 25, 2012, 05:25 PM
Innerbreed is offline
Find More Posts by Innerbreed
DotCoDotUk
Innerbreed's Avatar
Joined Mar 2012
tut, cant leave you with it for five minutes. lol
good to see how the COG acts upon a roll.
Innerbreed is offline Find More Posts by Innerbreed
Old Apr 25, 2012, 05:28 PM
flyhigh300 is offline
Find More Posts by flyhigh300
United States, TX, El Paso
Joined Nov 2010
ok its going in a box. now..
flyhigh300 is offline Find More Posts by flyhigh300
Old Apr 25, 2012, 07:46 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Where is mine.. lol
Dialfonzo is offline Find More Posts by Dialfonzo
Old Apr 27, 2012, 08:31 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Man, get those electronics in and a flight video.
This could be the next big thing.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Apr 27, 2012, 10:18 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I have confirmation from a developer of MultiWii.
He will do a configuration for the sphere.
Old Apr 27, 2012, 11:04 AM
DotCoDotUk
Innerbreed's Avatar
Joined Mar 2012
thats great. eric we will still need to model the surfaces if this kicks off. not sure i can hand craft for the thousands. lol
Old Apr 27, 2012, 12:30 PM
DotCoDotUk
Innerbreed's Avatar
Joined Mar 2012
thought i might share some of the design ideas for the sphere. this is not currently in the project but a 3D print of the parts might be worth a thought.
The part shown will allow for one servo to be use to control the Yaw control of the sphere.
http://www.rcgroups.com/forums/showa...7&d=1335544070
http://www.rcgroups.com/forums/showa...8&d=1335544070
Old Apr 27, 2012, 02:21 PM
Brandano is offline
Find More Posts by Brandano
You could just use ball links and a sliding ring. Might end up lighter too, at the price of a little linearity
[edit] actually, with 3 servos and a ccpm mix there is a setup that can give you yaw, pitch and roll mixing with an arbitrary number of vanes
Brandano is offline Find More Posts by Brandano
Old Apr 27, 2012, 09:07 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Some Flap thinking....
Original Servo horn screw to the G10 horn.
3mm rod on center for support.
Old Apr 27, 2012, 10:16 PM
Joined Nov 2010
I'll take.. 2..
Old Apr 27, 2012, 10:18 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by flyhigh300 View Post
I'll take.. 2..
Nah.. you need at least 4 flap..
Old Apr 27, 2012, 10:49 PM
DotCoDotUk
Innerbreed's Avatar
Joined Mar 2012
Not 8 then... LOL
http://www.rcgroups.com/forums/showa...8&d=1335581338
Old Apr 28, 2012, 05:05 AM
VTOLicious is offline
Find More Posts by VTOLicious
VTOLicious's Avatar
Austria
Joined Oct 2007
The Material will be cut from 3mm PVC Foam board, (light but strong), and will be powered using a Thunder Power 2100mAh 3-Cell 11.1V LiPo Battery with a Turnigy Park 300 Brushless Outrunner 1600kv motor. (test motor)
It will pose x3 HK401 Heading Hold AVCS Gyros, and x6 Hs-65hb servos.
Hi guys, nice project!
Can you post some details about the 3mm PVC foam board? Whats the materials density (kg/m), how does it compare to 3mm poplar plywood?
266g for the frame seems to be pretty good, but with all the servos and 200g battery-weight youll need a stronger motor for sure
Edit: 400kg/m seems to be a realistic number for 3mm poplar plywood.
All the best, Michael
VTOLicious is offline Find More Posts by VTOLicious
Old Apr 28, 2012, 09:36 AM
corocopter is offline
Find More Posts by corocopter
Joined May 2010
Flight controls
Hello Interbreed,
Beautiful workmanship, but I see several concern with your flight controls that must be address in order for your sphere to fly correctly.
Would you like some assistance?
Kelly
corocopter is offline Find More Posts by corocopter
Old Apr 28, 2012, 09:38 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by corocopter View Post
Hello Interbreed,
Kelly
this is an open project..!
So if you have any comments and suggestion they are welcome
I would cut the flaps today.. but wonder if we could Hollow them and put some kind of tape on them.
Discussion Flying sphere TheZero Multirotor Talk 13 Dec 13, 2011 06:51 PM
Discussion Japan's Flying Sphere UAV jbrundt Electric Plane Talk 1 Nov 10, 2011 10:42 AM
Cool Japan Defense Ministry - Flying Sphere martinic Multirotor Talk 1 Oct 27, 2011 09:04 AM
Discussion Japan's Flying Sphere? Excogitate Electric Plane Talk 4 Oct 27, 2011 05:35 AM
