Old Apr 25, 2012, 08:20 AM
Riodiler1 is offline
Find More Posts by Riodiler1
United States, CA, Livermore
Joined Jan 2005
What is CG for ST-Models ASW28
I posted this on the electric aircraft foam forum but didn't get any response so maybe I'll have a little better luck over here.
My ST-Models ASW28 instruction manual is very unclear about the recommended CG. I'm not sure if they goofed during printing but it shows 5mm +/-3mm from a line in the center portion of the wing rather than from the leading edge.
Does anyone know the recommended CG for this plane from the leading edge?
Thanks!
Riodiler1 is offline Find More Posts by Riodiler1
Old Jun 23, 2012, 05:53 AM
BaronBaz is offline
Find More Posts by BaronBaz
Joined Jun 2012
I've just replied to your other post, but here's the gist of what I said.
Don't measure from the trailing edge as suggested, as this will seriously unsettle the 'plane. My interpretation of the manual is to measure 5mm from the front edge of the EPO foam insert in the wing that covers the servo leads - ie: the strip of EPO on the underside that travels from the wing root to the servo.
My ASW28 balances & flies very well using this method.
BaronBaz is offline Find More Posts by BaronBaz
Old Jun 23, 2012, 12:02 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
I'm flying mine at 52mm from the leading edge.
peterlngh is online now Find More Posts by peterlngh
Discussion ST Model ASW28 Mr Kamikaze Australia 926 Aug 27, 2014 01:56 PM
Discussion ST Model/Jamara ASW28 Foamy Thermal Duration Times Mr Kamikaze Electric Sailplanes 337 Jul 03, 2013 12:24 PM
Discussion Hobbyking / St Model ASW28 Review and Hacks foamaircraft Foamies (Kits) 1 Aug 05, 2012 07:29 AM
Discussion CG for ST-Models ASW28????? Riodiler1 Foamies (Kits) 5 Jun 23, 2012 05:49 AM
Discussion Replacement motor/prop for Hobbyking / St Model ASW28 ? frank48 Electric Sailplanes 0 Apr 10, 2012 09:49 AM
