Old Apr 24, 2012, 10:07 PM
penz83 is offline
Find More Posts by penz83
San Jose, CA
penz83's Avatar
Joined Mar 2012
Build Log
Turnigy Talon Quad Build Question
I'm building my first quad and I'm looking for some feedback. I am gonna run the turnigy talon frame, turnigy 2830 900kv motors, hk 20 amp esc's, hk v2.1 control board, and 9x4.5 props.
Looking through many threads and as much googling as I can handle about how other people have set up their quads I think this setup should work well.
My other question besides feedback on the components I have chosen is my battery. I have some 3000mah 3s lipos I would like to use for my quad, would this be too much battery weight wise? Battery weighs in at 270g.
penz83 is offline Find More Posts by penz83
Old Apr 25, 2012, 10:47 AM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
I did some more reading and got a basic idea of how much thrust I will have and how much is required.
My quad will weigh roughly 1000g and I will be generating roughly 3200g of thrust with my setup. So the 3000mah battery I want to use should be perfect.
Old Apr 25, 2012, 12:06 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
The 2830 is a good motor for a 1kg quad. They have a pretty good range in that 750kv will give long battery life and the 900kv makes for a good sporter.
pug398 is offline Find More Posts by pug398
Old Apr 25, 2012, 12:13 PM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
Thanks for the feedback pug. I was reading all the reviews on the motors on hobbyking and it seemed like a lot of ppl have had good success with these motors on quads.
And sporty is exactly what I was aiming for.
Old Apr 25, 2012, 08:23 PM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
Anyone with this frame out there that can chime in and let me know if it comes with the hardware to mount the control board?
It does not say or show in the talon description but in the extra parts menu the hardware kit has 4 alum tubes and 8 screws, looks to be for the control board?
Description:
Old Apr 25, 2012, 08:53 PM
Tifani is offline
Find More Posts by Tifani
United States, IL, Park Ridge
Joined Apr 2010
Hi !
Aluminum tubes go on the bottom of "legs" - landing gear.
Bras standoffs connect centerplates.
http://www.hobbyking.com/hobbyking/s...ter_Frame.html
You have pictures of assembled frame
Tom
Tifani is offline Find More Posts by Tifani
Old Apr 25, 2012, 08:56 PM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
Ahh now I see where they go. So I have to come up with my own mounting hardware for the control board.
Old Apr 25, 2012, 09:20 PM
Tifani is offline
Joined Apr 2010
Unless You have zero vibrations use double face foam tape (I use double sandwich - foam tape - thin plastics - foam tape).
If You are vibration free You can use plastics standofss and plastics screws form HomeDepot or ACE
Regards
Tom
Old Apr 25, 2012, 09:44 PM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
I have a lot of the foam sounds like a good idea thanks. Are you happy with the talon frame?
Old Apr 25, 2012, 09:54 PM
Tifani is offline
Joined Apr 2010
I did't finish it - but for $35 I can buy one CF tube so can't be picky.
I use to build my own frames (Tri) - Talon was accident (friend order it for me)
This weekend I will attach some pictures.
Old Apr 25, 2012, 10:06 PM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
Cool sounds good, I'll be waiting a couple more weeks for mine to arrive from hk...
Old Apr 27, 2012, 12:51 AM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
I have a good understanding on how to setup my radio for choppers but I'm guessing it's a little different for quads? No servo mixing correct? I will be using a fs-th9x, any setup tips or tricks?
Old Apr 29, 2012, 07:14 PM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
So sounds like turn all mixing off and set trims to zero and I'm good to go for my quad.
Old May 04, 2012, 05:54 PM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
Went to osh today and picked up some hardware that should work for mounting the control board. Some 1" nylon spacers, 1.5" aluminum 6/32 screws, some rubber washers to dampen vibration and some 6/32 nylock nuts.Name: ImageUploadedByTapatalk1336168384.030290.jpg
Description:
Also should allow me to mount my rx directly underneath, all the inputs are on the side of the rx, which is nice Name: ImageUploadedByTapatalk1336168463.543291.jpg
Description:
Old May 06, 2012, 12:32 PM
penz83 is offline
San Jose, CA
penz83's Avatar
Joined Mar 2012
Ordered my talon and electronics from hobbyking two weeks ago and tracking still says its in hk... International orders are a pita. I normally avoid ordering from hobbyking or china in general for this exact reason... But they had everything I needed all in one stop...
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 02:05 AM
Discussion AF-37 Talon build bobdaeronort Foamies (Scratchbuilt) 32 Feb 17, 2014 04:23 PM
Discussion new build quad got questions wbuttry Multirotor Talk 3 Dec 27, 2011 07:13 PM
Talon build TomO Slope 62 Oct 02, 2005 07:11 AM
dynaflight talon should i build it with a flat wing falcon41176 Slope 14 Mar 19, 2005 09:17 AM
