Old Apr 24, 2012, 05:44 PM
Lpbug is offline
Find More Posts by Lpbug
United States, CA, Santa Monica
Joined Jul 2011
Twin or single motor cargo plane
Just one question, I have learned growing up that twin motor planes are more "inefficient" and it never quite made sense to me. If you have two propellers, shouldn't you be outputting twice the amount of thrust that one propeller planes can produce? And if you're outputting twice the amount of thrust, you should be also putting out twice the amount of force. By that principle, you should be able to accelerate two times faster. How does this fact make twin props more inefficient? Also, does two props give you more maximum speed over single props? Or does it just help you accelerate up to maximum speed faster?
If I want to build a heavy lifting cargo plane, should I go with a 4 motor, 2 motor, or single motor design? Also, what Kv would you recommend if I use a 3s Lipo.
Thanks for all the help and support.
Lpbug is offline Find More Posts by Lpbug
Old Apr 24, 2012, 05:57 PM
-james- is offline
Find More Posts by -james-
-james-'s Avatar
UK
Joined Sep 2008
I would also like to know the answer to this question, I have posted a similar thread in power systems a couple of hours ago.
My hypothesis is that with a twin, you have twice the power output, but the pitch speed remains similar. It is also known that a larger prop spinning slower is more efficient than a small prop spinning quickly. I am not sure how that translates to acceleration though, using f=ma, we know that the force (in this case the tractive force from the props) is proportional to the acceleration, so in theory it should increase with the increase of force, that is of course assuming that mass would be constant, and it wouldn't because two motors and esc obviously weigh more. How drag from the extra nacelles and propellers affect the aircraft also need to be taken into account :/
James
-james- is offline Find More Posts by -james-
Old Apr 24, 2012, 06:04 PM
Lpbug is offline
Joined Jul 2011
James
Well, with a larger prop, I guess you have to take into account of torque, as T=Ia, the I increases as mass increases, so to get the same amount of torque, the smaller prop would need a lot more angular acceleration to compensate for its smaller rotational inertia.
Old Apr 24, 2012, 09:24 PM
StewieRC is offline
Find More Posts by StewieRC
This Calls for a Sexy Party
StewieRC's Avatar
Minneapolis
Joined Sep 2010
extra bearing friction, extra drag from another prop.
StewieRC is offline Find More Posts by StewieRC
Old Apr 24, 2012, 11:23 PM
Lpbug is offline
Joined Jul 2011
Okay, but for the extra torque you're getting, it would probably not be too inefficient a choice right?
Old Apr 25, 2012, 02:58 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
It's generally accepted that larger diameter props are more efficient at creating thrust than small props. For the same total thrust you're looking at the difference between one large prop or two or four much smaller props.
But acceleration is governed by how much total thrust you have. If the total thrust is the same the acceleration will be too .
Speed is basically related to the pitch speed (prop pitch x rpm). It doesn't matter what diameter the props are from that point of view though if the thrust is low the plane may have trouble ever accelerating up to the theoretical maximum.
And of course efficiency really means how much power do you need to put in to get out the thrust/speed that you're looking for. Multiple motors with small props will almost always need more input power than a well sized single motor with a larger prop so less efficient overall. In our terms that basically just means that with the same size battery you'll get a shorter run time with the less efficient multi-motor system. But the difference won't be huge.
Steve
slipstick is offline Find More Posts by slipstick
Old Apr 25, 2012, 05:35 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
The main reason to go multi-engine is to get more power through the props. With a single prop, the amount of power you can put through it might be limited by the maximum diameter you can fit on the aircraft without the prop hitting the ground.
abenn is offline Find More Posts by abenn
Old Apr 25, 2012, 05:47 AM
ulogix is offline
Find More Posts by ulogix
Birmingham (UK)
Joined Sep 2010
I was considering a 4 prop setup with the two inner props being low pitch for good low-speed response, while the two outer props being high pitch for good speed.
Can anyone think of any major problems that such a setup might cause? Is it worth bothering with?
ulogix is offline Find More Posts by ulogix
Old Apr 25, 2012, 05:52 AM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
That's not true in this case. One large prop is more efficient than one small prop, but only because it's got to move more air through a smaller disk
One large prop is the same as two smaller props of the same area.
The reason big planes have multiple engines is that they don't have enough ground clearance for one huge prop. It's safer, as they can continue to fly if one engine fails, and there are structural benefits to moving heavy weights out onto the wings. (the wing doesn't have to be as strong if the weight is in the same place as the lift). Also many multi engined planes have been designed around existing engines, many WWII bombers used 4 engines of similar types to the fighters.
Very little of this is relevant to models, except possibly ground clearance. If you have a single motor, the long landing gear is going to make it look like a small plane.
RobinBennett is offline Find More Posts by RobinBennett
Old Apr 25, 2012, 07:34 AM
Staffs, UK
Joined Nov 2003
Except it is very often true in precisely this case. E.g. when you look at the likely disk area of a single prop vs two or more props using the same total power the single prop will almost always have more area. E.g. replace one 10" prop by 2 x 7" props - slightly less area. If, as is more likely, you use 2 x 6" props that's over 30% total less disk area.
Obviously it would theoretically be possible to replace one 10" prop by two larger props turning very much slower (and either use very high pitch props, or lose a lot of pitch speed)...but very few people do that .
Steve
Old Apr 25, 2012, 07:35 AM
abenn is offline
Joined Jul 2004
I can't give you any rules, or formulae, or anything, but that doesn't sound like a good idea.
First of all, the props probably won't be at their most efficient if they're trying to do different things at the same time. Then, when you want a quick response, it still won't be very quick because only half of your power is coupled to low-pitch props. I'm guessing it's probably best to put "compromise" props on all the motors.
Build Log Scratchbuild YC-14 twin prop cargo plane RCSquale Foamies (Scratchbuilt) 35 Apr 24, 2012 03:20 AM
Discussion Servos For Twin Cargo Plane (help Please) ramcam Foamies (Scratchbuilt) 3 Nov 20, 2011 04:34 PM
Video rc cargo twin high alpha boxermad84 Electric Plane Talk 0 Nov 07, 2011 11:10 AM
Discussion the twins, a cargo plane, REFIT. nemoskull Scratchbuilt Indoor and Micro Models 9 Oct 31, 2011 02:52 PM
Discussion 2 engine "twin" cargo plane VTOL attempt goldenite007 VTOLs 4 Dec 20, 2009 08:15 PM
