Old Apr 24, 2012, 02:40 PM
wollins is offline
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
30-32mm spinner for 5mm shaft
I've asked this question before a long time ago but figured id ask it again in case there have been any new developments. Looking for a spinner (not for folding props .. regular spinner) that's in the size range of 30 to 32mm diameter that can fit a 5mm shaft. Anything out there?
If not, can something be done to make one up? For instance can one that's made for a smaller shaft be "reamed" out toi accomodate the 5mm shaft? I was looking at a few out there (here's an example) and thinking whether this was possible to just drill out the collet adapter that comes with it to fit my shaft?
Colin
wollins is offline Find More Posts by wollins
Old Apr 24, 2012, 03:38 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Can you not find a Plastic spinner that does not have a built in shaft adapter gizmo . Lots were made & sold over the Decades before China, that simply went onto the prop stud before the prop.
Try your Local Hobby Shop :-)
Bare is offline Find More Posts by Bare
Old Apr 24, 2012, 05:14 PM
BobRCnut is offline
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Hyperion offers a 32mm spinner that has adapters for different diameter prop shafts, including 5mm... http://www.allerc.com/hyperion-32mm-...er-p-2582.html
(They come in "Aero" and "Standard" shapes.. the Aero is longer and pointier.)
BobRCnut is offline Find More Posts by BobRCnut
Old Apr 25, 2012, 08:28 AM
wollins is offline
wollins's Avatar
Toronto Canada
Joined Aug 2004
Classic case of the K.I.S.S. principle!
Thanks guys ... it's weird how sometimes you can miss the simplest solution for something even when it's staring you in the face! I've been looking for this solution for two years now and it never occured to me to use a "regular" spinner (without a built in prop adapter - like the HP-SPSTAN-32) and just get a separate 5mm prop adaptor (like the HP-ADAP-50L) for it!
Went for the above Hyperion spinner and prop adapter! (thanks BobRCnut!)
Thanks again!
Colin
Sold RFM Spinner 32/5mm shaft Kholder116 Aircraft - Sailplanes (FS/W) 2 Mar 12, 2012 03:25 PM
Discussion Source for a 32mm spinner that takes a 6mm shaft? flyboy320 Electric Sailplanes 7 Nov 11, 2009 10:47 AM
Found 30mm folding spinner for 5mm shaft/8mm root jjs63james Aircraft - Electric - Airplanes (FS/W) 8 Oct 10, 2005 09:15 PM
FS: RFM Carbon 32mm spinner for folding props (4mm shaft) kyril Aircraft - Electric - Airplanes (FS/W) 1 Jun 08, 2004 09:57 AM
wtb: 30mm spinner for 5mm shaft, (folder) 8mm pin opualuan Aircraft - Electric - Airplanes (FS/W) 1 Jan 03, 2003 12:28 PM
