Espritmodel.com Heli Air
Old Apr 24, 2012, 01:27 PM
United States, TX, Lewisville
Joined Jan 2011
u-can-do 60 with dle?
couldnt find much on this.... do yall think it would be a good 3d plane? I really want to find a nice (inexpensive) around 200ish frame for a dle 20 for 3d...thanks
michael88997 is offline Find More Posts by michael88997
Old Apr 24, 2012, 02:16 PM
Village Idiot!
ScooterInVegas's Avatar
United States, NV, Las Vegas
Joined Apr 2011
U-Can-Do, Evolution 26 cc (0 min 26 sec)
http://www.youtube.com/watch?v=FPG98WQn-NU
ScooterInVegas is offline Find More Posts by ScooterInVegas
Old Apr 24, 2012, 03:12 PM
Joined Jan 2011
Second one doesn't work... I'm comparing it to a mojo 65 which I've heard is a great combo, the u can do is lighter and about the same size so I would think it would work great
Old Apr 24, 2012, 07:59 PM
Jacksonville Fla.
Joined Mar 2007
The DLE 20 would be twice the engine recommended. As the U CAN DO is a 3D type airplane and subject to flutter at high speeds I wouldn't do it
jetmech05 is offline Find More Posts by jetmech05
Old Apr 24, 2012, 10:35 PM
Mtn Home, Idaho
Joined Feb 2010
Does it have to go fast with a dle20 on the nose.
I also want this plane and wonders about the dle gasser would it be faster then a 91 2 stroke?
Evan03 is offline Find More Posts by Evan03
Old Apr 24, 2012, 11:53 PM
Village Idiot!
Joined Apr 2011
The standard prop for a DLE-20 is a 17X6. The DLE-20 has about the same power as a OS 120AX.
Fuel: 87 octane with 27-28:1 Stihl HP non-synthetic oil
Prop: Xoar 17x6
Tach: 8,350 rpm
Static thrust: 13lbs 11oz
Old Apr 25, 2012, 07:42 AM
Jacksonville Fla.
Joined Mar 2007
Does it have to go fast with a DLE 20...no not if you can keep the throttle down...but if you get excited and add too much power...then you may have a problem...or you can set the throttle to not open all the way...a de rate so to speak...but if you do that then why put on a DLE 20?
The only airplane I saw come apart in the air was a U CAN DO..there was a buzz that happened so fast you could not react and then there was a ball of confetti and a wing tumbling down...this happened at the bottom of a loop or hammer head.
I have read on here that the U CAN DO does not like speed and is prone to flutter
Good Luck
Old Apr 25, 2012, 07:51 AM
Joined Jan 2011
Well wouldn't be competing for speed on it, correct me if I'm wrong but most 3d places tend to flutter at high speed...
I'm also looking at this plane
NashBro 2010, EE60 with a DLE 20cc, 3D RC Airplane (10 min 25 sec)
Old Apr 25, 2012, 08:02 PM
Jacksonville Fla.
Joined Mar 2007
Flutter leads to airframe failure so fast at times it's over befor it began...do all 3D planes flutter at high speed ...no.....flutter will be heard not seen, a buzz sound..if the pilot does not react quickly the airplane can self destruct
Old Apr 26, 2012, 12:43 PM
Joined Jan 2011
I think I'm going to go with a profile... Easier on the engine and better for 3d
Sold .40 size U-CAN-DO w/ST .60 fgroza Aircraft - Fuel - Airplanes (FS/W) 0 Mar 06, 2012 07:56 AM
Discussion U can do 3d ..60 lostplane900 3D / Fun Fly Fuel Planes 12 Feb 28, 2012 06:45 AM
Wanted 60 size U-Can-Do wing Roo man Aircraft - General - Miscellaneous (FS/W) 0 Jan 08, 2012 10:42 AM
Sold Great Planes U-Can-Do .46 with Thunder Tiger .91 4-stroke & servos - N. Colorado LPU Garret H Aircraft - Fuel - Airplanes (FS/W) 5 Dec 11, 2011 09:31 AM
