Old Apr 29, 2012, 08:56 AM
mikes68charger is offline
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, IL, Rock Island
Joined Jul 2010
Originally Posted by mikes68charger View Post
I wish you posted sooner that was a wast of $18
Right. I can't wate
Thrust is real important number for me.
I had a rig set up when I was spending all that $$ on EDF set ups I'm going to use to test these props. It keeps me at a safe distance
I will admit that the ARC 28-58-1 on a 70mm wemo fan would make the most thrust/watts for 110amps/5 pounds EFFLUX around 180ish
But same motor with a prop rocks.
mikes68charger is offline Find More Posts by mikes68charger
Old Apr 29, 2012, 02:17 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Mike,
Are you testing the thrust on the bench?
Testing thrust on the oversquare props like 7x10, 7x13 or 8x23 won't give a very good idea of how they'll perform in flight.
These props will give you horrible static thrust results below 100mph airspeed, but start producing big thrust once they're moving forward and the relative angle of attack to the blades starts decreasing.
You could blow a leaf blower on your test rig and THEN measure static thrust!!
murdnunoc is offline Find More Posts by murdnunoc
Old Apr 29, 2012, 04:29 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
how does static Amps general compare with inflight? for these props..
Assuming you fly fast and in a sleek model..
Is static Amps always more ?
sebbe is offline Find More Posts by sebbe
Old Apr 29, 2012, 04:41 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
I'd say 15-25% unloading in flight as a rule of thumb with these props. I've tested a bucketfull of props and static A is always more than in-flight.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Apr 29, 2012, 04:44 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
how does unload compare between a "normal" prop like 8x8 to a over squared like 8x17.... can we se any pattern, like the oversquared always unloads more ?
Old Apr 29, 2012, 05:14 PM
Arcteryxxx's Avatar
Joined Feb 2010
A "undersquare" prop seems to unload more than a square as a general statement, but there are many variables to consider, so generalizing is a game of chance. Such variables are eg. the make (design) and pitch, rpm (as a factor of rigidity and airfoil) etc. etc.....
The data from folding prop is very much dependent on rpm and the size of the spinner it's attached to....
Old Apr 29, 2012, 05:36 PM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
So my 7x13 folders mounted on a 45mm Turbo spinner are a 8x..something?
arcticflyer is offline Find More Posts by arcticflyer
Old Apr 29, 2012, 06:07 PM
Arcteryxxx's Avatar
Joined Feb 2010
You need to measure the width... The prop will draw more amps on a 45mm middle piece than on a 32mm... obviously....
Old Apr 29, 2012, 06:12 PM
Joined Jul 2010
Like stated before I can't find any high pich 7in prop. And as I'm trying this motor I don't want to speed the $$ on folding props untill I find out ruffly what prop I need
That's good to know about unloading and low thrust numbers
I know my ARC 28-58-1 with a 6x4 prop is 5.5 pounds. I'm hopeing this big ARC will do an 8x8 with 9 pound. If so I may get 2 of them for my big falcon as in EDF set up I was going to use 12s 5000 mah set up
Old Apr 29, 2012, 06:22 PM
Arcteryxxx's Avatar
Joined Feb 2010
Mike: have you contempated a gearbox for your 28-58-1? I have the same motor turning a 15x18 prop on 5S with a Kontronik KPG 5.2:1 gear
Old Apr 29, 2012, 06:32 PM
Joined Jan 2006
Mike grab an APC Sport (Nitro) prop in either 7x9 or 7x10 and throw that on there and lets see what the numbers show. Those numbers that Murdo posted back on page 2 are Sport or Pylon props. Won't know what you need until you spin her up with something....gotta have a base line.
Old Apr 29, 2012, 06:35 PM
Arcteryxxx's Avatar
Joined Feb 2010
<<<<<<<<<<<<<<<true, so true!
Old Apr 29, 2012, 07:54 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Originally Posted by jackosmeister View Post
I have one of those 7x7 aeranauts somewhere, I remember working out the max rated rpm was only like 14k! so threw it in the bits box...
Hmm, well I flew a plane 190 mph with one. It worked for me.
Steve C is offline Find More Posts by Steve C
Old Apr 29, 2012, 08:40 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
I never tried it Steve, just read the 14k rpm rating and thought screw trying that
jackosmeister is online now Find More Posts by jackosmeister
Old Apr 30, 2012, 03:38 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Well, Koch:s props are made for 45mm spinners and above,, So I guess its a 7x13 on that spinner..
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 02:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 05:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 03:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 03:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 03:26 AM
