Joined May 2012
Show me a motor which can turn a 18x35 at reasonable RPM?
The tests of Ralph showed us if u want speed get a propeller close to the 8,5x23 if you want acceleration and high vertical mount a higer diameter + less pitch. Maybe im too stupid to read diagrams and watch videos? |
![]() ![]() ![]() Ralf did it his way, and it is obviously a good way,but why do you think it is the only way? Keep watching videos and diagrams, while otherones try to find other innovative solutions! Yello |
Joined May 2012
Eyello because he can prove that it works as he says what can you or Slowbar show us? Anothert thing that would be interesting would be the maximum level flight speed of one of your F5d ships. I want to show you that the LP1.1 is not a bulky duck
![]() Looks like I'm going to have to try this one myself. You say if I want acceleration I should use a large diameter lower pitch prop and yes you're right. BUT what if I use a large diameter, high pitch prop and turn it at a lower rpm? Just some generalisations (very general) 1. I still achieve the same pitch speed as the small props at high RPM 2. I still achieve the same static thrust as the small props at high RPM 3. My prop is more efficient simply because it has a more surface area. 4. My prop is more efficient because it rotates slower. No chance of supersonic or transonic flow over the top half of the blade and definitely no chance of supersonic tips. (much more laminar flow) 5. My prop is more efficient because less of it is consumed by yoke area. (larger diameter prop with same yoke size) Just trying to convince you that there's other ways to go fast. I've been playing around with the idea of mounting a ducted fan on an F5D airframe as shrouded rotors can be considerably more efficient then a normal prop. I've even drawn up my own ducted fan rotors which I may end up getting moulds cut for. Point is, this is an ever changing hobby and it never hurts to be open minded about new ideas Ben |
Joined May 2012
Hi Ben!
I have to admit that I feel sorry for beeing rude at first. Sorry! I'm not entirely sure if a bigger prop means much more drag in a steep-speederlike-flying-angle. The smaller props rotate so fast that that isn't a real problem but I don't know how this will behave with a much bigger prop. Germans also played with the idea of EDF on speeders some time ago if you like to abuse google translator u can get some ideas from this thread: http://www.rc-network.de/forum/showt...wellenleistung |
I'm not sure where you get .63 mach as a limit for tip speeds. Plenty of props are up above .80 with good efficiency. Just make sure it has the correct airfoil (no clark Y) and it's okay. It's still tough to beat the CAM 5x5 in an F5D ship after all and we run those tip speeds way up there.
There's a great book by Stuart Sherlock of Supercool props and he covers this. Steve C |
Big Mega on 7S
Well if there was any doubt that an Ice Lite 200 can take 7S I put that to rest today
![]() Hooked the Mega 22/60/1E up to the test stand today with my modified Ice Lite 200 (sinks and fan, no fan today though). I got a cheap Zippy 7S 3300 35C just for testing and it finally came in the mail after nearly 4 weeks ![]() As you can see from the video there was no fire and the ESC and Motor were fine but the battery started to get hot which is expected for a 35C. During the test the voltage cutoff kicked in as the battery was really struggling with 250+ amps static but I was surprized at how well it held up to the pounding. This setup produced 5.5KW of power with Downunder's 7x10 folders. I am convinced that 7S will get the Monster near to or to 400kph (250MPH).
| Thread Tools | |
| Discussion Buying fast planes from .... | sebbe | High Performance | 17 | Apr 10, 2012 02:57 PM |
| Sold Pattern plane,Trainer planes Cheap!Need to move fast. | radman615 | Garage Sale/Large Lot Ads | 5 | Mar 03, 2012 05:16 PM |
| For Sale JEPE fast foam BIG F-18 HORNET | pajlotmato | Aircraft - Electric - Jets (FS/W) | 2 | Jan 30, 2012 03:40 PM |
| Discussion How fast can a Big Lama fly? Pretty fast! | Owner1 | Coaxial Helicopters | 1 | Aug 12, 2011 03:53 PM |
| Discussion Need some advice! I'm looking for a big fast plane! | JoeyNC | Fuel Plane Talk | 6 | Jun 09, 2010 03:26 AM |
