Old Apr 26, 2012, 11:48 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Originally Posted by arcticflyer View Post
What is the KV on that Mega 22/60?
Forgot to ask...what ESC were you using?
I don't have an exact KV on 22/60/1E. It's a buddy's plane.
Numbers seem to point to around 1400kv. I know Peter M has a KV on his identical motor. I'll try to find it.
It looks like that motor could turn a 7x10 at around 30K on 7S. If your speed ship's airspeed runs around 80% of pitch speed, which is commonly held as an efficient level, that would put the airspeed at 227mph
Might require dropping to 6S to run a 7x13 prop.
That would give pitch speed of around 325mph!!!
We ran the 22/60/1E on an ICE 200A. Full size with heat sink. Love that ESC.
murdnunoc is offline Find More Posts by murdnunoc
Old Apr 27, 2012, 12:10 AM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Music to my ears Bro...If I can get away with those kinda numbers with 6/7S that plane should be a black bullet
arcticflyer is offline Find More Posts by arcticflyer
Old Apr 27, 2012, 01:15 AM
jetdryvr is offline
Find More Posts by jetdryvr
jetdryvr's Avatar
United States, CA, Fairfield
Joined Aug 2004
Hey Arcticflyer,
Does that hitec need a bumpy servo cover or can a straight piece cover the servo and keep it smooth.
Erik
jetdryvr is offline Find More Posts by jetdryvr
Old Apr 27, 2012, 01:17 AM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Steve - how am I going to get three antenna's from a 6255 receiver...if you know a neat mod please tell.
Here's the mod
dsmx
http://www.horizonhobby.com/webapp/w...pe=productgrid
or dsm2
http://www.horizonhobby.com/products...iver-SPMAR9300
Pretty sure Spektrum does not recommend 6255 in all carbon airplanes. They tell you to use 3 or 4 antennas, which means one of the 9ch rx's.
Steve C is offline Find More Posts by Steve C
Old Apr 27, 2012, 03:43 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Guys,
I measured 1415rpm/volt cold.
Regards
Peter
Peter M is offline Find More Posts by Peter M
Old Apr 27, 2012, 10:52 AM
Joined Jan 2006
Jetdryvr - Made my own servo frames from ply and even with the frames they do not stick above the wing skin. They are a nice thin servo...first ones...so the performance will have to wait and see.
Steve - Guess I wasted my money on the 6255 (will find another plane to put it in)...ordered a DSM2 9300 from AmainHobbies just now. Pretty cheap for the older DSM2 $69.99.
Peter M - Thanks that means I need to get some 7S packs on the way...will do some tests with 5 and 6S when the motor gets here then I will know for sure. Nothing like good hard data from guys who have spun the motors up!!!
Old Apr 27, 2012, 12:30 PM
wastegate is offline
Find More Posts by wastegate
Annoying people since 1970 :)
United Kingdom, England, Taunton
Joined Nov 2005
Great project Arctic, looking forward to the results
wastegate is offline Find More Posts by wastegate
Old Apr 27, 2012, 03:52 PM
Jocke is offline
Find More Posts by Jocke
WATTSUP.SE
Jocke's Avatar
Sweden
Joined Dec 2001
Fast big inrunners for zpeeeed
Jocke is offline Find More Posts by Jocke
Old Apr 27, 2012, 04:00 PM
mikes68charger is offline
Find More Posts by mikes68charger
Why kamikaze pilot wear helmet
mikes68charger's Avatar
United States, IL, Rock Island
Joined Jul 2010
I would love to see more larg prop/motor set ups
I just got in an ARC 36-75-1 1800kv inrunner. For my 69in speed falcon
http://www.lightflightrc.com/HTML/pr...36-65&75mm.htm
I'm hopeing to spin a 8x8 as fast as I can
I'm also thinking of getting this huge 56x92mm inrunner 1000kv http://www.hobbyking.com/hobbyking/s...or_1000kv.html
I got a falcon 120 jet that needs to spin a 16x12 as fast as possible
mikes68charger is offline Find More Posts by mikes68charger
Old Apr 27, 2012, 04:48 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
NNOOOWW you're talkin!
Old Apr 27, 2012, 04:53 PM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
Never a waste of money to have spare parts around! That 6255 is perfect for speed 400 to F5D size planes (gliders too) that have a mix of glass/kevlar/carbon.
Mike,
8x8 sounds too big for that motor, unless you plan on running only 4s and it will pull 100 amps. 1000-1100kv is more where you want to be for a prop that size.
Old Apr 27, 2012, 05:35 PM
tho98027 is offline
Find More Posts by tho98027
tho98027's Avatar
Joined Aug 2004
Plettis... they're in a league of their own.
I love your website/blog Jocke! I check it often. It's always fun to read your projects and articles. Keep up the good work man!
tho98027 is offline Find More Posts by tho98027
Old Apr 27, 2012, 05:56 PM
Joined Jan 2006
jocke - that is one sweet motor.
Steve - You're right...it (6255) will probably go in my Plasma. You mentioned mounting the receiver up in front of the wing with the antennas out the sides and the remote in the tail boom out the top?
Mike - I would be really interested in the numbers on that ARC please let us know when you get some tests done with props on that motor. I think you are gonna find that what Steve said is true the KV is a little high for the higher cell Lipos.
Is the Falcon you are talking about the ARF that Nitro planes sells? If so and you run that monster motor make sure to post it up...that should be interesting.
Old Apr 27, 2012, 06:06 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
+1!
I'm clueless as to the performance of the big ARCs
Old Apr 27, 2012, 08:32 PM
Joined Jul 2010
Will do. It seems very hard to find any 7 in props that can handle the rpm (close to 30k) I want. I was going 8in as towerhobbies sells a ton
I will try that monster Motor when it gets in stock.
It seems leopard makes the same motor at 2x the cost
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 02:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 05:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 03:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 03:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 03:26 AM
