Old Sep 11, 2012, 12:43 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Arctic: that picture sure gives some clue about the space available in the Monster the 36mm MEGA and 39mm NEU looks very small all of a sudden...
Very cool!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Sep 15, 2012, 08:47 PM
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
New Fixed Props Arrive!
My 7.6x12.5's arrived from Germany....Beautiful work Marcus I am impressed
What worries me is our rough field...the rodents have wreaked havoc on our field over the past several years and every landing is a potential broken prop!
As soon as my new back plates arrive from TT in Texas will be running some tests with these on 6S with the big Mega, which is installed in the plane now.
arcticflyer is offline Find More Posts by arcticflyer
Old Sep 16, 2012, 02:48 AM
sebbe's Avatar
Sweden
Joined Feb 2006
man those props look rigid NICE..
sebbe is offline Find More Posts by sebbe
Old Sep 16, 2012, 03:40 AM
member of 400km/h club
Joined Nov 2008
scorpion-fan is offline Find More Posts by scorpion-fan
Old Sep 16, 2012, 03:47 AM
250mph club
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
Hi Ralph!
The mold i made was for the 8,2x12,5! I didn' t have made the molds for the small one yet but i have the plugs! If Skip likes the fixed ones i of course can make the folder ;-)! Ciao, Marcus who is still in Hamburg
M. Koch is offline Find More Posts by M. Koch
Old Sep 16, 2012, 03:52 AM
Joined Nov 2008
enjoy your vacation!
Old Sep 16, 2012, 05:17 AM
designer,builder,flyer
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Hello fellows, after searching and reading, I finally found a couple of.burned 4025's. My plan.is.to rewind one for speed croco style. I know nothing about rewindind but am willing to take on the job and learn. Question is what wind etc does a rookie need to study, I'm turning a 7 x7 @ 32.5 static and doing 200. What wind type wind and prop size is suggested by you pros for a 6-8s setup?
Tom
ApexAero is online now Find More Posts by ApexAero
Old Sep 16, 2012, 10:04 AM
Carbon fiber is our friend
Steve C's Avatar
Lodi CA
Joined Feb 2001
First make sure you know how many magnets it has. It could be 8 or 10 and they need to be wound completely different. If it's 10, I'd look at this one - http://www.scorpion.powercroco.de/12...dscorpion.html
Winding the teeth in pairs as Ralph does on YY, makes it easier. You can use shorter wire and you find a short, you don't have to undo as much. You risk a short when the wire ends up near the sharp "T"ends of the tooth and this is more likely if you're really packing in the wire.
Also you can get one if you've left wire too close to the middle and it gets pinched when you put the stator on the bearing tube.
It hurts your fingers and it takes longer than it seems like it should. Be patient and you'll figure it out.
I'm running a stock 1100kv 4025 with 9x20 prop on 5s soon. If I rewind it with the same turns and big wire, maybe I could go as high as 6s, but I'll probably add some turns and go up to 10 or 12s.
Steve C
Steve C is offline Find More Posts by Steve C
Old Sep 16, 2012, 03:22 PM
ApexAero's Avatar
Joined Aug 2008
I'm scoping supplies locally, found a motor shop that has insulator paper, wire. What is the loaded rpm and amps? I tried a 7 x8 today , it didn't unload at all. Arc 36mm
Old Sep 16, 2012, 04:33 PM
Joined Jan 2006
Couple of links I found helpful:
http://www.bavaria-direct.co.za/models/motor_info.htm
http://www.rcgroups.com/forums/showthread.php?t=666877
Old Sep 17, 2012, 07:14 AM
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Tom
Hi Tom,
These 2 posts have really gotten my attention !
1. You are turning a 7x7 @ 32,500 rpm
2. It takes well into 3500 watts to do this with an APC Sport, or are you using a Graupner (which needs less than 2500 watts to turn 32,500) ........... and how many cells are you running ?
3. 7x8 didnt unload at all ............... was this from inflight data, and how long did you run WOT, also what plane of yours has 7x7 @ 32,500 rpm with 200 mph ? (or is that 200 amps) ?
This is no "ordinary power level" data you are looking for ..................... "loaded rpm and amps" ................ do you want in flight data ?
moparmyway is offline Find More Posts by moparmyway
Old Sep 17, 2012, 10:40 AM
Joined Jan 2006
Mopar - I think this is the plane and setup that Apex has been testing:
http://www.rcgroups.com/forums/showthread.php?t=1715245
He might have moved to something else but he was testing some big ARC motors in this plane.
I did some static testing yesterday with the big Mega installed in the Monster. I got close to 3KW at 21,000RPM's and 163 AMPS on a 5S NanoTech 65C/130C with Marcus' 7.5x13 folders. Going to get some kickin 6S batteries from one of my Heli buddies today and do some static at that level. New spinner should be here any day and will get some inflight data at 5 and 6S.
Old Sep 17, 2012, 01:43 PM
moparmyway's Avatar
New York
Joined Jan 2009
My gosh !!!
I would definately try it on 6 cells with 5 cell data like that on a 1 turn !!
Allmost 260mph pitch speed with 5 cells !!!
Thanks for the links for Apex, I will look now !
Old Sep 17, 2012, 09:25 PM
ApexAero's Avatar
Joined Aug 2008
Thanks arctic
Mopar, kast I checked it got 2100 watts at 113 amps and 32.5 k rpm static. Arc 36-65-1 2080kv, cc125, genace 4800 60c5s aeronaut 7x7. Apc 7x7 does work better.
Old Sep 18, 2012, 03:40 AM
moparmyway's Avatar
New York
Joined Jan 2009
My Gosh !!
I have grenaded them Aeronutz 7x7 props at 30k+
Your voltage is about 3.72 per cell ............. those figures are with a full battery, correct ?
How did you get rpm and power levels with the Phoenix 125 as your ESC ?
More specifically, what test equipment did you use ?
Would you be willing to swap in an ICE 100 to see how it does in flight ?
Getting back to your previous posts, how do you know the 7x8 did not unload if running Phoenix 125 ?
I love your balsa scratch build !!
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 02:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Garage Sale/Large Lot Ads 5 Mar 03, 2012 05:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 03:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 03:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 03:26 AM
