Old Sep 01, 2012, 10:03 PM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Subscribed!
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Sep 02, 2012, 01:40 AM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
to get the best results with the 45xx series you need bigger blades like 11x20 or more as we just use.
scorpion-fan is offline Find More Posts by scorpion-fan
Old Sep 02, 2012, 05:34 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Thats it .................. NOW i am gunna puke !!
If it aint Marcus posting pictures of his CF spinner on this big horse, its a picture of this work of art above !!
Dudes ......... my computer is gunna short circuit from my drooling !!!
moparmyway is offline Find More Posts by moparmyway
Old Sep 02, 2012, 05:57 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
LOL!
and I've realised that I'm still in "preschool" ......
Peter M is offline Find More Posts by Peter M
Old Sep 02, 2012, 10:40 AM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Big Motor...Big Plane
Peter - that big Scorpion of yours needs one of Marcus's Big Typhoons
arcticflyer is offline Find More Posts by arcticflyer
Old Sep 02, 2012, 02:21 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
That's awesome! Looks like I see gold inside the front, but the back end / stator holder is a new piece correct?
I don't see a place for the prop yet. How many blades will this one get?
Steve C is offline Find More Posts by Steve C
Old Sep 02, 2012, 03:34 PM
M. Koch is offline
Find More Posts by M. Koch
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
Hi Steve! The stator is complete new cnc-drilled by my colleaugue Stefan Bayer who makes all the parts for the new motors, yokes and so on! The yoke for the prop in Ralphs "armor piercing granade" special design will be integrated in the middle part above the cooling holes! Prop i think will be the new
13x27 prop! Not sure if 2 or 3-bladed!
Ciao, Marcus
M. Koch is offline Find More Posts by M. Koch
Old Sep 02, 2012, 04:33 PM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
Ralf,Marcus,
First of all,very nice work even without the klowledge about the numbers Ralf is talking about!!!
The ventiation holes at the front look like beeing enlarged to the spinner direction.
In my understanding they are the outlet ,so they throw out cooling air at spinning rotor,what is your intention to modify the holes like this?
wouldnt it be even better to keep the airflow angle more backwards, or even keep the sharp corner to benefit from the low presure spot created by the excelerated airflow behind the prop?
Or do you want to reverse the airflow after motor stops?
Yello
Mreyello is offline Find More Posts by Mreyello
Old Sep 03, 2012, 01:13 AM
Joined Nov 2008
there is nothing left from the former radial fan anymore.
the airstream in these motors is completely inverted.
the air is pressed with 400km/h and more throup airgap and slots.
this helps to increase the overload factor massiv.
Old Sep 03, 2012, 10:07 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Hello all, I have been wondering which way the air flow is on the leading end bell. Am planning a 4025 rewind. How can one test windings with minimal equip?
Tom
ApexAero is offline Find More Posts by ApexAero
Old Sep 08, 2012, 04:38 AM
moparmyway's Avatar
New York
Joined Jan 2009
Originally Posted by arcticflyer View Post
The 22/60/1E arrived from across the pond...it is a 36mm motor that is 90mm long
The KV on this motor as tested by PeterM is right around 1400 and according to all his prop testing data it is quite a beast
Due to the length of the motor and Mega's stiff wires (hate them) I had to make them into little pig tails by winding them around a pen (carefully I might add).
Just found it !!
Beel looking for this picture since you posted this !!!
See how far back the tinning goes on the motor leads ?
I usually cut off everything except the last 1/4" of the tinned wire, leaving much shorter leads !!
Old Sep 08, 2012, 11:31 AM
Joined Jan 2006
I wondered why those wires were so stiff...might unwind my pig tails and do the same.
Old Sep 08, 2012, 11:36 AM
moparmyway's Avatar
New York
Joined Jan 2009
Cant hurt to have a look !!
If you cut enough, you might even loose a smidgeon of resistance !
Old Sep 09, 2012, 03:19 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
And here all this time I thought Mopar was ordering his motors custom built with stubby leads!
I've ripped into very other part of these motors, but haven't bothered to have a peek under the insulation
I have a feeling lots of wire strippers and nippers will be going to work with this info
murdnunoc is offline Find More Posts by murdnunoc
Old Sep 11, 2012, 12:35 PM
Joined Jan 2006
Time to test the big Mega.
Am going to put the big Mega (22/60/1E) in the Monster today and decided to move all testing from the build thread over here. I will be doing a flight video soon which will be posted on the build but all additional motor testing will be done here.
Will have to make some slight mods to get the motor in the plane.
First...the motor mount was made for Neu motors which do not have that pesky ring on the front. I do not want to weaken my plate with drilling the center hole larger so hopefully Chris can make an aluminum plate that fits on the front of the motor and will allow it to bolt flush without drilling the main plate.
The Mega is longer than the Neu considerably but it is heavier and the battery will have to move back some anyway.
I have two sets of folders to try with this setup Marcus' 7x13's and Downunders 7x10's. I also have two fixed 7.6x12.5's on the way from Marcus so will have some interesting props and combinations to test.
The hope is to get a 6S setup that will get me to 250mph/400kph. That is the goal for this build.
This winter I am going to get another airframe from Andi and that one will be built with outrunners in mind. Will be winding my own motor from a Scorpion kit....winter project!
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 03:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 06:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 04:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 04:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 04:26 AM
