Old Jun 18, 2012, 05:51 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Originally Posted by scorpion-fan View Post
its easy!
use "java prop" http://www.mh-aerotools.de/airfoils/javaprop.htm
(programmed by dr. martin hepperle) and send your file to stefan heuel ((sheuel><attt><web.de)).
he will use your *.jpdata -file to make a milling file and mill a aluminium mould for your calculated prop.
before milling you will get a 3D model file of your prop.
the costs are imo reasonable:
about 200 for the polished mould.
OK, I played around with Javaprop, and it is not all that easy! Scorpion-fan, would you be willing to share the data of one of your 7" folders? It's doesn't have to the the latest and greatest, but I want to look at getting CNC made moulds and starting from scratch is tricky!
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Jun 18, 2012, 10:46 PM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
I'm with ya on the CNC moulds...I would like that 8x12 fixed that is in the pic. With the motor I have coming and the new Monster 1.1 bet I could bust 250 with it easy.
Learned alot from that last build this one should go smoother and faster...problem is...getting ready to go visit family in the States which is going to slow the build down quite a bit!
Canada Post says the Monster should be at my house tomorrow....
arcticflyer is offline Find More Posts by arcticflyer
Old Jun 19, 2012, 05:51 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Where in the States ?
moparmyway is offline Find More Posts by moparmyway
Old Jun 19, 2012, 07:05 AM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
down under,
only diameter and pitch are not enough to describe a prop, you can make a prop with same diameter and pitch very, very different.
thre is needed more than only the prop diameter for a usable layout for a special reason.
minimum additional are needed:
wished round about input power level and rpm-level at working point and targeted speed, the main data of model (wingspan, area, weight, airfoil, used battery)
scorpion-fan is offline Find More Posts by scorpion-fan
Old Jun 19, 2012, 10:24 AM
Joined Jan 2006
Mopar - I'll be in the Elkton, Maryland area. My boy is graduating from Parris Island (Marine Corp Boot Camp) so I will be making a couple of trips down that way to see him and I plan on going to Vic's Speed event in NC while 'm down there as well.
Should be a fun month...leaving here Friday.
Old Jun 19, 2012, 03:36 PM
Joined Mar 2006
down under,
Sorry to hijack your thread here arcticflyer...
Scorpion-fan:
P in: 4000-5000W
RPM: 27-30,000
vMax: 100-120 m/s
Wing Span: 1300mm
Target weight: 2200g
Airfoil: MH-54
used battery?: 8/9/10S, ~2200-3000 Mah ?
I have read all the java prop theory and understand what you're saying. However I also know a 7" prop is a good starting point for this sized model. I never specified a pitch
Old Jun 20, 2012, 03:05 AM
Joined Nov 2008
you better should start a new thread about this.
Old Aug 30, 2012, 03:39 PM
Joined Mar 2006
its easy!
Scorpion, is this email address valid? I have contacted Stefan on the email address above but there is no reply.
Thanks.
Old Aug 31, 2012, 12:50 AM
Joined Nov 2008
yes, it is.
I hope, you have replaced the " ><att>< " by a simple "@ "
Old Aug 31, 2012, 03:20 PM
Joined Mar 2006
Yes, thanks, he's replied to me! Cheers
Old Aug 31, 2012, 05:40 PM
Joined Jan 2006
New Motor for Testing
The 22/60/1E arrived from across the pond...it is a 36mm motor that is 90mm long
The KV on this motor as tested by PeterM is right around 1400 and according to all his prop testing data it is quite a beast
Due to the length of the motor and Mega's stiff wires (hate them) I had to make them into little pig tails by winding them around a pen (carefully I might add).
As soon as I get a few flights in with the new motor mount in the Monster 1.1 and get that airframe completely dialed in, this motor is going in.
It will be tested using props that Marcus is making for me 7.6x12.5's and at 6 to 7S should put the Monster into orbit
With that said the next motor will be one of Steve's 1518 or 1521's with a KV that is better for super sonic than the high kv 1515 that I have now. Will say this...that Neu 1515/1y was burried in a field (8 inches). Then later down the road came out of the front of a plane at over 200, sailed through the air for over 50yards, hit the field....and still runs!!! Great product Steve!
Old Aug 31, 2012, 05:53 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
That is some Wicked CZ Goodness
VooDoo Child is offline Find More Posts by VooDoo Child
Old Sep 01, 2012, 05:34 PM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
New Motor for Testing II
Arctic,
You'll enjoy your 22/60/1E!
I've just bolted mine into a Parkzone Stryker Q: http://www.rcgroups.com/forums/showp...&postcount=193
I've also just started static testing an outrunner with folding blades and have been impressed to date:
RFM Spinner 38mm
Koch 9.8x17 Blades
ICE HV 160
Scorpion HK4525-520 Ultimate
10 Cells
35.5 volts
129 amps
4580 watts
16,525 rpm or a pitch speed of 266 mph
12 Cells
42 volts
157 amps
6608 watts
19,057 rpm or a pitch speed of 307 mph.....
and it has the capacity to run more pitch or diameter if need be.
Peter M is offline Find More Posts by Peter M
Old Sep 01, 2012, 08:47 PM
Joined Mar 2006
What the heck are you going to put that onto, Peter? Impressive!
Old Sep 01, 2012, 08:52 PM
Peter M is offline
Peter M's Avatar
Joined Sep 2007
Ritewing Demon 50
http://www.rcgroups.com/forums/showthread.php?t=1691229
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 02:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 05:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 03:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 03:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 03:26 AM
