Old Jun 07, 2012, 11:25 AM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Man I'd love to hear the sound that (3) blade makes.
arcticflyer is offline Find More Posts by arcticflyer
Old Jun 07, 2012, 11:28 AM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
it is very "silent", you would think, the model isn't really fast.
you must hear the 5 blade 8,5x23 in flight........ undescribable.
scorpion-fan is offline Find More Posts by scorpion-fan
Old Jun 07, 2012, 11:42 AM
Joined Jan 2006
Scorpion Fan - Was wondering...in the rewinded Scorpions what is the most common wire used (size) and what is the most common number of winds & what type of termination? I am thinking about winding a big outrunner in the near future.
Old Jun 07, 2012, 12:47 PM
Joined Nov 2008
this is very different and depends on the targeted battery, modelsize, prop and rpm.
with 1,5 (YY) or 1,6 (D) you are save for 200Amps for normal runs.
I will bring all the speedmotors back on my website soon (christmas)
now I have flight season and I find no time for doing this.
some of them you actually can find here:
http://www.scorpion.powercroco.de/
Old Jun 07, 2012, 03:02 PM
Joined Jan 2006
NEU repaired!
Got the Neu back last night and made the back plate fix today...JB Weld and cap screws...not as pretty as set screws but easier to get in and out.
The JB has to cure over night so there won't be any test flights tonight...will have to wait till tomorrow morning
Might go to the field and fly the 400 Slipso just to keep the thumbs loose
Old Jun 07, 2012, 03:11 PM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
I hope this works !!
Wouldnt it be great to know that it was under our nose the whole time ??
JB Weld and some heat !!!
Did you use heat ?
moparmyway is offline Find More Posts by moparmyway
Old Jun 07, 2012, 03:41 PM
M. Koch is offline
Find More Posts by M. Koch
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
@ Darron!
Your right! If this system was in flight in a f5D ship with 1000g max weight and about 140 cm span it would be very inefficient! But this setup were flown in an F3S model called Eagle with 186 cm span and about 3000g weight!
Under this aspects it seems not to be so inefficient !
Today we had another setup-test for our new Typhoon with a threebladed 11x20! Fastest run was between 430-435 km/h, so a step in the right direction but hopefully not the end! Time to finish my new props to get some better speed runs !
Ciao, Marcus
M. Koch is offline Find More Posts by M. Koch
Old Jun 07, 2012, 03:53 PM
Darron is offline
Find More Posts by Darron
Darron's Avatar
London
Joined Jul 2003
Originally Posted by scorpion-fan View Post
So what's the deal with the F5D prop? - I need one or a few...
Darron is offline Find More Posts by Darron
Old Jun 07, 2012, 04:34 PM
Joined Nov 2008
its easy!
use "java prop" http://www.mh-aerotools.de/airfoils/javaprop.htm
(programmed by dr. martin hepperle) and send your file to stefan heuel ((sheuel><attt><web.de)).
he will use your *.jpdata -file to make a milling file and mill a aluminium mould for your calculated prop.
before milling you will get a 3D model file of your prop.
the costs are imo reasonable:
about 200€ for the polished mould.
examples:
Old Jun 07, 2012, 04:42 PM
Joined Jan 2006
Now that is impressive! Those are things of beauty! You can bet I will have one of those! I don't mind the prop making part...it is the mold part that has always held me back.
I want that 8x12 in the pic!
Great Stuff Guys!!
Old Jun 07, 2012, 07:35 PM
Joined Jan 2006
ESC Mods Done.
The mods to the ESC are done...heat sinks front and rear and a fan on the front. Used Arctic Alumina to attach the sinks and they are there for good. Still waiting on the Kapton tape to arrive to wrap the rest of it up.
Will try to get in a flight tomorrow to test everything out
Need those Nano Tech 65C's to get here from HK then it's off to the races
Old Jun 07, 2012, 10:51 PM
Joined Jan 2006
Sorry Mopar I missed your post...in a way I did use heat. I put it under a light that gets pretty hot and let it bake all day at low heat. Hope it works!
Old Jun 09, 2012, 11:01 AM
Jebera is offline
Find More Posts by Jebera
Jebera's Avatar
United States, NH, Nashua
Joined Oct 2006
its easy!
examples:
Soo cool!
André
Jebera is offline Find More Posts by Jebera
Old Jun 15, 2012, 10:19 AM
Joined Jan 2006
In case you guys might of missed it...my first Monster is deceased: http://www.rcgroups.com/forums/showthread.php?t=1668258
The thread details the investigation that lead to a de-soldered Z connector on a Turnigy battery which brought down the plane because...stupid me was running the BEC off of the flight pack. 250 amps will melt solder!
Back on topic my NEW Monster 1.1 is somewhere between Ontario and here in Canada Post so I have a build question.
What are the Speed cup guys running for aileron link up? and are any of the guys using any of the RDS systems (which is the direction I am leaning)???
Old Jun 15, 2012, 08:23 PM
Refalovala is offline
Find More Posts by Refalovala
Joined Jun 2011
Here is a few videos of my HK fiberglass f16 w/ arc 28-58-1 in a wemo minifan, on a 6s. After I repair it and change the rx in it, I should have some longer and better ones for you.
HobbyKing F-16, w- Arc 28-58-1,70mm MiniFan Pro,6s Repainted,Red Tail and Retracts (2 min 25 sec)
HobbyKing F-16, w- Arc 28-58-1,70mm MiniFan Pro,6s Repainted,Red Tail and Retracts 2 (6 min 59 sec)
Refalovala is offline Find More Posts by Refalovala
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 02:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 05:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 03:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 03:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 03:26 AM
