Old Jun 04, 2012, 10:39 PM
arcticflyer is online now
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Well done Jacko!!!
The Monster 1.1 is on the way from Germany and I should be able to give you a good review in a week or so with a build thread and flight video's to boot!
arcticflyer is online now Find More Posts by arcticflyer
Old Jun 05, 2012, 04:47 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Jacko, it is a big risk, that your baby monster will "feal" way faster the the big one, even if you get 20mph more speed...Better to do some high altitude drop down low doppler speed runs with the baby first and smash that 220mph
sebbe is offline Find More Posts by sebbe
Old Jun 06, 2012, 11:26 AM
Joined Jan 2006
One last hole!
My 7x10's arrived from AMain (fast shipping) But still haven't received the thermal epoxy or the batteries from HK
Decided to cut one last hole for air...since my Ice Lite 200 is now an Ice Lite 300 (in the test pilot area now):eek
The NACA is just in front of the ESC and will pump air onto the back of the ESC directly. Didn't want to do this...but the 7x10 is going to push the amps at WOT to around 300 I'm guessing.
With the fan in the front and the outside air ramming the back I hope to keep the temps down on the ESC which had been creeping up prior to the mods.
I'm gonna ring this ESC out for them!
Old Jun 06, 2012, 04:27 PM
Joined Jan 2006
YEOOW.. the Q40 prop (7.4x7.8) came today...beasty looking thing compared to the 7x9&7x10 Sport!
Old Jun 06, 2012, 04:50 PM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
You should have seen the 7.4x8.1 Meanest looking prop ever!
Quite different than the one in your picture, with a straight part in the middle. I use it in one of my foamies attached to a Mega 22/35.
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jun 06, 2012, 04:56 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
The only thing is you're limited to approx 250 mph pitch speed with a 7.4x7.8.... I didn't do the numbers exactly but you're hitting max tip speeds at this pitch speed.
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Jun 07, 2012, 07:00 AM
Darron is offline
Find More Posts by Darron
Darron's Avatar
London
Joined Jul 2003
Originally Posted by scorpion-fan View Post
here you can see, how the 12 x 24 folder climbs out of the hand just with 8S and almost without throwing!
only low rpm /amps are enough to get the needed thrust.
Scorpion-fan
Is that data correct? Just under 4KW to turn a 12x24 at under 12,000 rpm seems excessive. Your motor/prop can't be very efficient?
Darron is offline Find More Posts by Darron
Old Jun 07, 2012, 07:18 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
12x24 @12000rpm isnt a small load
jackosmeister is online now Find More Posts by jackosmeister
Old Jun 07, 2012, 08:19 AM
Darron is offline
Darron's Avatar
London
Joined Jul 2003
I've achieved 11,500 at much lower power levels i.e < 1.5KW
I must have a much more efficient prop and drive system, and it's a 12x25.
Old Jun 07, 2012, 08:31 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
So Darron, what's your setup?
Was that an in-flight data log?
murdnunoc is offline Find More Posts by murdnunoc
Old Jun 07, 2012, 08:53 AM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
darron,
you are right of course.
this power system and prop is really so bad......
scorpion-fan is offline Find More Posts by scorpion-fan
Old Jun 07, 2012, 09:08 AM
Darron is offline
Darron's Avatar
London
Joined Jul 2003
darron,
You're previous answer, before you edited, was that this was a 3 blade setup.
That's cool. Would be interesting to see the 2 blade data for comparison.
Old Jun 07, 2012, 09:31 AM
Darron is offline
Darron's Avatar
London
Joined Jul 2003
It was a with a Neu motor +GB and a Saw prop with my D05, but it was too hot for F5D competition so I moved on. It was also level flight, no diving from 400m and turning 180deg every 2.5 seconds. But an F5D model is much smaller and lighter than Scorpian-fan's speed models which require more thrust (and power) to get closer to pitch speed.
I have tried offical F3S speed runs (all 4 gates) with my F5D models, and I can say that it's not easy at all! The model literally disappears as you transition from diving to level flight with the model over 200m away. Much better to use the bigger models or fly without the big dive.
Old Jun 07, 2012, 10:47 AM
Joined Jan 2006
Hey guys got a question about motor wires on these high amp applications
My motor wires are really long due to the fact I had to put the ESC back under the wing (balance issues) what size should they be in relation to the size of the wires coming out of the motor?
Also CAPS...should I add caps to the setup since I am pushing it a "tad" beyond the limits?
Got the NEU back last night Will be installing everything back into the plane today and might get a flight in tonight just before dark with the 7x10.
Old Jun 07, 2012, 11:09 AM
Joined Nov 2008
its almost impossible to compare in flight data with different models.
and its also impossible, to get useable teststand-data with an light and weak f5d prop.
this is a 2 blade 12 x 24 for f3s (50mm root distance), tested up to 12kW and a 12 x 24 for f5d (30mm root distance) for the "normal" f5d load.
this 3 blade system was able to reach 414km/h between the gates.
it also was able to get a 320km/h average with "power on" in horizontal flight at the "flight in" gate.
the max. diving speed of eagle I found with about 270km/h.
here I assume, it was about 250km/h max.
so you can calculate the reached acceleration. if inflight speed is 250km/h and average speed is 320km/h the speed at outflight gate could have been about 390km/h.
I develop my models not primary to get max speed - I'am >50years old and I'am a much bader pilot with bader eyes compared to our "young wilds". so I try to find a way, to be fast with my personal possibilities.
this means for me good acceleration, high power and powerduration (actual drive can take 270A for 20 sek on teststand without burning) and very silent drive system - so I can fly directbehind our little cottage.
a good example:
with chimera I reached 380km/h max.
my friend kai was 460km/h fast in his second flight through the gates......
now think, what could be possible for him with my eagle.
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 02:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 05:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 03:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 03:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 03:26 AM
