Old May 30, 2012, 10:09 AM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
tjoachims model is almost to fast for the camera!
also with you own eyes you would have problems to follow it.
you can calculate: with its 130m/s it needs only about 1,5sec to go through the 200m distance!!!
about setup:
10S battery; HK 4225 rewinded; special calculated 7,7" x 13,8" with up to 26000rpm into the measuring distance.
same wing as also chimera has.
so your 7" x 13" folder also should be good for your model.
in the fastest run he came down from 480m.
in the turn point he had 360km/h speed and then he had 450m (straight down) to accelerate to the measured 471km/h.
btw. this speed was about 85% of pitch speed - so we have an evidence again, that the assumption for reaching about 85% of pitchspeed is near by the truth.
scorpion-fan is offline Find More Posts by scorpion-fan
Old May 30, 2012, 10:12 AM
arcticflyer is offline
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
Great info scorpion! I wondered about his setup. The converted nitro airframe was a great idea for more space!
Do you know what ESC he was using?
arcticflyer is offline Find More Posts by arcticflyer
Old May 30, 2012, 10:18 AM
Joined Nov 2008
(older) yge 240HV with 8kHz and 18 timing, "plane slow" for acceleration.
the actual yge 160HV is also strong enough to give the needed amps.
its good for 200A for more then 30 seconds duration - but not my battery.
Old Jun 03, 2012, 05:37 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
We got the Cyclone up to 232 mph today. The Hyperion GS motor is working well, but it is near the limit now on 5S and may get pulled out soon for a rewind. Still an impressive motor for the money.
I know we're still way behind the Germans, but we are making some headway! Mark wants to see the Cyclone hit 250 before we go to a bigger plane and he has recently made a wing in carbon for this sort of thing.
I wonder if an outrunner wouldn't be a better choice for the Monster? You can swing a lot of prop!
Steve C
Steve C is offline Find More Posts by Steve C
Old Jun 03, 2012, 06:04 PM
Joined Jan 2006
Hey Steve - Let me know when you do the rewind and post it up...I have done some rewinding on some smaller motors (400 size) and they are still running strong.
Not familiar with the Cyclone airframe like to see some pics.
Our day will come! For sure outrunners are the way things are going...they seem to get rid of heat better. Might get one of those Scorpion kits and wind one myself.
I'm kinda in the hold mode right now waiting on props to come from California (Amain) thermal glue to come from somewhere else to finish the mods on the Ice Lite 200 and my 65C batteries to get here from HK (NanoTech 5S 65C 3300's).
Then we are off to the races again. I watched my video again of the 204mph pass and it was really not a good pass for measurement. It was not over the camera but well off to the side which means that pass was a bit better than I thought. Really believe that this NEU setup will get me over 220.
Old Jun 04, 2012, 01:24 AM
Joined Nov 2008
bigger models:
steve will try a horten like monster:
1,8m wingspan, up to 5kg into the FAI reglement.
5 blade pusher 8,5"x 23" with a lot of power
I will try my harpyie soon:
2m wingspan, also up to 5kg.
also 5 blade 8,5" x 23" or 3 blade 12" x 24" or 2 blade 13" x 27" with up to 16S battery and some kW.
marcus will use the big typhoon with 210cm wingspan:
also with big prop, big motor and up to 16S
in fact the visability of bigger models also for the measuring system is better and they seem to be "feeled" slower for the pilot.
btw.:
we communicate only the FAI conform (200m distance in 5-35m height) measured results - using radar or doppler we just got some very incredibly fast speed results for this short moment.
Old Jun 04, 2012, 01:46 AM
M. Koch is offline
Find More Posts by M. Koch
300 mph club ;-)
M. Koch's Avatar
Regensburg, Germany
Joined Apr 2003
Hi Guys!
For better size comparison Stefan and i with our Typhoons !
Ciao, Marcus
M. Koch is offline Find More Posts by M. Koch
Old Jun 04, 2012, 06:59 AM
Joined Jan 2006
Great Stuff Guys - I agree bigger is better!
QUESTION: With these super high pitched props how much longer does it take for the prop to really (can't think of the words) kinda like back when I rode 2 stoke dirt bikes we used to call it "come on the pipe" and that was when the engine was making the most power.
Is that why alot of guys fly a U shaped pattern? To dive the prop into the most efficient range and pull out then hold it there...Hope that makes sense!
Could you guys take some close up pics of how you are controlling airflow INSIDE the planes (scoops and vents) Think I see some NACA's (both standard and reversed) to help with airflow! The outrunners on the outside solve the problem of motor temps...was wondering about your ESC's and batteries.
Are you guys using RDS systems for your ailerons?...am thinking about that for the next Monster build.
Great information guys please stay hooked in!
Old Jun 04, 2012, 08:53 AM
Joined Nov 2008
the esc lays between the 2 holes in front of the wing.
it lays (naked!) over the 3S front battery with 5mm wooden spacers for airstream.
the motors is separated as good as possible.
there is only a small hole in the firewall for the wires.
no hot air comes through the motor into the body.
the hole behind the wing is for the antennas and the warm air from batteries.
the radio is behind this hole.
so system has almost no heat connection between motor, esc, battery and radio.
here you can see, how the 12 x 24 folder climbs out of the hand just with 8S and almost without throwing!
only low rpm /amps are enough to get the needed thrust.
the second peak shows an accelation.
the point of maximum grip of prop and the following decresing of amps with the acceleration of model are visible very good.
in longer flights to full speed the amps goes down up to 120A!
Old Jun 04, 2012, 09:03 AM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
I love the carbon flying wing.
How are they launching it?
I know you guys don't like radar, but it's all we have right now. Our planes are not slowing down during speed runs either. The fastest speeds are right as they pass the radar gun. Also have not done 400 meter dives! I think we'd have trouble seeing an F5D size plane at that altitude.
If I get an urge to take the Hyperion apart, I'll be sure to take some pics while I do it. In the meantime, you can check out Ralph's powercroco site. That's what I do! I'm really impressed with the Mega 22 series rewinds and the custom Kontronik Tango. I'd like some of those stators, as one of my Tangos broke (winding came loose and cut on the spinning can) and left me with a perfect rotor.
Steve C
Old Jun 04, 2012, 09:41 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Steve,
Rewinding a Mega 22 size inrunner?!
That's some serious surgery!
Got a link to the site where they're doing this?
murdnunoc is offline Find More Posts by murdnunoc
Old Jun 04, 2012, 10:10 AM
Arcteryxxx is offline
Find More Posts by Arcteryxxx
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Originally Posted by murdnunoc View Post
Steve,
Here you go, Murdo:
http://www.tuning.powerditto.de/Mega22-45.html
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Jun 04, 2012, 10:56 AM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
Yes, Ralph is a pro for sure. It's a thing of beauty!
Try a completely new motor, based on just a Tango rotor
http://powerditto.de/9N6P3225IL.html
Old Jun 04, 2012, 03:07 PM
E-speed buff is offline
Find More Posts by E-speed buff
186mph Funjet Ultra
E-speed buff's Avatar
nieuw vennep, the netherlands
Joined Feb 2010
Wrong thread!
E-speed buff is offline Find More Posts by E-speed buff
Old Jun 04, 2012, 06:12 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
That rewound mega 22 is awesome. Want to rewind a Mega 16 Ralf?
The baby monster (Lp1.1 @ 2.2kW) has smashed 200mph now, Think I need to upgrade to the big daddy monster...
jackosmeister is online now Find More Posts by jackosmeister
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 02:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 05:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 03:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 03:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 03:26 AM
