Old May 19, 2012, 06:31 PM
arcticflyer is online now
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
NEU Motor...no pun intended!
Well...went and did it My LHS owner gave me a killer deal on a 1515/1Y and I just couldn't resist. Another customer stiffed him on an order almost 2 years ago and the motor has sat in the box burried in the store...until today $230.00...Thanks Jack!
I know the kv is a little high but with the right prop and battery it is a "big block."
The numbers in the motor calc look good on 4S with my 7x13 folders.
We shall see...still have another "big block" coming from across the pond
arcticflyer is online now Find More Posts by arcticflyer
Old May 19, 2012, 08:34 PM
Joined Jan 2006
Vents & Motor
Well the reversed NACA vents are done...it remains to be seen if they will work or not
This motor (1515) is just to large for a heat sink in this application...wish I had the ability to monitor the motor temp in flight in real time Will probably start testing on it with 3S then move to 4.
Made a 4500 4S2P today should work fine and fits the Fuz well
Old May 21, 2012, 09:17 PM
Joined Jan 2006
Cooling Works
It was a good night..not good for flying but I went anyway...hate the wind here...but love how it slows the plane down for landing
The reason for flying tonight was primarily to see if the attempts to get more air out of the motor area and the use of a heat sink would work
Well I'm happy to report that they did The outside temp was nearly the same as my last motor case measurements so that was good. I tried to fly a similar pattern with 4 or 5 WOT passes and mixed flying in between. Upon landing I quickly measured the case temp and found 185F The average about 35 degree reduction
The motor is still holding up at 5S and the amps on WOT passes have remained the same between 103 and 109. The rotor appears to have survived the overheating (285F) of 6S. 6S is out for this motor (650 Typhoon)
Static motor tests tomorrow for the NEU...made a 3S2P 3600 65C and a 4S2P 4500 40C for the tests. Will start with APC 7x9 and go from there to the 7x13 folders.
Tried spoilerons tonight for the first time ever and was delightfully surprised at the results..will give a definate opinion when the wind is not as strong...but I actually had to give it some throttle on the approach to make the field...never had to do that before
NEW MONSTER 1.1 on the way from Germany and a "big block" motor on the way from CZ. Should be an interesting summer
Old May 21, 2012, 09:51 PM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Wow Arcticflyer, you're REALLY getting into some fun power system stuff now!
Love the plan for the 1515 1Y on 4S. Should get you around 28K with decent battery voltage.
Hmm... 28K on a 7x10 gets you 265mph pitch speed.
I think you better practice turning your head very quickly.
Will be very great to get your flight reports on a known high quality motor so that you can make good judgements on how these large inrunners can cope when running in a Speedcup-type application.
I want to see if I can bolt up a Neu 1915 or 1917 to the front of a Ninja Speed.
Something in my gut says these large diameter, short can motors will be the most efficient and still be able to dump heat for huge power.
murdnunoc is offline Find More Posts by murdnunoc
Old May 22, 2012, 11:12 AM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
Hmmmm,
25K on 7x10 in flight already requires 2,5 Kw.
Static power would be arround 3,5 Kw and 250 A at 4S.
No way to reach 28K at 4S.
Arcticflyer, i think you have to cut down your 7x10 to about 6x10!
Yello
Mreyello is offline Find More Posts by Mreyello
Old May 22, 2012, 12:03 PM
Joined Jan 2006
Would love to get my hands on some 6.5x10 or 12 folders
Old May 22, 2012, 04:40 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Yeah, over 250A would be pushing it for the Ice Lite 200. It may be alright though if partial throttle is kept to a minimum, and the NACA scoops work some real good magic.
Get an ICE 200 with heat sink.
Like you haven't dropped enough bills on this project!
Old May 22, 2012, 05:06 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
... but will the ICE 200 fit?
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old May 22, 2012, 06:50 PM
Joined Jan 2006
I have already decided not to look back at all the receipts in reference to this project because it is still far from over The ole DX7 is starting to show its age as well.
Need some real time data...like amps, volts and temps! Since I am locked in to Spektrum... due to the crazy amount of receivers that I have...it looks like their telemetry will have to do. Would really like to see them come out with something that plugs in to the USB on a laptop like Hitech has. Then a partner could monitor the vitals! And no I don't want an IPhone!
The DX7S has caught my eye...don't need amillion channels...cause I won't be flying any "whirly birds" or crazy scale stuff...to each his own Just wanna go really fast before my eyes won't let me anymore
Ordered some 7x10APC's from AMainHobbies yesterday...largest I have is 7x9.
Props are a definate issue but some good things are happening in that area
Hopefully Andi will have the Monster 1.1 version done by the end of this week and that thing will start its trip across the pond next week
Spent the day making capitol improvements on the vents...a little deeper towards the nose and removable...tiny screws...just a bit of parasitic drag which we will attempt to simply OVERPOWER! found some fake carbon covering so they match the plane now..gotta have some "BLING."
Murdo - Didn't know you were building a Ninja Speed...post it up..it's a "FAST PLANE"...with a big motor
The Ice 200 will fit in both planes...so it is a consideration if I go higher on the cell count
Old May 22, 2012, 08:48 PM
Joined Jan 2006
Holly Cow!
Mreyello - you were right...218AMPS with 3S on the 7x13 folders
then it dawned on me (it's not a 7x13 with the 45mm spinner) it
is an 8x13
Here are some static numbers that I got tonight on the beasty NEU 1515/1Y
3S 7x13 folders:
volts 12.4max
Amps 218 max
RPM's 18164 max
Watts 2209
Motor temp after 107F
(3) 3 to 4 second WOT's
3S 7x9 APC:
volts 11.8
Amps 138 max
RPM's 20665
Watts 1461 max
Motor temp after 95F
4S 7x9 APC:
volts 15.8
Amps 199.7 max
RPM's 24480 max
Watts 2589 max
Motor temp after 100F
(2) 3 to 4 second WOT's (then the batteries started pooping out,
2 old 4S Rhino's beyond their years)
Man I wish those 7x10's from AMain would get here yesterday...not
I like this MOTOR
Old May 23, 2012, 01:33 AM
Putter is offline
Find More Posts by Putter
Joined Mar 2012
I've been loving this thread for a minute now. It's inspired me to do something similar with Triffik. I was leaning towards the MVS Redliner but someone mentioned one of the Mega motors. I'm also using folders (7x4 - 9x6) and no more than 6S (2x3S in Series) but mostly 3S and 4S. The only difference is I'm looking to fly it like a Hotliner / Pylon racer. Great project BTW!
Putter is offline Find More Posts by Putter
Old May 23, 2012, 12:01 PM
Joined Jan 2006
Mega's are good motors! I have a 16/30/2 which has been used and abused for nearly three years. Had to rewind it once as the wires were pulled out from the back in a crash. Service and turn around time were great.
This is my first NEU...can tell already that I'm going to like them as well!
Old May 23, 2012, 03:04 PM
tho98027 is offline
Find More Posts by tho98027
tho98027's Avatar
Joined Aug 2004
Where do you get the TT vented spinners from?
tho98027 is offline Find More Posts by tho98027
Old May 23, 2012, 06:36 PM
Joined Jan 2006
Right here: http://www.truturn.com/cgi-bin/store...ics130&maxp=30
You have to call them for the order and explain your application.
Old May 24, 2012, 12:51 PM
Joined Jan 2006
New Monster on the way!
YEEEE HAAAA...got a tracking number this morning from Andi at HJK. The new Monster 1.1 is on the way http://www.hjk-speedwings.de/epages/...cts/Monster1.1
The current Monster now has the NEU 1515/1Y inside, 7x9APC and 4S to get things going. APC 7x10's are on the way
The bad thing about the APC's will be broken props on landing Once settled on a maxed out setup will have to order a bunch of props.
Discussion Buying fast planes from .... sebbe High Performance 17 Apr 10, 2012 02:57 PM
Sold Pattern plane,Trainer planes Cheap!Need to move fast. radman615 Non R/C Items (FS/W) 5 Mar 03, 2012 05:16 PM
For Sale JEPE fast foam BIG F-18 HORNET pajlotmato Aircraft - Electric - Jets (FS/W) 2 Jan 30, 2012 03:40 PM
Discussion How fast can a Big Lama fly? Pretty fast! Owner1 Coaxial Helicopters 1 Aug 12, 2011 03:53 PM
Discussion Need some advice! I'm looking for a big fast plane! JoeyNC Fuel Plane Talk 6 Jun 09, 2010 03:26 AM
