This thread is privately moderated by RWCLOUD, who may elect to delete unwanted replies.
Old Apr 24, 2012, 04:05 AM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
Build Log
Qsc 100!
Dennis and I decided that we wanted a "Beater" type glider that was fairly inexpensive, something like my QSC 32 inch 3 panel poly, but bigger so that it could be winch launched.
!00 inches would work out well. 4 , 24 inch panels plus 2 inch tips would give us 100 inches. Why 24 inch panels? The foam comes in 24 X 96 inch sheets. I decided on AG 24,25,26 airfoils going on what is recommend by the Charles River Radio Controllers web site. And that the wings would have 1/8 X1/2 inch wooden spars. Also the glass would be attached with Minwax Polycrilic rather then vacuum bagging.
The fuse pod would be from 1/8 inch lite ply and the boom was to be a golf club shaft.
The tails are just smaller version of the wings, but have .060 carbon rods for spars. The rudder also has a balsa spar that is the front half of the hinge line.
The V mount is made of aluminum , the first one is of .045, but is serious overkill, next will be redesigned and of .025.
The wing will be 3 piece, with 1/4 inch plate 6061 T6 Aluminum cut into a chevron shape. My 2 Meter has 1/8 inch plates and it can take a full pedal launch, so these should be OK
I've been texting Dennis pictures as progress is made . I'll try posting them here. The are not in any special order And the build sequence may seem a little different, but this is what works for me.
RWCLOUD is offline Find More Posts by RWCLOUD
Build Log QSC 32 inch 3 panel poly with drawings RWCLOUD Hand Launch 91 Nov 25, 2011 04:08 AM
