Old Sep 11, 2012, 09:04 PM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
One more video
Another video. Hard to tell, but I'm putting the wood to it for the first 2 min.
ZephyrEl (3 min 34 sec)
Kevin
kmdunnster is offline Find More Posts by kmdunnster
Old Sep 13, 2012, 07:40 AM
phoxache is offline
Find More Posts by phoxache
.--troll-o-copter--.
phoxache's Avatar
United Kingdom, Warks
Joined Jun 2012
Hi fellas,
I'm about to order a Zephyr. I'm started wading through this thread but I need to hit 'buy' quickly before I come to my senses and realise I don't need another plane!
Could someone tell me:
Which battery should I get that will perform well, balance the CoG without adding extra weights and fit in the fuse without too much hassle?
Is the wings breaking on landing a huge problem as reported in the reviews? Do I need extra skids or something else to combat this?
Thanks again, guys. I will read the thread properly but I want to order before I back out or stock runs out.
phoxache is offline Find More Posts by phoxache
Old Sep 13, 2012, 09:34 AM
phoxache is offline
phoxache's Avatar
Joined Jun 2012
Originally Posted by phoxache View Post
Hi fellas,
I think I'm gonna go with this:
http://www.hobbyking.com/hobbyking/s...idProduct=9953
That sound okay to you guys?
Old Sep 13, 2012, 09:37 AM
jnoel is offline
Find More Posts by jnoel
Thermal Hunter
jnoel's Avatar
United States, PA, Phoenixville
Joined Jan 2005
Here is what I use.....
http://www.hobbyking.com/hobbyking/s...dproduct=24644
jnoel is offline Find More Posts by jnoel
Old Sep 13, 2012, 09:48 AM
phoxache is offline
phoxache's Avatar
Joined Jun 2012
Originally Posted by jnoel View Post
Thanks! Does it fit in the hatch easily enough?
It's out of stock at the moment but the stats and dimensions are still really useful.
Old Sep 13, 2012, 10:34 AM
jnoel is offline
Thermal Hunter
jnoel's Avatar
Joined Jan 2005
Yes on edge.. see post #1260 for pic ...from kmdunnster
I though still added 1.5 to 2.0 oz of lead in the nose for Proper CG
Old Sep 13, 2012, 02:48 PM
phoxache is offline
phoxache's Avatar
Joined Jun 2012
Thanks for your help. Much appreciated!
Old Sep 13, 2012, 06:27 PM
j j is offline
j j
Find More Posts by j j
j j
United States, CA, Santa Clarita
Joined Sep 2012
iam a bout to buy a zephyr do you know anything on what typ of wind can it handle
j j is offline Find More Posts by j j
Old Sep 13, 2012, 06:47 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
It's not a floater, it's fairly fast for what it is. I've flown mine in over 20 kph winds. It could have handled much more.
xviper is online now Find More Posts by xviper
Old Sep 13, 2012, 08:16 PM
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Post #637 I posted back in June still sums up this airplane(I think) for me . I've been using that setup for a few months now with NO extra weight added.100+ flights and still flys like the day I got it
Kevin
Old Sep 13, 2012, 09:31 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
I had mine up once in a 30km breeze. I find it doesnt just bounce about, but gets some un-nerving twisting going on with wings as you bank cross wind coming about. Perhaps because its moving pretty quick. Penetration is not an issue as it will slice through easily upwind, and down wind you have to be careful not to over speed into a wing flutter. I agree with Xviper in that 20km and below is the Zephyr's happy place. Very few of my foamy's can deal with much more than 20km/hr winds anyhow so its not really a failing on the Zephyr's part.
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Sep 13, 2012, 09:48 PM
jnoel is offline
Thermal Hunter
jnoel's Avatar
Joined Jan 2005
Yes In a full power dive heading downwind
I had some of that wing flutter...scared the
out of me . and I'm only using a 3 cell
Old Sep 14, 2012, 08:04 PM
elshemerly is offline
Find More Posts by elshemerly
Joined Dec 2011
Originally Posted by xviper View Post
Balance will depend on the size (mah) of the battery you use (3s, 4s, doesn't matter). The stock recommended battery (3s, 3300 mah) balances the plane perfectly and is already a tight fit. Going higher mah will make it nose heavy.
Search this thread. There's a couple of guys who have routinely run 4s without other mods and seem to do fine and not burn anything out. If you don't go full throttle, you won't overtax the ESC and motor anyway.
I have an X8 wing that runs perfectly on 3s. When I put in 4s batteries, the motor and ESC get extremely hot, so I just don't go full throttle hardly at all when I use 4s on it. You can do the same with the V70. I don't use 4s on it routinely, only when I run out of my 3s batteries at the flying field.
Personally, I've used a 4s, 2650 mah battery in the V70 and I couldn't detect any real difference in the way it performed. It didn't seem to go significantly faster.
thanks a lot for your support
elshemerly is offline Find More Posts by elshemerly
Old Sep 15, 2012, 06:11 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Where do you all set your low voltage cut-off at? I have mine set to high, (3.2v/65%). If I set it lower, can I still do a go-a-round if I need to? Thanks.
av8ersteve is offline Find More Posts by av8ersteve
Old Sep 16, 2012, 06:56 PM
lotsaturbulence is offline
Find More Posts by lotsaturbulence
Northwest Florida, USA
Joined Mar 2012
Zippy Compacts
The Zippy Compacts 3300 and 3700 both fit in very easily but you need the battery adapters to go with them if you don't change plugs. Very nice fit even with the adapters and a Spektrum AR400 rx.....
lotsaturbulence is offline Find More Posts by lotsaturbulence
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 02:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 12:26 PM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 08:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 09:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 02:07 PM
