Old Sep 05, 2012, 06:11 AM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Here are the esc instructions that came with my Zephyr:
av8ersteve is offline Find More Posts by av8ersteve
Old Sep 05, 2012, 06:56 AM
karoliinasalmin is offline
Find More Posts by karoliinasalmin
karoliinasalmin's Avatar
Finland, Espoo
Joined Jan 2012
Originally Posted by brendanpekin View Post
My friend uses a thrust tube which really helps, do you use one?
No I don't. Thrust tube will help a little for high speed. However, since there is enough thrust regardless at 6S, it is indifferent if one is installed because I am hitting a structural limit far sooner. The problem is the flutter tendency of the too flexible airframe.
karoliinasalmin is offline Find More Posts by karoliinasalmin
Old Sep 05, 2012, 06:58 AM
LonelyDragon is offline
Find More Posts by LonelyDragon
Russian Federation, Moscow
Joined Jul 2012
Stock ESC can be programmed with HobbyKing BlueSeries programming card.
LonelyDragon is offline Find More Posts by LonelyDragon
Old Sep 05, 2012, 05:41 PM
starfighter1956 is offline
Find More Posts by starfighter1956
Joined Sep 2012
Originally Posted by jj604 View Post
I added a couple of these on the bottom about where the aileron servos are. Seems to work. About $2 for 10 from HK. They have 3 sizes.
http://www.hobbyking.com/hobbyking/s...idProduct=8702
Are they to be placed under the wings?
starfighter1956 is offline Find More Posts by starfighter1956
Old Sep 05, 2012, 05:46 PM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Yes
hendrnk is online now Find More Posts by hendrnk
Old Sep 05, 2012, 10:08 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
As noted below - yes. They aren't really there as skids (although that is what they do) but as spacers in the case of the Zephyr.
The idea is that you are lifting the big flat surface area of the wing just enough so that it doesn't actually contact the ground when it glides in. The force of friction is the friction coefficient times the contact area. That's why the wings get ripped off even in a reasonably mild bad landing. The turning force of one huge wing surface contacting the ground is more than the little locating pegs and their plastic holder can cope with. If you can minimise the contact area, the force goes way down.
It won't do anything for an impact force though.
John
jj604 is online now Find More Posts by jj604
Old Sep 06, 2012, 01:00 AM
bryont is offline
Find More Posts by bryont
United States, WA, Bellevue
Joined Dec 2006
Thanks Av8ersteve
Thank you for posting the ESC instructions.
Other than setting the Throttle min and max endpoints did you have to change any other settings?
I believe I have read that others have not had to change any other settings.
The manaul does not indicate what the default settings are or it was set for the Zephyr as it came in the box.
bryont is offline Find More Posts by bryont
Old Sep 06, 2012, 05:31 AM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
I don't know what the default setting are, so I did go through and set it up the way I wanted it. Threshold, cutoff, that sort of thing.
Old Sep 09, 2012, 09:56 PM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Yet another video
Hey guys,
A buddy gave me his cheapie 808 Keychain cam. Thought I'd take it up for a spin. I mounted the camara just behind the screw that holds down the top of the motor cowl. Just so happens that it's tilted up a couple degrees.
Zephyr V 70 (4 min 58 sec)
P.S. I could have floated around a lot longer, but that would make a boring video even more boring
V 70 El Dorado Land (0 min 13 sec)
Tried to get some video from the ground with the cam mounted on my visor. Had it down too far on my eyes to block the sun. Most of it out of frame, but you get the idea.
Kevin
kmdunnster is offline Find More Posts by kmdunnster
Old Sep 10, 2012, 09:31 AM
elshemerly is offline
Find More Posts by elshemerly
Joined Dec 2011
dear all i need to ask can i use 4c 3600mAh lipo with the ESC: 55A w/BEC and motor that coming with it ?
elshemerly is offline Find More Posts by elshemerly
Old Sep 10, 2012, 02:14 PM
leifning is offline
Find More Posts by leifning
Norge, Buskerud, Kongsberg
Joined Jul 2010
Most people seem to be very dubious to the stock ESC, and especially on 4S. Its probably best to upgrade it a bit if you want to increase to 4S.
leifning is offline Find More Posts by leifning
Old Sep 10, 2012, 02:40 PM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
My impression is that it's NOT an issue to do with the ESC being able to handle 4s. It's just that 4s will propel the V70 to speeds that compromise the integrity of the wings. It'll start flapping the funky chicken.
xviper is offline Find More Posts by xviper
Old Sep 11, 2012, 09:32 AM
Joined Dec 2011
but i will not got for full throttle but this is to avoid the short fly timing also the tail heavy issue dose adding 4c will burn the ESC and motor
Old Sep 11, 2012, 09:58 AM
xviper is offline
Canada
Joined Jul 2009
Balance will depend on the size (mah) of the battery you use (3s, 4s, doesn't matter). The stock recommended battery (3s, 3300 mah) balances the plane perfectly and is already a tight fit. Going higher mah will make it nose heavy.
Search this thread. There's a couple of guys who have routinely run 4s without other mods and seem to do fine and not burn anything out. If you don't go full throttle, you won't overtax the ESC and motor anyway.
I have an X8 wing that runs perfectly on 3s. When I put in 4s batteries, the motor and ESC get extremely hot, so I just don't go full throttle hardly at all when I use 4s on it. You can do the same with the V70. I don't use 4s on it routinely, only when I run out of my 3s batteries at the flying field.
Personally, I've used a 4s, 2650 mah battery in the V70 and I couldn't detect any real difference in the way it performed. It didn't seem to go significantly faster.
Old Sep 11, 2012, 06:14 PM
pilotonovato is offline
Find More Posts by pilotonovato
Joined Aug 2011
Originally Posted by jim350 View Post
do you have a watt meter or access to one?
at full throttle you should be pulling approx 45A
My watt meter showed 55A at full throttle using a nano tech 65-130C 3300mAh 3s.
Using a 60A plush esc.
It is screaming very loud at the sky!!!!!!
I recommend owners to threadlock the screw on motor`s shaft. Mine came loose.
Sweet!
pilotonovato is offline Find More Posts by pilotonovato
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
