Old Aug 29, 2012, 04:10 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Either Medium CA which is what is in the manual or Gorilla Glue. That's what I'm using, check out previous posts. It works well on EPO if the surfaces are prepped well, the only difference with CA is that GG is not as brittle and more like epoxy (somehow flexible) which I prefer for big/stress areas like wings and tails.
Castel101 is offline Find More Posts by Castel101
Old Aug 29, 2012, 04:37 PM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
Speaking of glue. Has anyone tried the CA with rubber in it? It sounds like the best of all possible worlds if they got it right. I have had good results with both epoxy and Gorilla Glue though I understand that there's some variations in EPO that might cause either one to work better on a specific model. The main thing is surface prep. Clean with rubbing alcohol or other solvent that won't dissolve the foam, sand the surfaces, then clean them again before glueing. It seems to help to make some little holes, so the pieces are "keyed" together, as well.
peterlngh is online now Find More Posts by peterlngh
Old Aug 31, 2012, 12:49 PM
dcame002 is offline
Find More Posts by dcame002
Lipo Burner
dcame002's Avatar
United States, FL, Sunrise
Joined Mar 2012
Finally some good weather this weekend. Looks like a maiden of the 6s zephyr is on the way. The battery is too tall to fit in the canopy, but I'm thinking of cutting out the bottom foam and replacing it with a strip of glass fiber. Pray for good weather guys!
dcame002 is offline Find More Posts by dcame002
Old Aug 31, 2012, 12:55 PM
Joined Apr 2012
FYI. The Zephyr is now available from the U.S. warehouse.
Old Aug 31, 2012, 07:34 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Hey all. My maiden flight is scheduled for tomorrow morning but I have a concern. I am flying with a thunder power g6 3300 and spectrum r600x receiver. I had to add to the nose a 9 volt battery and 3 quarters taped together to get the C.G. at 78mm. Does this sound right? Seems like a lot of extra weight. I am so concerned that I went and purchased a Great Planes CG balancer so I could check it with something other than my fingers. Is adding weight to the noes, (a lot), normal for this bird? PLEASE someone let me know something before I fly.
av8ersteve is offline Find More Posts by av8ersteve
Old Aug 31, 2012, 11:32 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Yes it is normal.
I run a 3s 3600mah battery and it just balances within specs.
jim350 is offline Find More Posts by jim350
Old Sep 01, 2012, 08:04 AM
dugmar is offline
Find More Posts by dugmar
United States, MA, Newburyport
Joined Aug 2011
Just set mine up. Everything seems to be working fine, except for the motor. No reaction to the throttle stick. I have swapped out a different RX and ESC, still have the same problem. Not sure what could be wrong but it seems as if I have a bad motor. Any easy way to rule that out?
dugmar is offline Find More Posts by dugmar
Old Sep 01, 2012, 01:13 PM
GBX is online now
GBX
Find More Posts by GBX
GBX
Illinois
Joined Jan 2005
just for fun hook up the battery and adjust the trim down for the throttle to see if you can get the esc to arm
GBX is online now Find More Posts by GBX
Old Sep 01, 2012, 01:33 PM
Joined Apr 2012
Good suggestion, GBX. And, if that has no effect, try plugging it in with the throttle all the way up. Dugmar might have the throttle reversed. That little pickle cost me a very frustrating afternoon!
Old Sep 01, 2012, 04:09 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Did you calibrate the throttle range by binding it at full throttle, waiting for beeps, then reducing throttle to zero?
Bravo47 is offline Find More Posts by Bravo47
Old Sep 01, 2012, 05:00 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Well, no maiden today due to rain... Tomorrow hopefully. Does anyone know how the stock esc holds up? I Have never flown with one of these but I do like the ease of programming and it looks to be of good quality. Any +'s or -'s you guys know of?
Old Sep 02, 2012, 12:28 PM
banjo328 is offline
Find More Posts by banjo328
banjo328's Avatar
Albuquerque, NM
Joined Jan 2010
I only have maybe an hour's use in the Zephyr but it seems to be working fine. I think it's the same type as used in my Dynamic-S and that one has a lot more usage on it, again with no problems.
banjo328 is offline Find More Posts by banjo328
Old Sep 02, 2012, 12:44 PM
GBX is online now
GBX
GBX
Illinois
Joined Jan 2005
Added some New Stuff Film to my wings and added these to help the bolts from getting caught on landings (from a defunk Kinetic 800) still waitting for a first flight
Old Sep 02, 2012, 01:22 PM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
Good ESc. Will handle 65 amps
Old Sep 02, 2012, 01:45 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
What size New Stuff did you put on the wings?.
hendrnk is offline Find More Posts by hendrnk
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
