Old Aug 22, 2012, 04:41 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Originally Posted by IIIHorseman View Post
Are these available in the U.S. warehouse from hobbyking?
Nah only International so far as far as i can tell
Bravo47 is offline Find More Posts by Bravo47
Old Aug 22, 2012, 06:04 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
My tracking # from Hobby King says its at China Peoples Rep. It's journey to my front door has begun.
av8ersteve is offline Find More Posts by av8ersteve
Old Aug 23, 2012, 04:18 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Heres a little flight from today with a different view on things, and with a little extra added on for fun.
Running 4s 3000mah 20-30c Turnigy that just cant handle the amp draw of the fan. I have the ESC mounted externally as you'll see at the end of the video.
Im happy with its performance and its a hoot to fly even with the 3-4 minute flight times!!!
Enjoy!
HK ZephyrV70 Fun times! (4 min 50 sec)
Teamsherman is offline Find More Posts by Teamsherman
Old Aug 23, 2012, 05:10 AM
R.T.K.F is offline
Find More Posts by R.T.K.F
Return To Kit Form
R.T.K.F's Avatar
Australia, WA, Joondalup
Joined Oct 2010
Dx7 - v70
cool view in ur video TS..
Any of you cats already flying using a DX7..???
Keen to know what settings you have ended up with?
Cheers Brad.
R.T.K.F is offline Find More Posts by R.T.K.F
Old Aug 23, 2012, 01:17 PM
B34N is offline
Find More Posts by B34N
B34N's Avatar
Switzerland, ZH, Zurich
Joined May 2012
Cheers Brad.
I must be the only person on this forum who uses Graupner
B34N is offline Find More Posts by B34N
Old Aug 23, 2012, 02:49 PM
dcame002 is offline
Find More Posts by dcame002
Lipo Burner
dcame002's Avatar
United States, FL, Sunrise
Joined Mar 2012
After a few days vacation in Cancun, I'm finally able to get back to the RC world.....
Changesun 10 blade fan is currently balanced and installed in my zephyr. I was going to run 5s, but there still wasn't enough thrust. I believe it may be due to the intakes......
I am now running a 6s zippy flightmax 2200mah 45c battery. Thrust is much better...... around 1.5 kg. at 1450 watts peak on a full charge, I believe 1200 settled gonna test again later
The sound is amazing. My ears happily ring from the white noise. If i stand the plane up vertically, it begins to take off at full throttle. Fun stuff..
Setup
Zephyr.....
New stuff 5 mil on wings and control surfaces
carbon rod in the ailerons
changesun 70mm 10 blade
turnigy 2100kv motor
80a esc
zippy flightmax 45c
Should fly like a little faster than a stock habu lol
EDIT:
Did some more testing today with the plane hanging on a string..... I'm pulling 1215 watts settled with a 1560 amp peak when I let the battery get a low throttle break. Plane will kinda hover at 2/3 throttle, and takes off at around 3/4. No clue of efflux speed, but I'm only shooting for around 115mph top speed, as any faster the flying field runs out too fast.....The whole purpose of this crazy setup is to have similar vertical performance to a hotliner...PS its hell trying to fit everything. I have to tape up my canopy to keep it closed.
dcame002 is offline Find More Posts by dcame002
Old Aug 23, 2012, 06:04 PM
Member #1
Joined Aug 2011
Cheers Brad.
Cheers Brad!
I think next time I'll do some high speed runs leading into vertical climb with some sweet wing overs with the same view and no ribbon to slow me down!
Old Aug 24, 2012, 01:48 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
I just got this plane. Looks like it's going to be a blast to fly! I've read most of the recommendations here and how it seems a better compromise to use 3S instead of 4S because of possible wing fluttering with increase speed.
My question is, does anybody know how many amps the stock ESC/Motor/Fan pull with 3S and 4S? Is the Motor and ESC up to the task ok with 4S? I read the ESC was a 55Amps one, is that correct?
Thanks!
Castel101 is offline Find More Posts by Castel101
Old Aug 24, 2012, 03:01 PM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
Thanks!
It will definitely handle the power of 4s. You're peaking at 45-50 amps 3s depending on the battery. 4s will pull around 60 If i remember. A few guys here fly on 4s. Just make sure u shift the cg more forward if using 4s (suggestion from scott at HK)
Old Aug 25, 2012, 01:28 AM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
buddy trying he's new toy
Hobbyking Durafly Zephyr V70 EDF Glider (5 min 51 sec)
Westwood is offline Find More Posts by Westwood
Old Aug 25, 2012, 02:41 AM
Aender69 is offline
Find More Posts by Aender69
Grand-Duchy of Luxembourg
Aender69's Avatar
Joined Sep 2005
fuselage lex
Hm, anybody notice fuselage flex, in this case meaning the whole rear boom bending/hanging down?
I noticed the following: I had to add elevator uptrim over the last month just to keep it flying straight. I experienced with adding some ballast up front again, but that didn't change anything.
I suspect the the whole rear of the fuselage is wearing out (after +- fifty flights) and the V-tail begins to have a down-attitude, which need huge amounts of up-elevator to compensate. I had this problem already with another plane : I corrected it by simply bending the tail upwards, and the tendency 'to go down' was gone...
Aender69 is offline Find More Posts by Aender69
Old Aug 25, 2012, 12:58 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Does anyone fly this thing like a glider? How does it thermal, or slope?
Old Aug 25, 2012, 01:42 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
Hey guy's, almost bought this plane but got the Dynamic-S instead. I just got it and built it but never have flown it...Check this out!! www.rcgroups.com/forums/showthread.php?t=1718342 Dave/ZZ
zeezee is offline Find More Posts by zeezee
Old Aug 25, 2012, 02:35 PM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
Still at the field about to go home. Flew my V70 for 2 flights this morning. After a couple low fly-bys, I take it up to about 500 feet and shut the motor off and glide it around till it gets low, then go up and do it again. It's as much fun flown as a glider.
xviper is online now Find More Posts by xviper
Old Aug 25, 2012, 03:23 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Sweeeeeet..... I've been waiting on mine to arive now for over a week. Thats what I've been waiting to hear. I want to quietly glide in the back ground then turn everone's head while I climb back to altitude with them thinking "what the ".....
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
