Old Aug 19, 2012, 08:26 AM
B34N is offline
Find More Posts by B34N
B34N's Avatar
Switzerland, ZH, Zurich
Joined May 2012
Originally Posted by av8ersteve View Post
Do any of you use the Deans type connector? I really like them.
I use the deans type on all of my rc things, just wanted a standard, and I started there. I don't really know the pro's or cons of any of the plug types. And I use the ones readily available from HobbyKing
B34N is offline Find More Posts by B34N
Old Aug 19, 2012, 09:33 AM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Deans Plugs
Yep, that's all I use Supposedly, they have the least resistance of any other plug. Even less than the wire itself
Kev
kmdunnster is offline Find More Posts by kmdunnster
Old Aug 19, 2012, 11:54 AM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Good to hear . I really like the Deans and I'm now going to standardize all my equipment to them.
av8ersteve is offline Find More Posts by av8ersteve
Old Aug 19, 2012, 11:55 AM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
I heard the XT-60 connectors can hold more amps than the deans.
hendrnk is offline Find More Posts by hendrnk
Old Aug 19, 2012, 04:09 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
The main think I like about XT-60 is they can be separated easily whether hot or cold. All the softer plastic connectors tend to get soft and are hard to pull appart when warm.
Bravo47 is offline Find More Posts by Bravo47
Old Aug 20, 2012, 07:15 AM
R.T.K.F is offline
Find More Posts by R.T.K.F
Return To Kit Form
R.T.K.F's Avatar
Australia, WA, Joondalup
Joined Oct 2010
esc programing
Has anyone had an issue with setting the ESC in this thing?
Just set the hi & low point for throttle. Will work fine for a moment, then when u cut the throttle, it wont stop straight away. When it does stop motor beeps and twitches and wont go again..??
R.T.K.F is offline Find More Posts by R.T.K.F
Old Aug 20, 2012, 03:40 PM
Bravo47 is offline
Australia
Joined Jun 2010
Did you accidentally push the throttle trim up beyond the neutral point? If not try backing it down a couple of clicks and recalibrating. Other than that your ESC may have probs?
Mick
Old Aug 20, 2012, 05:52 PM
R.T.K.F is offline
Return To Kit Form
R.T.K.F's Avatar
Joined Oct 2010
Mick
Cheers Mick, I will check that as well.
Had a few trim / travel tips to try tonight...
Brad.
Old Aug 20, 2012, 07:50 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
I ordered my Zephyr from Hobby King on Thursday and their web site now says that it's shipped,. I tried the tracking # but it just takes me to another page that says this " 无查询邮件信息或邮件超过查询期限.". Anyone have any ideas? How long should I expect to wait for delivery? I just cant wait to get my hands on this thing!
Old Aug 20, 2012, 08:04 PM
hendrnk is offline
Joined Apr 2012
It roughly translates to "The no query mail messages or e-mail exceeds the query time limit"
Old Aug 20, 2012, 11:02 PM
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Just cut and paste your tracking# to this link:
https://tools.usps.com/go/TrackConfirmAction_input
You're in North Cakalaki, USPS tracking will work.
Kevin
Old Aug 21, 2012, 04:36 PM
banjo328 is offline
Find More Posts by banjo328
banjo328's Avatar
Albuquerque, NM
Joined Jan 2010
what kmdunnster says will work but don't expect to see anything there until it gets accepted for shipment from Hong Kong. And often it will say that the item has arrived at the NYC sorting center, and then it shows up at your door.
Don't expect less than a 2 week delivery time, as much as 3 weeks in my experience.
banjo328 is offline Find More Posts by banjo328
Old Aug 21, 2012, 08:18 PM
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Crap, I hate waiting but thanks for the info. At least I can read about it for now
Old Aug 22, 2012, 06:16 AM
GavDorro is offline
Find More Posts by GavDorro
Don't Panic!
GavDorro's Avatar
Australia, WA, Baldivis
Joined Jul 2011
My face palm moment !
This happened after major repairs that involved removal of the EDF unit and most of the electronics (this so that I could dunk the Zephyrs nose in boiling water).
Took the Zephyr out for its first flight with upspecced batteries. 2 launches resulted in really apathetic take offs. The Zephyr just would not lift off. I never had this problem with the underspecced batteries....??? It wallowed around near the deck and I had to land within 10 metres of takeoff.
Checking throttle throws, changing the ESC's wiring.....WHAT THE ??
Make my way back home, put it on the bench....
Then it hits me.... I had reassembled the EDF in backwards!!!
GavDorro is offline Find More Posts by GavDorro
Old Aug 22, 2012, 04:26 PM
IIIHorseman is offline
Find More Posts by IIIHorseman
United States, OR, Beaverton
Joined Jul 2012
Are these available in the U.S. warehouse from hobbyking?
IIIHorseman is offline Find More Posts by IIIHorseman
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
