Old Aug 16, 2012, 06:03 PM
GavDorro is offline
Find More Posts by GavDorro
Don't Panic!
GavDorro's Avatar
Australia, WA, Baldivis
Joined Jul 2011
Originally Posted by av8ersteve View Post
What battery have you guys decided on that works best for this thing?
I'm flying these:
http://www.hobbyking.com/hobbyking/s...dProduct=11953
Gives around 8 minutes of solid flying and unlike what the flitetest guys say, they DO fit pretty easy but you do have to think about where things go....
I admit that I have overspecced the C rating to 45/90 but learned the hardway about voltage sag when I got impatient about flying the zep, tried 2200 nanotechs in it and had 2 total brown outs in 2 days. Both resulted in death spirals and extensive repairs....
GavDorro is offline Find More Posts by GavDorro
Old Aug 16, 2012, 06:24 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Originally Posted by Teamsherman View Post
Hi folks,
Just re-maidened the Zeph with a 2200mah 4s and got a flight time of 2 minutes 34seconds before low voltage cutoff kicked in and I wasn't above 2/3rds throttle at any time!
I tested the battery cells voltage and they all came in at 3.8v. Is this low flight time common? I really don't have fun flying something for only 3 minutes! I tried to fit in a 3000mah 4s but it just wouldn't fit in!
Any suggestions on gaining more flight time?
Also, can I lower the voltage cutoff to about 2.75-3.0v per cell? And if so can someone tell me how to do it on the esc?
Cheers,
TS.
I wouldn't go below 3.2V, and never below 3V.
I fit in a 4000 3S battery no problem.
hendrnk is offline Find More Posts by hendrnk
Old Aug 16, 2012, 08:01 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
This aircraft really needs a regular pre-flight inspection like a helicopter or it will burn you. I thought mine was ready to go for this weekend when I noticed one of the AILE horns had come partially unstuck. I re-glued all the horns. Then this morning I was reading about V-Tail differential RUD/ELEV mixing when I noticed a split in my ELEV hinge. Now repaired and taped. Now I cant help staring at my thrust tube wondering whether the whether the extra top end speed is worth the risk of having reduced bottom end thrust for take off after my failed launch during the week. I'm starting to think Hobbyking really did hit the mark with the power plant they went with, in that it doesnt offer any more speed than the wing can handle, whilst still maintaining enough thrust for launch.
I use the rudder very rarely, partly because of the way it wags, but after reading this article I'll like seen if i could programe the RUD>ELEV mix so it would carve into rudder turns like the article report V-Tails can.
Link- http://www.southernsoaringclub.org.z...-Trimming.html
Bravo47 is offline Find More Posts by Bravo47
Old Aug 16, 2012, 08:13 PM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
Hi folks,
Cheers,
TS.
The recommended battery is a 3300+ mah, 3s. You shouldn't expect the same flight time on a 2200. And it's been said that a 4s will take the plane just over the threshold where the wings will start to flutter.
xviper is offline Find More Posts by xviper
Old Aug 16, 2012, 09:02 PM
Baseman is offline
Find More Posts by Baseman
Radian, Polaris, Mistaken ID.
Baseman's Avatar
United States, MO, Lee's Summit
Joined Nov 2010
Originally Posted by Wretcho View Post
I have ~7 planes, I bought this as it was 'different'.
I have had a heap of flights on it, like I said, doesn't float my boat anymore.
Wanna sell it?
Baseman is offline Find More Posts by Baseman
Old Aug 16, 2012, 11:35 PM
Wretcho is offline
Find More Posts by Wretcho
Wretcho's Avatar
Australia, WA, Osborne Park
Joined Jul 2011
Originally Posted by Baseman View Post
Wanna sell it?
already have :P
Wretcho is offline Find More Posts by Wretcho
Old Aug 17, 2012, 12:24 PM
dugmar is offline
Find More Posts by dugmar
United States, MA, Newburyport
Joined Aug 2011
What connector style is on the ESC from the factory?
dugmar is offline Find More Posts by dugmar
Old Aug 17, 2012, 12:28 PM
Mattacks is offline
Find More Posts by Mattacks
Mattacks's Avatar
Joined Aug 2011
Originally Posted by dugmar View Post
what connector style is on the esc from the factory?
xt-60
Mattacks is offline Find More Posts by Mattacks
Old Aug 17, 2012, 12:29 PM
hendrnk is offline
Joined Apr 2012
XT-60.
http://www.hobbyking.com/hobbyking/s...idProduct=9572
Old Aug 17, 2012, 12:45 PM
dugmar is offline
Joined Aug 2011
Originally Posted by hendrnk View Post
Cool, thanks. Batteries arrived before the plane and I just wanted to make sure I didn't need to swap connectors over. Looks like I am good.
Old Aug 18, 2012, 12:11 AM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
how do you all like this bird? been wondering what people thought of it.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Aug 18, 2012, 09:26 AM
GBX is offline
GBX
Find More Posts by GBX
GBX
Illinois
Joined Jan 2005
Picked mine up this week at the post office
The ESC Connector is the lg red type
Shown in the pic below
GBX is offline Find More Posts by GBX
Old Aug 18, 2012, 11:52 AM
hendrnk is offline
Joined Apr 2012
They must have changed it, mine came with the XT-60 connectors.
Old Aug 18, 2012, 04:56 PM
av8ersteve is offline
Find More Posts by av8ersteve
I did it...
av8ersteve's Avatar
Morganton, NC
Joined Jun 2005
Do any of you use the Deans type connector? I really like them.
av8ersteve is offline Find More Posts by av8ersteve
Old Aug 19, 2012, 08:21 AM
GavDorro is offline
Don't Panic!
GavDorro's Avatar
Joined Jul 2011
Like it a lot! Definitely has the speed. Also has a great "punch" through the air - even off the power. Inverted flight is a cinch. The sound it makes is definitely unique.
As I stated before, dont skimp on the batteries. 3300 to 4000 DO fit in the battery compartment with some attention to the layout. I have had to glue the wing on due to the 2 death spirals I experienced when flying batteries too small.....The servos require glueing in AND flight surfaces will at some stage require proper hinging (probably sooner rather than later depending on how agressive you fly).
AND I would definitely buy the ARF version in the future if this one gets beyond repair.
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
