Old Aug 12, 2012, 08:11 PM
dcame002 is offline
Find More Posts by dcame002
Lipo Burner
dcame002's Avatar
United States, FL, Sunrise
Joined Mar 2012
After much cutting and hacking, I got the new fan in.......this is not a very good platform for mods. I ran the new fan up on 5s and I am getting much less watts than expected. Only about 950.... and less thrust that bench testing too... It seems that the blades are restricted by the air intakes. Flight tomorrow....
dcame002 is offline Find More Posts by dcame002
Old Aug 12, 2012, 08:49 PM
peterlngh is offline
Find More Posts by peterlngh
Joined Apr 2012
I wouldn't be surprised if the intakes are a limiting factor, dcame002. A loooooong time ago, when glow powered ducted fans were new, a lot of people tried to model their favorite jet and discovered that the scale intakes resulted in very poor performance. For that matter, it took many years of building full scale jets before the deign of intakes caught up with the engines. This was particularly problematic, with both jets and fans, with split intakes. The interaction of the two streams would cause all sorts of problems; perhaps most famously on the XF-102 prototype (To be fair, there were other aerodynamic issues too.) which simply wouldn't go as fast as it "should have".
It would be interesting to see if blocking off one duct, making sure that whatever you use doesn't get sucked in, would actually increase the static thrust. I seem to recall that one of the early successful A-4 kits only used one functional intake with the smoothest possible duct back to the fan. It's just a thought that's been bouncing around my head.
Either way; have fun with the flying and I hope it's all you expect once it's in the air. The disappointing thrust might not be an issue once it's at flying speed.
peterlngh is offline Find More Posts by peterlngh
Old Aug 12, 2012, 10:43 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Originally Posted by brendanpekin View Post
I am just a bit confused? Is it about edf or is it about performance gliders? Watched a friend fly the v-70 on the weekend, apart from that sound, i'm not convinced. My stinger out of the box goes just as well, and my e-hawk will climb better and then glides! And hardly a performance glider.
Get back to the jet shape for edf I say and as for the pylon racer, too fast for me, whole new senario. Grab a funfighter, I still find my rare bear slippery enough. I have followed this thread from the beginning, 4s wing flutter/low terminal speed disappointment, low wing mount landing issues and cramped canopy space. As well as the usual hk check everything or it might just drop of. Remember 'model of the year'? Not quite. Good luck all
(monday morning ramblings)
Pretty fair appraisal I guess. The V70 is a bit on the heavy side for a glider of its size, but it does have a certain appeal still for me. I've abandoned any 4S ideas I had and have found that simple thrust tube gets the V70 as close to terminal on 3s as is comfortable. I still find it exciting to fly. It hasnt really caused me any serious grief since I modded out the drag the wing off its mounts part which i view as its main flaw.
Mick
Bravo47 is offline Find More Posts by Bravo47
Old Aug 12, 2012, 10:45 PM
Bravo47 is offline
Australia
Joined Jun 2010
Nice one. Will you be doing a slow vertical launch from your hand like my Yak55 does? just kidding and looking forward to hearing about your outcome.
Old Aug 12, 2012, 10:54 PM
ChuckTseeker is online now
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
i too hovered over the button ready to order when the "Slick" video was released but doing a little video work my self there was something not quiet right. So i hung off and i'm glad i did, although this thing looks everything i dreamed of ages ago it has not won me over with what i have read and seen in vids here and it will not be joining my fleet now i'll wait for something a little better
"Idea Of The Year" YES! plane of the year hahaha who are they trying to fool!
cheers chuck
ChuckTseeker is online now Find More Posts by ChuckTseeker
Old Aug 13, 2012, 01:06 AM
jim350 is online now
Find More Posts by jim350
Joined Aug 2011
Hey Chuck, your welcome to come out to A51 and have a look at the zephyr in person.
I have purchased one as i liked the concept. It does sound pretty cool for a stock edf.
jim350 is online now Find More Posts by jim350
Old Aug 13, 2012, 01:09 AM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
I don't think there's enough thrust. It was about 1kg. I'm gonna give it a shot with 6s . I'm thinking that these blades are stalled static because the watts don't increase much between 3/4 and full throttle
Cool sound with the change sun. Even more like a turbine.
Old Aug 14, 2012, 05:07 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Hi folks,
Today while flying my V70 for the second time, it tip stalled again and nosed in. Zero damage, but I'm wondering why it did it? I wasn't exactly flying slowly but I did at the time have aileron/rudder mix and it stalled in a turn as it did the first time. Should I get rid of the mix? Or could it be possible my rudder is moving the wrong way in the mix?
Right aileron comes up, right taileron goes down, left aileron goes down and left taileron comes up.
Teamsherman is offline Find More Posts by Teamsherman
Old Aug 14, 2012, 08:27 AM
Killadan is offline
Find More Posts by Killadan
Fastflydan
Joined Jul 2012
When your right aileron goes up, your left taileron goes up
When your left aileron goes up, your right taileron goes up
Killadan is offline Find More Posts by Killadan
Old Aug 14, 2012, 09:03 AM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
V Tail
If there's any confusion about V Tails, it was explained to me in a way that made sense. I tried using aileron/rudder mix when I first got the Z, but I found it didn't really like it. It does want to pitch down when a lot of rudder is applied(more than most.) I rarely use the rudder on the Z except for knife egdes, or maybe a little on landing if into a crosswind. Make sure you don't over rudder this thing or it will nose over like a Banshee. Obviously, up/down elevator is the same as an X tail. When you look at a V tail from the tail, rotate it 45 degrees(either way, doesn't matter) until one of the V's is vertical. Now move the rudder left/right. The "V", when turned vertical, should move the same way as a normal X tail rudder I.E. left rudder, left tail deflection, right rudder, right tail deflection. If your'e still not sure if it's correct, it should be OPPOSITE of the way the ailerons are traveling.
Kev
kmdunnster is offline Find More Posts by kmdunnster
Old Aug 14, 2012, 09:07 AM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Not sure if you notice but your right rudder / elevator hinge is starting to rip
hendrnk is offline Find More Posts by hendrnk
Old Aug 14, 2012, 09:09 AM
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
That's the reason I had it out this morning is for some hinge repairing
Has lasted over 100+ flights now.
Kev
Old Aug 14, 2012, 09:14 AM
Joined Dec 2007
Cheers Jim one day i'll make a trip down there to meet you guys and have a fly just a long way
cheers chuck
Old Aug 15, 2012, 02:14 AM
Member #1
Joined Aug 2011
Kev
So the fact I had 70% rudder mixed into aileron could be why it nosed over both times in turns?
Old Aug 15, 2012, 09:29 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
70% rudder in your average bank is a lot. Think about how much rudder you use in a turn when it's not mixed in - not very much. This plane has a tendency of being to wag its tail like crazy with even moderate rudder input. Try flying it with no mix and see how little rudder is needed to fly this plane.
xviper is offline Find More Posts by xviper
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
