Canada
Joined Jul 2009
It might depend on the model. EG, my Vampire did that when the CG was as described in the manual. On throttle up, the thing would head for dirt and on throttle down, it would balloon. Putting the battery more forward and moving the CG 10mm to 20mm forward has corrected this. The V-70 is whole other breed, so who knows if that's what causes it.
Non-centerline thrust line obviously causes pitch down with full power if the thrust line is above the centerline. And in Zephyr it is. It is not very severely high thrust line because the diameter of the EDF is smaller than a prop would be in a similar plane (like Multiplex Easystar) so the pitch down is less prominent. Prop planes (full size also) with high thrust line (like amphibians) require a lots of trimming with power changes (which is not desired, it is a control deficiency).
Centerline thrust is the only way to avoid all thrust-line related control deficiencies in the design. The deficiency that the high thrust line causes to the control harmony of the Zephyr is not very severe especially when you know to expect it. |
Australia
Joined Jun 2010
I'll have another look at it next weekend and perhaps tinker with CG. What are your thoughts guys on a vectoring tube on this aircraft, to be used for trimming the thrust angle?
Link- http://www.hobbyking.com/hobbyking/s...dProduct=21152 |
1 - 3 degrees should be enough to cure it. Packing washers under the fan mounting will do. A rearward CG will make the aircraft more pitch (elevator) sensitive and accentuate any thrust line problems. Your Glide is good, so I'd leave the CG alone and work on the Thrust Line to correct Power On problems. BTW with China "quality control" it's unlikely all zephyr aircraft have exactly the same Thrust Lines , so it's worth experimenting
Australia
Joined Jun 2010
Mick |
A few people have already tried this in this thread.. Either that or run 4S at your own risk...and start strengthening all the flight control surfaces. -mike- |
Australia
Joined Jun 2010
![]() Mick |
| Thread Tools | |
| Discussion Battery for the Durafly Dynamic-S from Hobbyking | Lars N | Foamies (Kits) | 20 | Apr 13, 2013 10:08 AM |
| New Product HK Zephyr V70 EDF Glider! SHWEEEET! | dustydonnay | Video Piloting (FPV/RPV) | 33 | Jun 29, 2012 11:26 AM |
| Discussion hobbyking durafly 310 question | Syner01 | Parkflyers | 1 | Jun 24, 2012 07:54 AM |
| Discussion Hobbyking Durafly Telemicro | Firehawk989 | Micro RTF | 5 | May 13, 2012 08:09 AM |
| Help! Replacement prop for HobbyKing Durafly P-51 | pabo1 | Electric Warbirds | 3 | Mar 28, 2012 01:07 PM |
