http://jepe.org/indek.htm <--- very good tutorials here on foam glassing if you're interesting in glassing those foam jets.
Just be careful with your resin. Epoxy doesn't stick to epo very well. I was able to peel off the glass layer on my clouds fly after a few flights using epoxy resin on the glass. The part that I did with bondo resin stuck very weil. Although most would advise against using it It works well for me (stinks like hell). |
Russian Federation, Moscow
Joined Jul 2012
Awesome plane! I love it.
Canada
Joined Jul 2009
Everything going great till I lost contact with the plane. Seems the Spektrum AR500 may have had a brown out. However, it could have been due to the RX and antenna being jammed in the cockpit space so close to the battery and ESC. The signal appeared to come and go near the end and I was able to shut power off just before the crash. Once I got close to the plane, all control surfaces worked as they should. Broke the nose off but it's all repaired now. Wing and wing mounts are fine, didn't budge. Will most likely run the antenna to the outside or ditch the AR500 altogether. Will do a range test before the next flight. Pardon my French near the end.
![]() Got about twice as many flights in now, and still feel the same way.![]() Kev |
Joined Jun 2012
My parcel has been in the UK customs for 2 days now. Last time it came through then in one day. But my last parcel has spent over 2 weeks in customs and I got charged £8.98 in VAT + £13.50 for parcelforce. So whats next??? sssss18 you have done this before, can I have your tracking please.
| Thread Tools | |
| Discussion Battery for the Durafly Dynamic-S from Hobbyking | Lars N | Foamies (Kits) | 20 | Apr 13, 2013 10:08 AM |
| New Product HK Zephyr V70 EDF Glider! SHWEEEET! | dustydonnay | Video Piloting (FPV/RPV) | 33 | Jun 29, 2012 11:26 AM |
| Discussion hobbyking durafly 310 question | Syner01 | Parkflyers | 1 | Jun 24, 2012 07:54 AM |
| Discussion Hobbyking Durafly Telemicro | Firehawk989 | Micro RTF | 5 | May 13, 2012 08:09 AM |
| Help! Replacement prop for HobbyKing Durafly P-51 | pabo1 | Electric Warbirds | 3 | Mar 28, 2012 01:07 PM |
