Old Jul 09, 2012, 11:32 AM
SkyBug is offline
Find More Posts by SkyBug
HUDDINGE, Sweden
Joined Sep 2003
Just back from my first flight with the V70. No surprises, stock set-up:
Black Magic LiPo 4000 mAh/30C (310 gr + 35 gr lead in the nose); 1110 gr AUW, CG ca 80 mm from leading edge. 5 min flight=37% capacity left in the battery.
Good elevator response, a bit sluggish on ailerons (I had 10 mm throw, should be inreased a bit). Easy to fly, landed with spoilerons (+10 mm) in the grass.
Only problem: the motor wouldn´t start, completely dead. I increased the "throw" on throttle channel to +/- 110% in my Futaba T10CG - problem solved!
Only mod: an extra hatch latch (I do not trust the magnets...)
Cheers,
Anders
Huddinge, Sweden
SkyBug is offline Find More Posts by SkyBug
Old Jul 09, 2012, 11:37 AM
dcame002 is offline
Find More Posts by dcame002
Lipo Burner
dcame002's Avatar
United States, FL, Sunrise
Joined Mar 2012
Originally Posted by sss34 View Post
But can it fit in a Matiz-http://www.careos.com/pics/BiblioPHO/net/matiz_2005.jpg
I don't thing so.
U can remove one of the wings when you want to transport. (the one without the servo wires hole). It makes the plane a million times less cumbersome.
Based on what the other guys here experienced, CA is good for everything except the plastic wing mount. That needs a glue that bonds to both materials better.
dcame002 is offline Find More Posts by dcame002
Old Jul 09, 2012, 12:11 PM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
i move the video to page 1 so you don't have to look for it
Westwood is offline Find More Posts by Westwood
Old Jul 09, 2012, 02:35 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
nice piloting there... good job
does it have the tendency to nosedown when you apply throttle?
pavcon is offline Find More Posts by pavcon
Old Jul 09, 2012, 02:39 PM
sss34 is offline
Find More Posts by sss34
Joined Jun 2012
So why it is not recommended to do a dive even Scott did a loop the loop which is practically a dive?
sss34 is offline Find More Posts by sss34
Old Jul 09, 2012, 02:52 PM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
After a certain speed, you may end up with destructive wing flutter. The plane is quite slippery so it doesn't take too much to get up to that speed by diving.
You may also experience blowback of the control surfaces, since they're made of foam. The plane is more for aerobatics and fun than top speed
Old Jul 09, 2012, 03:28 PM
pavcon is offline
Joined Jan 2010
so... ? ? ?
more carbon.. and DIVE...
Old Jul 09, 2012, 03:29 PM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
Originally Posted by pavcon View Post
so... ? ? ?
I'm with u on that one!
Old Jul 09, 2012, 04:05 PM
sss34 is offline
Joined Jun 2012
so... ? ? ?
Yeah great idea can't wait for it!!! but could the fluttering be caused by tensioned wings?? may be if you ease the tension then the wings can bend, therefore no flutter.
Old Jul 09, 2012, 04:42 PM
pavcon is offline
Joined Jan 2010
whos. gonna try??? :P
Old Jul 09, 2012, 05:53 PM
Mattacks is offline
Find More Posts by Mattacks
Mattacks's Avatar
Joined Aug 2011
What about this guys? How about putting in a fish bone pattern of fiber glass or carbon rods into the Zephyr's wings?
This is a pic from the e-flight wiki of the multiplex Blizzard. The fiber glass rods are set down into the wings in pre-molded groves. The rods are on both the top and bottom of the wings. I bet you could cut groves into the Zephyr's wings to install the same type of reinforcement. The pic is originally from David the rc-explorer guy's build log of the multiplex blizzard.
Mattacks is offline Find More Posts by Mattacks
Old Jul 09, 2012, 07:55 PM
Wretcho is offline
Find More Posts by Wretcho
Wretcho's Avatar
Australia, WA, Osborne Park
Joined Jul 2011
That could possibly help as the wing twists, not bends at speed.
Wretcho is offline Find More Posts by Wretcho
Old Jul 09, 2012, 07:58 PM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
So I guess the best solution may be to just glass the wing and call it a day
Old Jul 09, 2012, 09:29 PM
Wretcho is offline
Wretcho's Avatar
Joined Jul 2011
Have tested my thrust on 3s with and without a thrust tube.
Stock 3s: 700grams of thrust.
56mm thrust tube 3s: 820grams of thrust.
Roughly a 15% gain.
It was a very average home made thrust tube and I'm sure better results will come with a better tube but the thrust gain for five minutes of slapping together a tube is evidently there.
Old Jul 09, 2012, 09:36 PM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
How is the sound with and without the tube?
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
