Old Jul 04, 2012, 03:01 AM
Mattacks is offline
Find More Posts by Mattacks
Mattacks's Avatar
Joined Aug 2011
mine showed up yesterday! Only mod I've done was to tape the box right side out. and take a good look at all the parts, mess around with balancing the fan. She sure is purrdy. Hope I get mine up and flying soon. I have a few ideas for mods and whatnot. Theres many great things to do already in the thread.
happy 4th o July!
Mattacks is offline Find More Posts by Mattacks
Old Jul 04, 2012, 09:14 AM
dcame002 is online now
Find More Posts by dcame002
Lipo Burner
dcame002's Avatar
United States, FL, Sunrise
Joined Mar 2012
Hey guys how would you rate rudder performance. I haven't even bothered using mine lol. I may go try some soaring later
dcame002 is online now Find More Posts by dcame002
Old Jul 04, 2012, 10:13 AM
xviper is offline
Find More Posts by xviper
Canada
Joined Jul 2009
I don't use the rudder much but I can wag its tail like a dog waiting for a Milkbone.
xviper is offline Find More Posts by xviper
Old Jul 04, 2012, 01:43 PM
sss34 is offline
Find More Posts by sss34
Joined Jun 2012
So what do you use rate for??????
sss34 is offline Find More Posts by sss34
Old Jul 04, 2012, 02:24 PM
Aender69 is offline
Find More Posts by Aender69
Grand-Duchy of Luxembourg
Aender69's Avatar
Joined Sep 2005
Took off early today, to test out thermal ability.... a bit disappointed, definitely no soarer. Everytime I thought, ah there's a bubble of hot air and tried to turn, I fell out in a spin...
Zephyr performs better at the slope or in slermals. She's too fast for normal thermalling. Maybe it works if you get her over 600 feet, where thermals tend to get bigger, but at that height, she's becoming frightfully small...
Aender69 is offline Find More Posts by Aender69
Old Jul 04, 2012, 03:22 PM
Lipo Burner
dcame002's Avatar
Joined Mar 2012
A little disappointed today.....I was flying and noticed that the plane kept rolling to the left. After checking the plane, the screw mounts came loose. In addition, I lost the plastic piece that the wing pegs go into. Good job hk.
Old Jul 04, 2012, 03:35 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Lesson learned.. it's not hks fault.. you have to check EVERYTHING that's "done for you" by manufacturers.. it's not a lamborghini or a ferrari.. it's mass production
pavcon is offline Find More Posts by pavcon
Old Jul 04, 2012, 03:42 PM
Lipo Burner
dcame002's Avatar
Joined Mar 2012
No lesson learned. I checked everything out of the box. Those screw mounts are in the inside of the foam. One wouldn't expect to have to glue those back in place. The plastic piece is understandable, but these are embedded in the foam.
Yes, hobbyking did advertise this as their Lamborghini or ferarri.
That's also a poor example, comparing cars to hobby planes. You wouldn't expect to have to go back and tighten all of your belts after buying a brand new Volkswagen?
Old Jul 04, 2012, 06:09 PM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
My little piece that the LE of the wings hook into the fuselage came off and lost it the second flight. I had to fabricate one out of birchwood.
Kev
kmdunnster is offline Find More Posts by kmdunnster
Old Jul 04, 2012, 06:23 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
As has been documented throughout this thread alot of items on the zephyr either require glueing or have insufficient glue.
I found that the aileron servo covers, aileron servos are not glued from factory
The plastic part at the front where the wing attaches needs extra glue. Also reinforcing in the area the wing pins attach to the wing is required (i filled with hot glue)
Where the wings bolts connect is not glued in (purely captured in the foam. Rips out after one non perfect landing)
jim350 is offline Find More Posts by jim350
Old Jul 04, 2012, 06:39 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Surely this one is absolutely critical.
Mine fell off just trial fitting the wing. As supplied there was a minimal glue surface between glossy foam and some smooth raised ribs. It is loaded in tension (weakest) not shear. If this comes off in flight under even slight -ve G the wing will detach at the FRONT. Can imagine some pretty exciting separation events at high speed.
I am impressed by the innovation of the Zephyr in general but this is a real design weakness IMO.
jj604 is online now Find More Posts by jj604
Old Jul 04, 2012, 11:40 PM
Lipo Burner
dcame002's Avatar
Joined Mar 2012
Sadly I glued mine and waited a day, and it still fell off. I'm made a replacement from foam and fiberglass. I'm still gonna run screws though the wing. That's the weakest point imo.
The wing area setup really opens up the possibility to use another wing set wisignificant airframe mods. That may ultimately be the easiest way to fix the 4s flutter
Old Jul 05, 2012, 12:13 AM
Mattacks is offline
Mattacks's Avatar
Joined Aug 2011
ya gotta check those glues..
Old Jul 05, 2012, 01:03 AM
peterlngh is online now
Find More Posts by peterlngh
Joined Apr 2012
Has anyone tried running a strip of silk, Sky-Loft, or very thin glass fiber alone the thickest part of the wing? Leading edge? Trailing edge? All of the above? Or, What about covering the whole thing with a low temp covering material? Laminating just about anything should help to damp flutter.
peterlngh is online now Find More Posts by peterlngh
Old Jul 05, 2012, 01:17 AM
Mattacks is offline
Mattacks's Avatar
Joined Aug 2011
Yup, laminating film was mentioned. a few pages back I ordered myself a roll of 5 mil CP laminating film.
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
