Old Jan 07, 2013, 12:47 AM
scott page is offline
Find More Posts by scott page
Left RCG because of Trolls
Joined May 2009
Zephyr actually likes a bit of a breeze better than not. Makes launching easier, and it doesn't mess with it once up to speed. But definitely - always launch into the wind.
If you can program a switch to add 20 - 30% up for launch it's really helps.. then flip it off once the plane is upto speed.
scott page is offline Find More Posts by scott page
Latest blog entry: Making my own tray
Old Jan 07, 2013, 05:49 AM
glenbees is offline
Find More Posts by glenbees
Leeds/Bradford Leeds, Great Britain (UK)
Joined Jun 2003
Bit of a slope behind our house so i think i will try that, Thanks
glenbees is offline Find More Posts by glenbees
Old Jan 07, 2013, 06:16 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
It loves a bungie launch ramp as well.
Throttle up as it leaves the end of the ramp.
jj604 is online now Find More Posts by jj604
Old Jan 08, 2013, 12:23 PM
Joined May 2009
Would you be able to post photos of this ramp? I'm not sure what my minds eye imagines is anything like what you are doing.
Old Jan 08, 2013, 01:18 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Sure. Will try and find some time later today or tomorrow to do some pix.
Old Jan 09, 2013, 07:30 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Launch ramp for Zephyr
OK here you go. Sorry they are just pix taken at the side of the house but you will get the idea.
It is based on the many ramp ideas around but I wanted one that:
1) Was as compact as possible to go in the car.
2) I could fly from at the club if necessary without having to be on the runway to launch.
So I eliminated the big release board you normally push with your foot and replaced it with a servo operated catch made from a door hinge. I just bound a second cheap Orange Rx to my DX8 and plugged the servo into the gear channel.
Whole thing is on a small board anchored to the ground with two plastic tent pegs.
The bungie is HobbyKing blue bungie plus about 3x the length of 30lb fishing line. Anchored into the ground with a doggie training stake. The bungie ring hooks over the metal catch bolted to the door hinge with a 1m (3ft) length of extension line to a second ring that hooks on a towhook made from a HK wing skid. A skid on each wing near the servo plus the tow hook keep the whole thing a bit off the ground at touchdown and seems to help with the wing mount destroying twist you can get if one wing hits flat on. I started off with a long bungie but am about to try it with 3.5 m (yards) of rubber and 15 m of line which I think will be fine and quicker to set up.
The ramp itself is the usual plumbing pipe and push fits together at the field.
Takes about 30 sec to assemble and a bit longer to lay out and tension the bungie.
Check everything works, spool up enough to make sure the fan is running and reduce any throttle lag at launch but not move the plane and hit the retract switch. Launches smoothly and with authority and I throttle up to full power after it leaves the ramp.
If I can fly off one of these things, anyone can.
Only change I am going to make is drill a single hole for one tent peg so you can rotate the release mechanism easily into the wind if the direction shifts.
Old Jan 10, 2013, 01:03 PM
Joined May 2009
So If I understand this crude drawing is how this all is hooked up??
Old Jan 10, 2013, 03:33 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Scott that would work but I prefer to have the release up near the plane where I can adjust everything. Mine's set up like this.
John
Old Jan 10, 2013, 07:18 PM
Joined May 2009
John
O cool. Awesome. I've a little project to do. Thanks.
Old Jan 11, 2013, 09:48 AM
Disarray is offline
Find More Posts by Disarray
Disarray's Avatar
United States, GA, Gray
Joined Apr 2007
How is the slow speed performance? With the 4000 mah battery and crusing in a racetrack pattern at a slow speed, no thermals or gliding, what kind of flight time could I expect?
A buddy and I fly in formation with pusher wings right now but we are getting tons of prop strikes. We are usually 10' off the deck and fly as slow as we can. Thinking a ducted fan would cut down on the prop strikes. Does this plane sound like it might fit the bill?
Disarray is offline Find More Posts by Disarray
Old Jan 11, 2013, 09:55 AM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
I wouldn't think this would be suitable. Long low wings, delay in spool up with the fan propulsion.
hendrnk is online now Find More Posts by hendrnk
Old Jan 11, 2013, 03:41 PM
Joined May 2009
I did a touch and go about 80mph once, actually just drug a wingtip for about 20' right in front of me and crapped my pants.
But slow flight -- this is NOT the animal.
Old Jan 11, 2013, 06:55 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Scott if you want to make a ramp here's a little table I made up for designing the launch angle. Mine is about 7 degrees.
For a particular desired angle in the first column you multiply the length of the ramp by the factor to give you how much higher the front uprights have to be than the back ones.
For example for a 10 degree angle if your ramp was 4 feet long the front legs need to be 4 x 0.17 =0.68 ft = 8inches longer than the back ones
5..........0.09
7.5.......0.13
10........0.17
12.5.....0.22
15........0.26
John
Old Jan 12, 2013, 12:42 AM
Joined May 2009
5..........0.09
7.5.......0.13
10........0.17
12.5.....0.22
15........0.26
John
Thanks. Awesome.
Old Jan 13, 2013, 11:01 AM
bmclaughlin is offline
Find More Posts by bmclaughlin
Crash Specialist
bmclaughlin's Avatar
Near Dallas
Joined Mar 2009
Thanks for the idea and pics.
I've got one about to maiden..... as soon as travel and crappy weather allow me a day to get out.....
Never bungeed anything before. How far do you stretch the darn thing??
bmclaughlin is offline Find More Posts by bmclaughlin
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
