Old Oct 01, 2012, 07:48 AM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Originally Posted by aneikei View Post
I picked the V70 because of all the online perform reviews are its speed, balance and agility. I guess I got sucked into the hype. So whats the verdict. The X8 or the Bixler 2?
You could also think of a Skywalker either 168cm or 190cm version. One will carry more slower and the other less but faster. Mine is been built with 2 hour endurance in mind with the 190cm wingspan.
hendrnk is offline Find More Posts by hendrnk
Old Oct 01, 2012, 09:09 AM
xviper is online now
Find More Posts by xviper
Canada
Joined Jul 2009
What do you want to carry? How heavy? I have both and the X8 can carry a lot of stuff and not even notice. It'll carry GPS gear, motorized pan/tilt camera gear, fly with FPV gear and 20,000+ mah worth of batteries. The Bix 2 will also carry stuff but everything is proportional. It'll take a Go Pro, FPV gear if kept light and simple. Anything more, and the X8 will out distance and out time it. One is rather pricey and the other is rather cheap (Bix 2).
The X8 has been used as a pack mule. It is very well re-enforced with CF rods. It is a dense foam, extremely rigid and has an enormous interior cargo space.
The Bix 2 is a much better glider and has much better "hang time" with little power use. It is quite manouverable and agile because it's a conventional wing/tail design. However, it is a soft foam, won't carry nearly as much gear and if you load it up to as much as it will carry, it will have a higher sink rate and use more power. It doesn't look nearly as "cool" as a giant flying wing.
xviper is online now Find More Posts by xviper
Old Oct 01, 2012, 03:21 PM
Bravo47 is offline
Find More Posts by Bravo47
Australia
Joined Jun 2010
Hobbyking also do something like the X8 called "Darkwing"
Bravo47 is offline Find More Posts by Bravo47
Old Oct 04, 2012, 02:12 PM
phoxache is offline
Find More Posts by phoxache
.--troll-o-copter--.
phoxache's Avatar
United Kingdom, Warks
Joined Jun 2012
Had one of the control horns come off the v-tail on my second flight with the Zephyr. Check em properly before you maiden or you may end up in a tree.
phoxache is offline Find More Posts by phoxache
Old Oct 05, 2012, 01:42 AM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
Seriously ... that would suck. On foamy's I generally hit all of my horns with welder adhesive before their first flight. I learned this from the school of hard knocks. Welder is pretty interesting stuff -- I like it because it's lighter than many other adhesives, and works well on many foams.
scott page is offline Find More Posts by scott page
Old Oct 05, 2012, 02:00 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Check the hinges as well. One of my tailplane ones was molded too thin and was about to give way along 90% of its length. Looked OK unless you inspected it carefully. Caught it just in time. Adding hinge tape to all the molded hinges before committing aviation is good insurance.
jj604 is online now Find More Posts by jj604
Old Oct 05, 2012, 03:16 AM
phoxache is offline
phoxache's Avatar
Joined Jun 2012
Thanks guys. I'm going to do both of these things before it flies again. It went into a horrible death spiral. I was lucky the tree caught it. Both myself and a nearby dog walker needed a change of pants.
Old Oct 05, 2012, 05:21 AM
Bravo47 is offline
Australia
Joined Jun 2010
When its all patched up, crank it out to full throttle before sending it skyward before rolling over into a full throttle diving pass and rein it in as the flutter evolves Its fun and quite predictable. Last weekend I had a friends GPS logger riding shotgun on my Zephyr's left wing. Top speed was 83mph. Flutter, reliably comes into play anywhere above 80mph. This is when I back off a little throttle and start to climb out for another pass. Strangely enough my Dynamic-S achieved only a few km/h less with power off vertical dives without any flutter issues, and my Vampire which I thought was quicker than the Zephyr came in with the same speeds as the Zephyr. The noise that the Zephyr and Vampire create makes them seam faster than they actually are, and the Dynamic-S passes with just a cool whistle i'm loving all three ATM
Old Oct 07, 2012, 02:01 PM
dcame002 is offline
Find More Posts by dcame002
Lipo Burner
dcame002's Avatar
United States, FL, Sunrise
Joined Mar 2012
My zephyr has been shelved for a few months but I finally got back to messing around with it. A 2200mah 45c 6s wouldn't completely fit so.....I made it fit. This air frame has a 2100kv turnigy motor and a change sun 10 blade. I laminated wings and added cf rods to the ailerons. Hopefully i dont get so much flutter anymore. Looking for punchy acceleration rather than top speed. Currently static tested at 1450 watts.
dcame002 is offline Find More Posts by dcame002
Old Oct 08, 2012, 01:48 PM
kmdunnster is offline
Find More Posts by kmdunnster
Unregistered User
kmdunnster's Avatar
Long Beach, CA
Joined Mar 2010
Originally Posted by dcame002 View Post
A 2200mah 45c 6s wouldn't completely fit so.....I made it fit. Currently static tested at 1450 watts.
I like the way you think 1450 watts, that'll get it moving.
Kevin
kmdunnster is offline Find More Posts by kmdunnster
Old Oct 09, 2012, 03:26 PM
phoxache is offline
phoxache's Avatar
Joined Jun 2012
Did anyone else notice that on the packaging for the zephyr, the recommended battery was actually a sticker saying 3500 - 4000 mah?
I peeled it off and it originally said this:
That'd fit in better. My 4000mah are a slag to get in there.
Old Oct 11, 2012, 01:38 AM
GavDorro is offline
Find More Posts by GavDorro
Don't Panic!
GavDorro's Avatar
Australia, WA, Baldivis
Joined Jul 2011
2800 at 25C would be sailing very close to complete "power outages".
See my previous posts re 2200 25C nanotechs. 2 flights resulted in complete loss of power, loss of control, death spirals and extensive repairs.
Low mAH, low C definitely NOT recommended!!
GavDorro is offline Find More Posts by GavDorro
Old Oct 11, 2012, 02:21 PM
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
Joined May 2009
Agree completely -- and also realize that some companies really stretch their C claims.
I'm using Haiyin 40C 2200 maH and could not be happier. I was a nanotech and gens ace fan until I started using Haiyin -- have not looked back.
Old Oct 11, 2012, 02:25 PM
dcame002 is offline
Lipo Burner
dcame002's Avatar
Joined Mar 2012
Amen to that. I usually try to use at least 40c for any of my packs except for my gens ace ones.
Old Oct 11, 2012, 09:30 PM
Bravo47 is offline
Australia
Joined Jun 2010
I often run a 2800mah 30c Zippy without any issue so far. I think battery choice varies so much for different pilots flying styles. If you fly the Zephyr flat out constantly like an EDF jet then you need a higher battery spec, but if you just power up to gain altitude as in glider flight you can get away with a much lower battery spec.
Mick
Discussion Battery for the Durafly Dynamic-S from Hobbyking Lars N Foamies (Kits) 22 Oct 10, 2013 01:13 AM
New Product HK Zephyr V70 EDF Glider! SHWEEEET! dustydonnay FPV Talk 33 Jun 29, 2012 11:26 AM
Discussion hobbyking durafly 310 question Syner01 Parkflyers 1 Jun 24, 2012 07:54 AM
Discussion Hobbyking Durafly Telemicro Firehawk989 Micro Ready-to-Fly 5 May 13, 2012 08:09 AM
Help! Replacement prop for HobbyKing Durafly P-51 pabo1 Electric Warbirds 3 Mar 28, 2012 01:07 PM
