Old Nov 07, 2003, 11:35 PM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
Rudder servo
The rudder servo (all the servos) is glued in with hot melt glue. For the push rod I used .080 carbon fiber rod. On one end I made a Z bend out of .032 wire and on the servo end I just used a straight piece of wire held in place just like the slave struts. I used an ez connector on the servo to make adjustments easy.
jpflyer is offline Find More Posts by jpflyer
Old Nov 07, 2003, 11:37 PM
jpflyer is offline
Joined Oct 2001
elevator servo
The elevator servo gets the same treatment as the rudder servo.
Old Nov 07, 2003, 11:38 PM
jpflyer is offline
Joined Oct 2001
Tail skid
The tail skid is a piece of .032 wire bent to shape and glued in.
Old Nov 07, 2003, 11:41 PM
jpflyer is offline
Joined Oct 2001
finished pic
Here is a pic of the finished model. Test flight went fantastic with no trim changes. I used a 3 cell etec 250 for light weight and great power. The gym has a fairly low ceiling but I was able to do some rolls and managed a decent hover. I am working on indoor torque rolls, but the ulty will do them.
Old Nov 07, 2003, 11:48 PM
jpflyer is offline
Joined Oct 2001
one more pic
Here is the last pic, I promise. This is best of all the indoor aerobats I've tried. I really enjoy flying it indoors. I can fly as slow as the Tiger Moths and make inverted patterns with them. Yet, it is still fully aerobatic. Don't take my word for it, build one for yourself. Thanks Tim for the inspiration.
jpflyer
The last pic is too big and its too late to work on it. Maybe tomorrow.
Old Nov 10, 2003, 08:45 PM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
Absolutley fabulous! This just totally rocks! Isn't this the best? Doing 3D on inexpensive equipment that almost anyone can use.
Don't cha just love it? More!
willin is offline Find More Posts by willin
Old Nov 12, 2003, 10:28 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Re: equipment
Originally posted by jpflyer
I used an IPS single A drive with a 10x4.7 prop, 2amp esc, and pico servos. My AUW was 5.9 oz. The landing gear is bent from .047 wire with Dubro 1 1/4 foamie wheel and tires.
May be try an IPSD to be 3D and get great vertical climb!
GWS4CEO is offline Find More Posts by GWS4CEO
Old Nov 12, 2003, 10:57 AM
jpflyer is offline
Joined Oct 2001
dual drives
I've tried the IPSD 4.8 volt A geared drive with 2 cell lipoly. Tons of power but the single works well on 3 cells. I know motor life is an issue, but you save about 20 grams over the dual drive in weight.
One other note now that I've gotten some time on it. I went back and used hot melt glue on the foam to foam joints. The CA seemed to flimsy. I probably will only use it for field repairs in the future.
jpflyer
Old Nov 12, 2003, 12:06 PM
Happy|Harry is offline
Find More Posts by Happy|Harry
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
for gluing foam try UHU-Por which is the best glue for depron etc
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Nov 12, 2003, 07:43 PM
dlesnick is offline
Find More Posts by dlesnick
United States, IA, Des Moines
Joined Apr 2003
Does anyone have a single sheet pdf of the plans? I have access to a large format DesignJet and would like to print on it instead of putting together abunch of tiled pages.
Dru
dlesnick is offline Find More Posts by dlesnick
Old Nov 14, 2003, 08:25 PM
bmizes is offline
Find More Posts by bmizes
U.City Flyer
bmizes's Avatar
St. Louis, MO
Joined Oct 2002
JPFlyer, can you show a closeup pic of how you attached the landing gear wire to the bipe. It looks like you used a plywood sheet on either side of the fuse for added strength. How did you attach the wire to this securely?
Thanks.
Barry
bmizes is offline Find More Posts by bmizes
Old Nov 14, 2003, 10:44 PM
jpflyer is offline
Joined Oct 2001
flight shots
Did the indoor thing tonight and got some flying shots. I will try to post them soon.
bmizes
I attached a pic but it may be too small for detail. I used a small rectangle of 1/32 ply on each side of the fuse. There are two small holes drilled at the top about 1/8 on an inch apart. At the bottom is one large hole about 1/8 in diameter. I bend a 90 degree bend at the top of the gear long enough to just come out the other side of the plywood when mounted on the fuse. Mount one on each side. Then I use a small nylon zip tie and loop it through the bottom hole around both gear legs and zip it tight. If I want to fly without gear I just cut the zip tie.
jpflyer
Old Nov 15, 2003, 09:52 AM
jpflyer is offline
Joined Oct 2001
flying pics
Here are some pics from last night. This Ulty sure likes to hover.
Old Nov 15, 2003, 10:07 AM
jpflyer is offline
Joined Oct 2001
one more hover pic
Here is one more hover pic. Did I mention I REALLY like this little Ulty.
Old Nov 15, 2003, 05:44 PM
Aberdeen, Scotland
Joined Jul 2003
nice pics jp , i'm still trying to find an indoor venue
phil
SAAB 39 Gripen for minifan Build Thread nborin Electric Ducted Fan Jet Talk 47 Nov 15, 2007 04:23 AM
Looking for a vip build thread? jaycey High Performance 5 Nov 23, 2004 09:00 PM
3D Foam Ultimate w/ IPS Drive helipilot 3D Flying 6 Apr 28, 2004 12:25 PM
Photos of 90% Ultimate for IPS Dual Salto Foamies (Kits) 13 Feb 10, 2004 06:35 PM
Indoor homebuilt heli. for IPS Gonflyin01 Electric Heli Talk 2 May 11, 2002 08:33 AM
