Old Oct 29, 2003, 07:58 AM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
More
Didn't get much done, but here's where I'm at. I added the reinforcing tape as per the plans to the wings. I cut the control surfaces free and beveled them. Then I taped them back on as per the plans again, except for the rudder. I double beveled the rudder and used CA hinges. They worked really well.
jpflyer is offline Find More Posts by jpflyer
Old Oct 29, 2003, 08:00 AM
jpflyer is offline
Joined Oct 2001
assembly
I began to glue the pieces together. I used foam safe CA. I usually use hot glue, but I think the CA is lighter. I start with centering the bottom wing and squaring it up with the fuse.
Old Oct 29, 2003, 08:03 AM
jpflyer is offline
Joined Oct 2001
more
Add the interplane struts. Next glue on the top wing. Now glue in the horizontal stab making sure it square to the fuse and wing. Once it's in you can glue the rudder hinges in.
Old Oct 31, 2003, 04:00 AM
Blazin_Jason is offline
Find More Posts by Blazin_Jason
Blazin_Jason's Avatar
Canada, BC, Nanaimo
Joined Jul 2002
jpflyer - Is the tape that you are using about 2" thick by any chance and like packing tape? Plane looks great BTW! Thanks
Jason
Blazin_Jason is offline Find More Posts by Blazin_Jason
Old Oct 31, 2003, 07:08 AM
jpflyer is offline
Joined Oct 2001
tape
Yep, that sound like the right tape. I got mine from fast-pak.com. Eight rolls, one of each color, shipped for about $21.00. It is really colorful stuff.
jpflyer
Old Oct 31, 2003, 10:28 AM
Tommy632 is offline
Find More Posts by Tommy632
Mayor of Simpleton
Tommy632's Avatar
Cleveland, OH, USA
Joined Oct 2002
JP, could you post a link to that fast-pak.com? Not finding it for some reason.
Tommy
Tommy632 is offline Find More Posts by Tommy632
Old Oct 31, 2003, 12:03 PM
jpflyer is offline
Joined Oct 2001
link
I guess I should proofread before I hit send. lol
http://www.fast-pack.com/colored_tape.html
That should get you there.
jpflyer
Old Oct 31, 2003, 12:18 PM
Tommy632 is offline
Mayor of Simpleton
Tommy632's Avatar
Cleveland, OH, USA
Joined Oct 2002
Thanks!!
Old Nov 01, 2003, 04:42 PM
fishdeth is offline
Find More Posts by fishdeth
Team Broke
fishdeth's Avatar
Orlando/ Winter Garden, FL
Joined Feb 2003
JP,
gotta say, I LOVE the color scheme !
Nice work,
Jim
fishdeth is offline Find More Posts by fishdeth
Old Nov 01, 2003, 10:58 PM
jpflyer is offline
Joined Oct 2001
color
That's where I had seen those colors before! lol
jpflyer
Old Nov 02, 2003, 10:31 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Originally posted by Happy|Harry
does anyone know of an online source for the .007x.25 CF strips?
phil
http://www.acp-composites.com/
hoppy
hoppy is offline Find More Posts by hoppy
Old Nov 07, 2003, 11:23 PM
jpflyer is offline
Joined Oct 2001
more building
Sorry to take so long to finish the bipe, work etc. I finished installing all the equipment and got in a few flights today at our indoor fly-in. Here is a pic of the equipment install.
Old Nov 07, 2003, 11:26 PM
jpflyer is offline
Joined Oct 2001
equipment
I used an IPS single A drive with a 10x4.7 prop, 2amp esc, and pico servos. My AUW was 5.9 oz. The landing gear is bent from .047 wire with Dubro 1 1/4 foamie wheel and tires.
Old Nov 07, 2003, 11:28 PM
jpflyer is offline
Joined Oct 2001
Aileron servo
I mounted the aileron servo upside down. I used ez connectors and .032 wire to the control horns. This is very light and works very well.
Old Nov 07, 2003, 11:31 PM
jpflyer is offline
Joined Oct 2001
slave struts
The slave struts between the upper and lower ailerons are made from .080 carbon fiber rod with .032 wire z bends on the ends. I use heatshrink tubing to hold it all together and get everything lined up. Then a drop of ca and everything is locked in place. I used 1/32 ply to make the horns for the struts.
SAAB 39 Gripen for minifan Build Thread nborin Electric Ducted Fan Jet Talk 47 Nov 15, 2007 04:23 AM
Looking for a vip build thread? jaycey High Performance 5 Nov 23, 2004 09:00 PM
3D Foam Ultimate w/ IPS Drive helipilot 3D Flying 6 Apr 28, 2004 12:25 PM
Photos of 90% Ultimate for IPS Dual Salto Foamies (Kits) 13 Feb 10, 2004 06:35 PM
Indoor homebuilt heli. for IPS Gonflyin01 Electric Heli Talk 2 May 11, 2002 08:33 AM
