Old Dec 29, 2003, 10:50 PM
Tim H. is offline
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
Man, I've been so busy with all the other stuff going on that I realized I've completely ignored this thread???? You guys sure have done a great job with these little UB's. Heck, I may just have to build one...
Tim H.
Tim H. is offline Find More Posts by Tim H.
Old Dec 29, 2003, 10:53 PM
nr5a is offline
Find More Posts by nr5a
Box Elder, SD
Joined May 2002
Nice lookin bipe jpflier. Can you give me any details on the landing gear? I fly off pavement and grass both. Love doing touch -n-goes. Looks like I won't be able to maiden mine till Wed, darn winds.
4.8v duel A drive
2cell 700 li poly
pico bb servos
castle creation esc
weight without batts 6.6oz
CrashinJ
nr5a is offline Find More Posts by nr5a
Old Dec 29, 2003, 11:03 PM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
Landing gear
I will try to get some pics later, but I will try to explain. I use 1/32 plywood epoxied on each side of the fuse. At the top of the ply I drill two holes about 1/8 apart the diameter of the wire I am using for the gear. Towards the bottom of the plywood I drill a larger hole 1/8 to 3/16 depending on wire size again. There is a 90 degree bend in the top of wire landing gear that slides into the upper holes allowing the gear to fit flush with the side of the fuse. One gear from each side of the fuse. Then I loop a small nylon tie around both gear legs and through the hole and zip them tip. It's light strong and easy.
Larry Cox
jpflyer
Pro Bro #67
jpflyer is offline Find More Posts by jpflyer
Old Dec 31, 2003, 08:25 AM
Betired is offline
Find More Posts by Betired
Woodstock, Ontario, Canada
Joined Nov 2003
GWS 4.8 A DRIVE
you can get more power and longer life by re-soldering the motor (RLC 4.8V) to series. you then have a 9.6 volt motor. put heat sinks on it and use a 3 cell li-poly 700 mah. with throtle management you should have no problems and lots of power
Betired is offline Find More Posts by Betired
Old Dec 31, 2003, 08:30 AM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Both motors would see the same current but voltage would be based on the motors impedance - right?
Same power produced?
This is confusing
poobs is offline Find More Posts by poobs
Old Dec 31, 2003, 01:49 PM
Manchild is offline
Find More Posts by Manchild
Manchild's Avatar
Seattle, Washington
Joined Sep 2002
Nippy 0808 and Timing Advance
Jpflyer,
What did you set the Electronic Timing Advance on the Nippy 0808 setup? High advance, Standard Advance (default), or Low advance? I'm guessing Low advance is out since that gives least power. Thanks.
Manchild is offline Find More Posts by Manchild
Old Dec 31, 2003, 03:03 PM
jpflyer is offline
Joined Oct 2001
CC10
We used the default settings for everything except LVC was set to 7.2 for 3 cells.
Old Dec 31, 2003, 09:11 PM
nr5a is offline
Box Elder, SD
Joined May 2002
Maiden Flight - News at 10
Maidened my UB this morning and it flew great! Ok, I lied, I didn't fly it for this picture, but my buddy SDan did. I can't do 3D yet, so why did I build it, to learn silly! I got a lil stick time tho. Completly different from the Tiger Moth I'm use to flyin. Here is a shot of her this morning.
CrashinJ
Old Dec 31, 2003, 09:19 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Nice!!!!
Old Jan 18, 2004, 10:24 PM
jsc is offline
jsc
Find More Posts by jsc
jsc
Where does it all end?
Boise/Nampa Idaho
Joined May 2000
Hey Guys, I have mine built, and trying to decide on how to power it. I have a IPS-D A 7.2v and 2cells etec 700's, but I am thinking of powering it with a IPS "c" and possibly 3x340kokams. I built it out of 6mil for fuse and 3 mil everywhere else, 3 hs-55's. I want a setup for good hovering but slow enough for small gym flying. Anyone got any opinions? Thanks in advance.
Jeff
jsc is offline Find More Posts by jsc
Old Jan 19, 2004, 09:18 AM
bmizes is offline
Find More Posts by bmizes
U.City Flyer
bmizes's Avatar
St. Louis, MO
Joined Oct 2002
I powered mine initially with an IPS A, but have switched to the 50 cent, Johnson 250 motor from Allelectronics.com in a GWS C gearbox with an 11 x 4.7 prop. If you want lots of power at an unbelievably low price, this is the only way to go.
Barry
bmizes is offline Find More Posts by bmizes
Old Jan 19, 2004, 10:38 AM
dlesnick is offline
Find More Posts by dlesnick
United States, IA, Des Moines
Joined Apr 2003
bmizes,
Is that the GWS EPS-100C gearbox?
How does the weight compare to the IPS drive and what kind of prop and amp draw are yo seeing?
Dru
dlesnick is offline Find More Posts by dlesnick
Old Jan 21, 2004, 03:55 PM
FlyBoyKB is offline
Find More Posts by FlyBoyKB
FlyBoyKB's Avatar
USA, OH, Cincinnati
Joined Dec 2003
Originally posted by bmizes
... switched to the 50 cent, Johnson 250 motor from Allelectronics.com in a GWS C gearbox with an 11 x 4.7 prop. If you want lots of power at an unbelievably low price, this is the only way to go.
bmizes - This sounds real interesting...
Do you have weights and mounting info? How about some pictures and flight reports?
kb
FlyBoyKB is offline Find More Posts by FlyBoyKB
SAAB 39 Gripen for minifan Build Thread nborin Electric Ducted Fan Jet Talk 47 Nov 15, 2007 04:23 AM
Looking for a vip build thread? jaycey High Performance 5 Nov 23, 2004 09:00 PM
3D Foam Ultimate w/ IPS Drive helipilot 3D Flying 6 Apr 28, 2004 12:25 PM
Photos of 90% Ultimate for IPS Dual Salto Foamies (Kits) 13 Feb 10, 2004 06:35 PM
Indoor homebuilt heli. for IPS Gonflyin01 Electric Heli Talk 2 May 11, 2002 08:33 AM
