Old Oct 28, 2003, 11:51 AM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
Indoor foam Ultimate for IPS build thread
I started with Tim H's plans and shrunk them down to a 23 inch wingspan Ultimate for flying indoors (one basketball court sized gym) using GWS IPS systems. It flew so well several of the local guys also built them. There has been some requests for more detail here on THE ZONE so I thought I would document the lastest one I am building. I started by making templates for the cut foam parts.
jpflyer is offline Find More Posts by jpflyer
Old Oct 28, 2003, 11:55 AM
jpflyer is offline
Joined Oct 2001
Wing differences
While it flew fairly well with the stock wing, it was a little quick for some of the newbies to indoor flying. So, I added one inch to the chord at the leading edge and 1/4 inch to the ailerons. This lowered the wingloading down to Tiger Moth speed and really helped the newbies. I liked it so much that is all I build now. The wing in the photo on the bottom is stock and the one on top is the wider chord.
Old Oct 28, 2003, 11:59 AM
jpflyer is offline
Joined Oct 2001
Foam Parts
Here are the cut foam parts. The fuse and rudder are cut from 6mm depron and the rest is 3mm depron that I got at DepronUSA. The top wing has the cut out for the cabane strut in the center while the lower wing does not.
Old Oct 28, 2003, 12:03 PM
jpflyer is offline
Joined Oct 2001
Fuse stiffner
This picture shows the carbon fiber I use to stiffen the fuse. I use .014 thick by 6mm piece of flat carbon fiber. I had this in a box of carbon fiber and am not sure where I got it. I think most of composite folks probably carry it. The carbon fiber is just laying on the fuse at this point.
Old Oct 28, 2003, 12:07 PM
jpflyer is offline
Joined Oct 2001
Installing fuse stiffner
I cut the fuse in half longways to install the CF. It goes from the front along the motor mount stick back to the tail. You could probably use a CF tube like the big Ultimate, but I think this is lighter. I glue it in using foam safe CA, making sure the fuse is straight with no twists or warps.
Old Oct 28, 2003, 12:10 PM
jpflyer is offline
Joined Oct 2001
Fuse together
Here is a pic of the fuse glued together. I also installed the motor stick. You can add in some right thrust at this time. I line up the back end of the stick with the left side of the fuse and at the front I line the stick up with the right side. This provides plenty of right thrust.
Old Oct 28, 2003, 12:15 PM
jpflyer is offline
Joined Oct 2001
color
I used to use testors paint in a rattle can for paint pens and sharpies for decoration, but like this method better. Fast-pack.com sells colored packing tape (like Zagi tape) at a really good price, so I've been using it. I think it is actually lighter than the paint I was using. Here is the Ulty with color applied. This will be the last pic for a bit, got to go to work. Will try to add more this evening. Sorry for the quality of the pics. I had to shrink them down to fit on the board. If you want them full size let me know. My email is lcox@stx.rr.com and I will get them out to you.
Old Oct 28, 2003, 03:07 PM
Happy|Harry is offline
Find More Posts by Happy|Harry
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
Looking Sweet JP
i've attached a 23" Ultimate tiled PDF that tim did for me (thanks again ) Enjoy
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Oct 28, 2003, 03:14 PM
Tommy632 is offline
Find More Posts by Tommy632
Mayor of Simpleton
Tommy632's Avatar
Cleveland, OH, USA
Joined Oct 2002
Originally posted by Happy|Harry
Looking Sweet JP
phil
Thanks!!!
Tommy
Tommy632 is offline Find More Posts by Tommy632
Old Oct 28, 2003, 03:34 PM
Aberdeen, Scotland
Joined Jul 2003
i've just got to thinking i perhaps should have asked tim if it was ok to post these first (sorry if i messed up tim)
does anyone know of an online source for the .007x.25 CF strips?
phil
Old Oct 28, 2003, 07:04 PM
fwilly is offline
Find More Posts by fwilly
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
What does the plane weigh without any gear? Will it hover on an A drive?
fwilly is offline Find More Posts by fwilly
Old Oct 28, 2003, 07:29 PM
rc-eflyer is offline
Find More Posts by rc-eflyer
T:W>1= :>)
rc-eflyer's Avatar
St. Louis, Missouri, United States
Joined May 2002
phil
I just got some of these (second table down), now I know what to use 'em on.
rc-eflyer is offline Find More Posts by rc-eflyer
Old Oct 28, 2003, 08:58 PM
jpflyer is offline
Joined Oct 2001
Weight
I'm not sure but the flying weight is about 6 ounces. I use an A drive and 3 cell lipoly (etec 250) and can hover early in the pack.
With a twin A drive 4.8 and 2 cell TP 700s it will hover right up to lvc.
jpflyer
Old Oct 28, 2003, 09:16 PM
Tim H. is offline
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
phil
Not a prob! It's just one of those other things that I never got around to doing...
Tim
Tim H. is offline Find More Posts by Tim H.
Old Oct 29, 2003, 07:05 AM
Aberdeen, Scotland
Joined Jul 2003
phew
that's the depron on it's way, and the CF from HL
at last i'll get to build an ultimate , tim did these plans for me about 6-8 weeks ago but my original
source for depron fell through so i've never gotten to build one, but i sure will now
thanks
phil
SAAB 39 Gripen for minifan Build Thread nborin Electric Ducted Fan Jet Talk 47 Nov 15, 2007 04:23 AM
Looking for a vip build thread? jaycey High Performance 5 Nov 23, 2004 09:00 PM
3D Foam Ultimate w/ IPS Drive helipilot 3D Flying 6 Apr 28, 2004 12:25 PM
Photos of 90% Ultimate for IPS Dual Salto Foamies (Kits) 13 Feb 10, 2004 06:35 PM
Indoor homebuilt heli. for IPS Gonflyin01 Electric Heli Talk 2 May 11, 2002 08:33 AM
