Old Apr 23, 2012, 12:06 PM
Alex Koehn is offline
Find More Posts by Alex Koehn
Alex Koehn's Avatar
United States, AL, Emelle
Joined Feb 2012
What size motor?
I'm building a profile Sbach 342 out of DTF. I've been out of the small electric world for a loong time and don't know all the sizes and terms and all of the brushless motors. My plane is a 34" wingspan and I expect a 12-17oz AUW. Would a park 400 be what I need for 3d performance? Also what prop would be good?
Alex Koehn is offline Find More Posts by Alex Koehn
Old Apr 23, 2012, 12:44 PM
hankg is offline
Find More Posts by hankg
Lost but making good time
Joined Nov 2008
Alex,
I've been at this for 4 years and am not an authority on any aspect of this hobby but have begun to use WebOCalc as a tool to point me in the right direction when I'm looking for a combination of prop, motor, Esc and battery for a plane. You can use the program in two ways. You can plug in the AUW of the plane along with its wingspan and wing area and pick a prop 1/4 the wingspan and continue down an let the program pick out combinations for you. You can also plug in the airframe specs, and what ever size motor etc you think you want to use and see if they are feasible or not.
Play around with it...www.webOcalc.com
Regards,
Hankg
hankg is offline Find More Posts by hankg
Old Apr 26, 2012, 10:43 AM
Alex Koehn's Avatar
Joined Feb 2012
Ok I think I've decided to go with a 28-30-750 outrunner with a 25a esc and 3s lipo. I used Motocalc to come up with this. Approx. what size prop should I run with this for 3d performance?
Old Apr 26, 2012, 07:55 PM
hankg is offline
Joined Nov 2008
Alex,
Do you still have that Park 400 and if you do, what is the Kv? It's a good motor for that plane you are considering if it's the 920Kv...750 is to low on Kv.
You're looking for a motor between 900-1200 Kv. I ran a Park 400, 920Kv and with a 9x7.5 prop, a 3S -750mah battery and a 16-19 amp Esc you should be able to hover easily...142 watts per pound, 1.5 to 1 thrust to weight.
Regards,
Hankg
Old Apr 30, 2012, 09:12 AM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
You can get in the right ball park by matching the watts of the motor to the expected full up weight. You expect your plane to be about a pound. 1 pound x 150 watts = 150 watts. So a 200 watt motor should let you accelerate straight up. (you should not need a 400 watt motor).
Pick a prop that is matched to the motor. Pick a prop bite that will give you enough speed. Pick a battery that will run the motor, and fit on the plane. Pick a speed controller that can handle the amps of the motor.
wuest3141 is offline Find More Posts by wuest3141
Old May 01, 2012, 08:58 AM
Alex Koehn's Avatar
Joined Feb 2012
Thanks for the responses guys. I'll see what I can come up with.
Question what 3 blade prop size for .61 motor ChuckTseeker Fuel Plane Talk 14 May 24, 2012 06:09 PM
Question What size bullet motor / esc connectors? DanWard Power Systems 3 Apr 13, 2012 06:49 AM
Discussion what size brushed motors are these AzTrekie Power Systems 8 Mar 30, 2012 07:20 PM
Question What size motor foam AgCAt scratch build! RedTwilight Foamies (Scratchbuilt) 1 Oct 18, 2011 11:17 PM
Discussion What's a "400" size motor? marhar Beginner Training Area (Aircraft-Electric) 2 Oct 18, 2011 05:18 AM
