Old Apr 23, 2012, 09:04 AM
Joined Feb 2012
EDF fan balancing
Cant seem to find any info on this. Just replaced the 70mm ducted fan unit, motor and ESC in a hobby lobby thrust vectoring F16. There seems to be a little vibration at midrange on the new fan. Should I balance it? To do that do I balance the same way as on a propeller? How do you add/subtract weight without weakening the fan?
http://www.hobbyking.com/hobbyking/s...dProduct=11164
http://www.hobbyking.com/hobbyking/s...dProduct=11162
Thanks in advance,
David
Mike873 is offline Find More Posts by Mike873
Old Apr 23, 2012, 09:43 AM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Hi David
I have built a few EDF's and found any noticeable imbalance will cause the destruction of your fan/shroud eventually. Here's a link to the method I use (clock method).
Cheers Eric
http://www.rccanada.ca/rccforum/showthread.php?t=130843
4stripes is online now Find More Posts by 4stripes
Old Apr 23, 2012, 09:57 AM
Joined Feb 2012
Eric,
Thats just what I needed, thanks!!
Old Apr 23, 2012, 05:25 PM
designer,builder,flyer
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Sometimes you can simply loosen the fan bolt and turn the fan blade a fuzz on the adapter to a new position and get it into the sweet spot after a couple tries.
ApexAero is offline Find More Posts by ApexAero
Old Apr 24, 2012, 12:24 AM
Creations Aberration
Aethertek's Avatar
United States, OR, Newport
Joined Jan 2004
Don provides dynamic balancing here...
http://donsrc.com/cart/index.php
with this balancer...
http://www.bobsworkshop.co.uk/outdoo...d-fan-balancer
Kevin~
Aethertek is offline Find More Posts by Aethertek
Old Apr 24, 2012, 12:57 AM
Corelli's Avatar
Joined Jun 2008
Use a normal magnetic balancer. I use aluminum tape strips on the inside of the hub. Cut them in 1/4" strips the depth of the impeller. Once you get that close test it and see how it sounds. You may have to balance the spinner as well(if your fan has one). I use the balancer as well. But Ill use a touch of silicone on the spinner to balance it instead of the tape. Once you do both of these, check it and see how it sounds. After this if you still hear a bad harmonic you can do as Apex suggests and spin the fan on the shaft 10-20 degrees and check the sound. There are some very nice sounding fans out there that have been balanced using this method.
Corelli is offline Find More Posts by Corelli
Old Apr 24, 2012, 10:08 AM
Joined Feb 2010
http://www.rcgroups.com/forums/showt...nce+cell+phone
db_sonic is offline Find More Posts by db_sonic
Old Apr 24, 2012, 07:29 PM
Corelli's Avatar
Joined Jun 2008
Originally Posted by db_sonic View Post
Awesome thread. Wish there was a better search engine here
Sold EDF Motors and Fan units hi2nr Aircraft - Electric - Power Systems (FS/W) 3 Feb 22, 2012 12:50 PM
Mini-HowTo Mounting the Wicked EDF motor into the HET 6404 64mm EDF Fan unit The Don Don's RC 0 Jan 28, 2012 11:20 AM
Sold Cyclone 64mm EDF fan unit and Chagesun 70mm EDF fan unit The Don Aircraft - Electric - Jets (FS/W) 2 Jan 25, 2012 04:14 PM
Discussion Free Dynamic Balancer (good for turbine, EDF or prop balancing). dwalsh62 Jet Turbines 13 Nov 24, 2011 06:40 AM
Discussion Free Dynamic Balancer (good for turbine, EDF or prop balancing). dwalsh62 DIY Electronics 9 Nov 11, 2011 06:22 PM
