This thread is privately moderated by 6Sally5, who may elect to delete unwanted replies.
Old Apr 22, 2012, 06:39 PM
6Sally5 is offline
Find More Posts by 6Sally5
6Sally5's Avatar
United States, CA, Lincoln
Joined Jan 2011
Bh p-38
When the canopy's inside plaster is set, I removed the cast, then, after wetting the base, turned the mold over onto a pile of fresh mixed plaster to make a thicker base. Clean around the edges and smooth them while also trying to create an edge that will be visible as the bottom of the canopy when the original is removed.
6Sally5 is offline Find More Posts by 6Sally5
Old Apr 23, 2012, 05:20 AM
SEMPERFI8387 is offline
Find More Posts by SEMPERFI8387
Proud To Have Served 1983-1987
SEMPERFI8387's Avatar
United States, PA, York
Joined Dec 2005
What are you using to heat the plastic to make it pliable to be vacuumed down ?
SEMPERFI8387 is offline Find More Posts by SEMPERFI8387
Old Apr 24, 2012, 08:01 PM
6Sally5 is offline
6Sally5's Avatar
Joined Jan 2011
I put 4 ceramic coffee cups upside down on the rack in my kitchen oven, then set the PETG plastic sandwiched between the MDF frame on them...about 4-5 inches away from the broiler elements. In about 30 seconds, the plastic begins to sag. When it's about 1-1/12" below the bottom of the frame, it's ready to set on the mold and turn on the vac.
Semper Fi, Bro!
Wanted BH or HK NIB P-38 Kevin Greene Aircraft - Electric - Airplanes (FS/W) 1 Mar 09, 2011 05:59 PM
Discussion motors for BH p-38 bucsbw Electric Warbirds 2 May 20, 2010 01:47 PM
