Old Nov 05, 2001, 10:30 PM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
Hitec Flash 4 Problem...
I was breaking in a motor and after about 30 mins the transmitter battery ran down. Charged it up and when I turned it back on it had dumped all the settings on channel 1 and switched to Glide Mode. I cannot set it to ACRO mode as it is a flash 4.
Any ideas? Will it still fly on Glider mode?
Cant tell if the throttle works yet.
Kirby
kepople is offline Find More Posts by kepople
Old Nov 05, 2001, 10:43 PM
p471701
p471701
Guest
n/a Posts
kirbky; something funny is going on here! you can take the main battery out and not lose settings. it has a memory battery inside for that reason.the memory battery is rated for 5 years......gregg
Old Nov 06, 2001, 12:48 AM
kepople is offline
kepople's Avatar
Joined Jun 2001
Yes something funny is going on here. Only Channel 1 is stuck in the Glide mode, which it is not supposed to be doing. THat should be Channel 4&5. All other channels retained thier memory.
Kirby
Old Nov 06, 2001, 12:48 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Go to the menu that has "reset" on it and "reset". I had a problem with a screwed up memory and that fixed it.
hoppy
hoppy is offline Find More Posts by hoppy
WTB: HiTec Flash 4 or 5 tenover Aircraft - Electric - Airplanes (FS/W) 0 Jan 12, 2002 01:48 AM
Cannot sort elevon mixing with Hitec flash 4 trickyrik Foamies (Kits) 8 Dec 27, 2001 11:50 AM
Hitec Flash 4 system X Flaperons Rocken Power Systems 11 Nov 11, 2001 09:22 PM
Hitec Flash 4/5 question LuckyArmpit Electric Plane Talk 4 Oct 08, 2001 01:34 PM
Training with Hitec Flash 4/5X WAR Beginner Training Area (Aircraft-Electric) 2 Jul 27, 2001 12:02 AM
