Espritmodel.com Heli Air
Old Apr 22, 2012, 02:02 PM
Hawaii
Joined Feb 2003
Why a hole in the middle?
How come most designers of multi rotor like to put a hole in the middle of the center plate? It weakens the structure substantially. If holes are necessary to route the wires through put them on the side between the arms.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Apr 22, 2012, 02:13 PM
Schweiz, BE, Münchenbuchsee
Joined Jun 2011
weight....
Morphin is offline Find More Posts by Morphin
Old Apr 22, 2012, 02:36 PM
Old new guy
TheX's Avatar
United States, TX, Austin
Joined Sep 2004
I've never had structural issues with the hole.
TheX is offline Find More Posts by TheX
Old Apr 22, 2012, 04:12 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
I would guess it is for ease of access for wiring and configuring flight controllers
I agree it is not needed and can make the flight controller more vulnerable in a bad crash.
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 22, 2012, 05:02 PM
Hawaii
Joined Feb 2003
Originally Posted by Morphin View Post
weight....
1) Try to weigh the material of the hole in the center and see how much you save.
2) You can put a whole lot more holes on the circumference instead of one hole in the middle and you will save more weight.
Hawaii
Joined Feb 2003
That doesn't mean anything. It only means that you have not built or flown enough multi rotor to notice it.
Old Apr 22, 2012, 05:03 PM
Hawaii
Joined Feb 2003
Again you can have multiple holes on the circumference of the center plate versus one hole in the middle to route the wires.
Old Apr 22, 2012, 05:04 PM
Adidas4275's Avatar
Joined Mar 2011
Completely agreed. I was just trying to conjecture why so many frames today have one in the middle.
Looks like I failed
Old Apr 22, 2012, 05:12 PM
rimshotcopter's Avatar
Joined Aug 2009
Ideally, right in the center of the copter is where the Accelerometer should be mounted. I have no idea other then what has been previous stated.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Apr 22, 2012, 05:20 PM
BenHayat's Avatar
United States, FL, Sarasota
Joined Mar 2012
I agree with OP. With a CF plate you don't need to cut so many large holes.
a) It weakens the structure
b) some holes are so large that you can't place the electronics there.
Seems like many just duplicate others without giving it any original thoughts and design.
Here you can see the designer only drills small holes and yet the full surface is usable.
This is another great design where the center plates are fully solid:
BenHayat is offline Find More Posts by BenHayat
Old Apr 22, 2012, 05:43 PM
Hawaii
Joined Feb 2003
Looks like I failed
I cannot figure that out either. Having one hole in the middle is the worst for structural integrity. Ask any structural engineer. Instead holes around the center plate will be a lot more useful.
Just to be fair I have seen some designs with no holes in the middle.
Old Apr 22, 2012, 05:47 PM
Hawaii
Joined Feb 2003
b) some holes are so large that you can't place the electronics there.<<
Definitely.
>>Seems like many just duplicate others without giving it any original thoughts and design. <<
That is the answer I have been looking for. I think a lot of the multi rotor designs did not come from some one's original idea or research. They are just all copying each other.
>>Here you can see the designer only drills small holes and yet the full surface is usable.<<
Holes look cool. IMHO instead of holes the designer can also use thinner materials.
[IMG]http://shop.carboncore.co.uk/WebRoot/Store2/Shops/es140672/MediaGallery/CarbonCore_Octo_Mega_Spares.<<
I know Sergei has a lot of problem when he was selling his products under RC carbon. His quality control was non-existent. It seemed like he was producing while he was drunk. I have carbon fiber arms from him that has more air pockets than a sponge. OTOH he is a pretty good designer.
Old Apr 22, 2012, 05:50 PM
United Kingdom, Swansea
Joined Mar 2011
All those little bits they cut out go towards making homes for orphaned mice and little people
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Spain
Joined Jan 2010
good to know
Figure first designs were so...and as most people don´t like to copy......evolutioned (o better "creationism" in this thing...) this way till 100000 center plates broken show the good way...
Saludos and have fun,
Jose
Doblao is offline Find More Posts by Doblao
Old Apr 22, 2012, 05:53 PM
BenHayat's Avatar
Joined Mar 2012
Serious? I was really looking forward to consider them. Are you saying the CarbonCore has serious quality control with their products?
Discussion Servo holes in bagged wings robert14 Hand Launch 9 Feb 24, 2012 06:08 AM
Gallery Any interest in a detachable 48" flying wing with AP pod in the middle? Kyle G. Aerial Photography 6 Jan 10, 2012 03:57 AM
Discussion Fuselage 'vent' holes.. why? JetPlaneFlyer 3D Flying 65 Nov 24, 2011 12:59 PM
New midi fan, drilled hole in the hub, why??? birdseed Electric Ducted Fan Jet Talk 8 May 31, 2005 06:38 PM
