Old Apr 22, 2012, 06:29 AM
Snowboard_Nut is offline
Find More Posts by Snowboard_Nut
Full-Blown RC Junkie
Snowboard_Nut's Avatar
United States, MO, KCMO
Joined Jun 2011
Wiring harness for Sony 1/3 CCD Board Cams. Anyone have DigiKey or Mouser Part #'s?
I have read hints that the connector for video/pwr on the 650tvl Effio version is a Molex .125 spaced 3 pin plug. I searched Digikey and Mouser and can't find anything close. I've seen this same connector used on video card cooling fans as well. Does anyone have a part number for the 3 pin connector with bare lead wires? I assume all the Sony Board Cams use this same connector, although with different pin counts.... Any help is appreciated greatly.
Snowboard_Nut is offline Find More Posts by Snowboard_Nut
Old Apr 22, 2012, 02:16 PM
Joined Jun 2011
63 views, and not a single reply. I thought this was going to be easy, apparently not so. I guess I could solder, but the pins on the board are pretty darn small, and I would like to keep the unit unpluggable if need be. My goal is to sit the 4-way joystick control cable for the cams OSD off to the side and only use it when a cam adjustment is needed, then use a lightweight 3 pin lead from cam to vTx during flight. Surely someone with the heavy 4-way joystick control unit for the OSD has done this same thing?
Discussion SONY 1/3" CCD 480 TVL Cam for only $40 EyeFlyPlanes FPV Talk 66 Jan 23, 2015 07:27 PM
Help! 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera OSD Menu 2.8mm lens not working bighead93 FPV Equipment 18 Jan 10, 2015 10:01 PM
Discussion Ebay - 700TVL 1/3" CCD II cam for 39$ shipped - anyone tested these ? i3dm FPV Talk 2 Mar 22, 2012 03:38 AM
Sold 900MHZ 100mW Tx/Rx & 1/3-inch Sony CCD Camera NTSC daskip87 FPV Equipment (FS/W) 2 Sep 16, 2011 08:49 AM
Discussion Anyone have an old CCD or CMOS Cam?? qualcity Aerial Photography 0 Apr 03, 2006 01:06 AM
