Old Apr 21, 2012, 08:37 PM
Joined Dec 2009
Pick the best Hobby King (inexpensive) engine + prop for my Oyl II 100" electric c
Title says it all. I am about to put in a large order to Hobby King and want to know what engine from their extensive selection (I'm suffering from overchoice) is best for this plane. I'm looking for light; don't want or need "vertical". So if you are flying a converted Olympic II and are happy let me know. I did find quite a few older threads, buy HK has certainly changed/added to their lineup. Plane is 100 inch span with a wing area of about 928 sq. inches. Not sure of the all/up weight but I'm sure it's in line with other 100 inch gas bags.
lornecherry is offline Find More Posts by lornecherry
Old Apr 24, 2012, 09:28 AM
Tucson
Joined Nov 2009
You need to measure the inside diameter of the fuselage, to see what size motor will fit. A lot of sailplanes have about a 40mm inside diameter, allowing up to a 35mm diameter motor.
Then, decide how many pounds of thrust you want.
A 35-42 will give you about 595 watts or about 4 pounds of thrust (4S). How heavy is your plane?
The NTM PropDrive 35-42 is $16.00 and will put out 450 watts (3 pounds of thrust) with a 3S LiPo. Battery would have to be about 2200 mAh 30C with a 55A speed controller. A 4S LiPo will give you about 700 watts (4.6 pounds of thrust).
wuest3141 is offline Find More Posts by wuest3141
Old Apr 24, 2012, 03:58 PM
LT, SC, USN
United States, CA, Tracy
Joined Feb 2010
I chose to go with a smaller motor for my Cularis (foamie, I know, but it's also a 2.6m span). Airplane should weigh about 1500g when finished, and I chose the RCTimer 3536-8. 1000kv should put out 32 amps swinging a 12x6 folder on 3S. 62oz of static torque.
Best of all, the motor only weighs 102 grams.
Joelmusicman is offline Find More Posts by Joelmusicman
Old Apr 24, 2012, 06:00 PM
AMA 7224 LSF 1832 SAM NFFS
Leadchucker's Avatar
Joined Sep 2008
30 year old Oly II I gave to a friend which he converted with a 35-42 and is setup for ALES with a CAM switch. Nice climb but not silly.
Ray's Oly II (0 min 23 sec)
Leadchucker is offline Find More Posts by Leadchucker
Latest blog entry: 1940 Megow Models Super Quaker
Discussion Prop option for large electric Texan II webdr Giant Electric Planes 5 Mar 07, 2012 11:29 PM
Sold EXCELLENT Vintage OS 45FSR R/C Engine with muffler !!! OS's BEST 45 ENGINE EVER !!! shooboy Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 18, 2012 04:29 AM
Help! help me pick motor/prop/esc for my quad abcd123 Multirotor Talk 3 Feb 09, 2012 08:29 PM
Question What is the best BL Motor & Prop Combo for a 100 Gram Foamie? ShokWaveRider Indoor and Micro Models 3 Oct 20, 2011 01:06 PM
Discussion What's the best break in prop for my Saito 100? Flyboy1958 Engines 1 Jun 17, 2010 01:38 PM
