Old Apr 22, 2012, 10:44 AM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
onewire- cool i guess the 2200mah should do fine then. have fun flying it!
Cfisher1421- oh okay i understand now. yep i will be sure to post my first few flights!
electricrc68 is offline Find More Posts by electricrc68
Old Apr 22, 2012, 11:13 AM
mcnowhere is offline
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
I moved from the um t-28 to the dynam t-28 http://www.rcgroups.com/forums/showthread.php?t=1419147
very nice flying much larger then pz 28 and less $
retracts lites flaps
just a thought for you, but sounds like your going with pzone.
edit
click on my name for vid and pics of mine
mcnowhere is offline Find More Posts by mcnowhere
Old Apr 22, 2012, 11:16 AM
Joined May 2011
thanks for the suggestion. Yes i would much rather have the parkzone one. I just have faith in the parkzone line more than i do with the products from nitroplanes. Nothing wrong with the dynam though im sure.
Old Apr 24, 2012, 07:53 PM
Joined May 2011
Hey guys. sorry for bringing this thread back to life but im not going to be getting the T-28 anymore. I already have the micro T-28 so i want something different. I now have a new list of planes that i have an interest in below. If it helps any, i can now comfortably do rolls and loops with my micro T-28.
Parkzone F4U Corsair
Eflite Leader 480
Eflite RV9 450
Parkzone Extra 300
Parkzone Thunderbolt
Eflite Mini Pulse XT
Eflite Super Airliner (doubt that anyone would recommend this!)
and obviously they would need to be able to takeoff and land in short grass.
Old Apr 24, 2012, 09:44 PM
Joined May 2011
Well I've decided on the p47 thunderbolt.
Old Apr 24, 2012, 10:05 PM
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
From what I've read the P-47 is one of the fastest parkzone warbirds with it's Power 15 motor (the regular T-28 being at the opposite end of the spectrum, although not really a warbird) so be ready for the big jump in speed and make sure you have a big enough field to fly it. You might also want to install the flaps to help shorten landings. It's also generally considered a little more challenging to fly than the T-28 you were going to get.
Rayne is offline Find More Posts by Rayne
Old Apr 24, 2012, 11:35 PM
onewire is offline
Find More Posts by onewire
onewire's Avatar
United States, CA, San Diego
Joined Jul 2009
If you get the Corsair, you'll need to reinforce the landing gear for grass or remove the gear, put on the included skids, and hand launch...belly land. Can't speak for the P47.
Even though you'll read reviews that claim the micros fly "just like their larger counterparts", they don't. In the air they may fly similarly, and landing on a grass field where you can put it in from any direction may make it seem so. But they are faster, heavier,and take some getting used to. Also, they can do a lot more damage should they get away from you.
I was flying the micro Sukhoi XP and very comfortable with it before i got my Trojan. Almost went for a sportier, larger plane. Glad I didn't. There's someting about landing the bigger birds on a fixed direction and size landing strip that just ain't the same as the micros in a baseball field.
onewire is offline Find More Posts by onewire
Old Apr 24, 2012, 11:43 PM
onewire is offline
onewire's Avatar
Joined Jul 2009
BTW. I now have the Nitroplanes sukhoi and love it. But the larger Trojan prepared me for it. It would have been a pile of blue and yellow cottage cheese had it been available at the time and had I decided that since I was comfortable with the micro, I was ready for it.
I might add that my older reflexes may not be the same as yours and you may be perfectly capable.
Hell, I knew a guy that bowled a 300 first time out.
Old Apr 25, 2012, 12:22 AM
galdionite is offline
Find More Posts by galdionite
galdionite's Avatar
USA, AR, Fort Smith
Joined Aug 2010
this is definitly your best choice of the planes you listed, you will love it!
galdionite is offline Find More Posts by galdionite
Old Apr 25, 2012, 10:33 AM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
you wanna take off and land on grass? You need this instead. SUPER easy to fly!
this plane can be setup as 3-4-5-6 channel depending on what you want to do with it. will fly on throttle/rudder only if you have technical issue in the air. I haven't but it's good to know. You can fly it 20mph wind. I use 2800/30c batteries in it or 2200/25c. Very little trim on maiden too. it was the first plane I built of the four I have. #4 is getting built now....hope this helps.
JDMJim is offline Find More Posts by JDMJim
Old Apr 25, 2012, 12:16 PM
RickAvery is offline
Find More Posts by RickAvery
Moorpark, Ca.
Joined Apr 2004
I'll throw one at you. Try the Multiplex Twin Star. Great airplane out of the box. Here's some pics of two ways to build them. Very versitile and wonderful fliers. NOTE: they DO NOT come with landing gear. You must make your own, or as you say, you're flying off of grass and they're made to belly land. Both birds in the pics have brushless systems.The green one has Hot-Rod HiMaxx motors and is used as a glider tug. Gobs of power with the big 8" 3 blade props. The yellow one has cheapo XT400 motors, 6" props and is just a great floaty flier. 52" wing span foamys. Set em up as tricycle or tail dragger. Good luck.
Rick
RickAvery is offline Find More Posts by RickAvery
Old Apr 25, 2012, 02:47 PM
Joined May 2011
onewire- okay thanks. yeah i sort of thought that it would be different than flying a micro.
galdionite- thanks!
JDMJim- whoa those are some big wheels! handles wind nicely too according to what you said!
Rickavery- thanks for the suggestion! those dont look too bad either.
Old Apr 25, 2012, 02:53 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
The title of this thread is a little misleading....
What he is really looking for is not a large electric, but a first small to medium electric, after flying ultra micro electrics....
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Apr 25, 2012, 04:33 PM
Joined May 2011
oh i think i should change that. sorry, their pretty large for me since all i've been flying is micros!
Old Apr 25, 2012, 06:27 PM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
LOL .... it surely depends on your point of reference, HUH!
Don
dkrhardy is offline Find More Posts by dkrhardy
Discussion Mikrokopter First and Second FPV vids... first Good... second... not so good :( chargenut Aerial Photography 9 Apr 22, 2012 04:39 AM
Wanted Looking for good deal of pcm Module for Futaba 9cap jcervantes11 Aircraft - General - Radio Equipment (FS/W) 1 Apr 02, 2012 06:16 PM
Discussion need advice. prop for large scale electric warbird. Matt Gunn Power Systems 7 Mar 12, 2012 02:56 PM
Discussion Prop option for large electric Texan II Matt Gunn Giant Electric Planes 5 Mar 07, 2012 11:29 PM
Discussion Looking for a good first DLG michaelJH Hand Launch 8 Jan 24, 2012 02:35 PM
