Old Apr 21, 2012, 09:07 AM
skybolt123 is offline
Find More Posts by skybolt123
Joined Mar 2010
Idea
Solution to vicious tip stall!
Let me start by saying that I have been flying models for a long time but I don't have much technical knowledge of airodynamics.
I recently purchased the 36" Great Planes PT-19 ARF from Tower Hobbies. Contrary to the wonderful reports on this plane elsewhere on this site I found mine to be a real bear to fly and almost impossible to land. The problem being that at anything less than about 50% throttle it would rapidly and unpredictably dip a wing and go into a downward spiral which was difficult to recover from. The landing speed and stall speed were very similar so most landings ended up as a spiral into the ground. Even from straight and level flight at normal speed, a turn would have to be very gentle or the wing down spiral was instant.
Even after installing a great lump of lead to correct the CG and correcting a few degrees of upthrust built into the engine mount, the plane was still horrible to fly.
I searched this and other forums for answers but found little, and no final definitive solution. I tried the "twist the wing and heat with heat gun" ides but after not much twist there was some cracking and creaking so I decided not to take that too far. Used the heat gun to remove ripples caused while twisting but could notice no obvious washout (with incidence meter) after this exercise.
I was sceptical of removing the covering and heating the wing with steam as this 'plane appears to have been built using mostly cyanoacrylate glue, which I don't think would take kindly to this treatment. Also it seems to me that the results could be kind of unpredictable.
In my ignorance I believe I have a solution. Out of sheer frustration I decided to physically add washout to the ends of the wings. I simply used a cardboard flat folder and designed a contraption that would give a concave curve from the highest point of the wing profile back towards the trailing edge. I decided to exaggerate the extent of the "lift" at the trailing edge of the wing because washout would normally be built in along the entire length of the wing, whereas this contraption only covers the last four ribs, so I guessed that a but of extra "twist" was required.
Since this experiment has worked I will now remove the covering from the last four ribs, add balsa formers to the ribs to imitate the cardboard washout and then recover. It should then not look too bad, and should be hardly noticeable.
Hope this idea may help some who have similar problems
skybolt123 is offline Find More Posts by skybolt123
Old Apr 21, 2012, 09:14 AM
Joined Mar 2010
Solution to vicious tip stall.
I must add that the plane is now a pussycat. Easy to fly and easy to land.
When flying straight and level, if I cut the speed too much it just puts it's nose down gently. Landings are a breeze and I can even "touch and go" with confidence.
I did have to dial in a bit more movement on the ailerons as the cardboard washout devices definitely interfere with the last section of the ailerons.
A big advantage of this approach is that it is quick and easy to try, easy to modify and easy to undo completely if it did not work for you.
Generally I would regard this experiment a great success.
Old Apr 21, 2012, 09:39 AM
Evan D is offline
Find More Posts by Evan D
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Don't go to the trouble twist some washout into the current wing using a heat gun....
Evan D is offline Find More Posts by Evan D
Old Apr 21, 2012, 09:59 AM
Joined Mar 2010
Tried that...didn't help
Old Apr 21, 2012, 10:27 AM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Funny that such an "Elegant" solution helped so much! Thanks for sharing the fix. Could be the ticket for other nasty fliers, too.
Wolpertinger is offline Find More Posts by Wolpertinger
Old Apr 21, 2012, 10:28 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
What you have done there isn't creating washout at all. The wings on the PT-19 dont have any taper so should not suffer from tip stall, the fact no one else has the problem backs this up. I'm guessing that you probably have a 'wash-in' twist in one or both wings that the 'ramp contraption' is off-setting. Whatever you do though dont go and build anything remotely like that into the wing, there are much better ways to sort it out.
As Evan said, twist some proper washout into the wing. If you cant do it by heating the covering then remove the covering and steam the wing while holding in some twist.. this will do it for sure. Make sure both wings have identical twist.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Apr 21, 2012, 10:57 AM
tlr-boise is offline
Find More Posts by tlr-boise
Boise, ID
Joined Dec 2008
skybolt123: There's something else you might try. There's a P-51 model, offered by one of the Horizon Hobby companies, Hangar 9 or eflite, I believe, that has clear plastic "NACA droops," I believe they are called, that come off and on. I'm not an aerospace engineer or anything, but I believe NACA droops work to eliminate tip stalls and make stalls easy to recover from. My Apprentice wing has them. The P-51 can be flown with the droops on at first, and turns it into a trainer, essentially. Then you can take them off as you get more experienced. They stick to the leading edge of the wing, out near the tips, with double-backed tape I believe, and taking them off is easy. I believe you can buy those NACA droops separately, for $10 or so. Being clear plastic, you hardly see them in flight.
Might work for you. Just a thought, and sorry to be so vague about the specifics.
Jetplane flyer might be on to the best permanent fix, however.
Found it: http://www.hangar-9.com/PTS/PTSSystem.aspx
Oops again. At the Parts and Accessories page, says they aren't available anymore, but contact the sales and support staff. I bet Horizon has some left somewhere, so might call them up. If you haven't called Horizon customer service number before, they are usually very helpful, in my experience.
tlr-boise is offline Find More Posts by tlr-boise
Old Apr 21, 2012, 10:58 AM
rcott is offline
Find More Posts by rcott
Joined Feb 2012
Hi Guys;
Seeing the pictures, looks to me that he had an "up twist" in one of the wing halves (creating bassically a tip stall at low speed); (if I remember correctly PT-19's should be "0's" across all surfaces with just only downtrust (1 degree) and right trust (1 degree) and motor level. Jst my two cents.
rcott is offline Find More Posts by rcott
Old Apr 21, 2012, 11:01 AM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
That "fix" involves too many degrees of change. Washout would only be a very few degrees anyway.
I agree with JetPlaneFlyer, I think there was/is another issue to start with. I had a PT-19 and it was a very easy plane to fly and land.
I wonder if you were just trying to fly it too slow. Not every plane is as easy as "pull the power off and let it glide to a landing".
Good luck and let us know what you finally do.
Don
dkrhardy is offline Find More Posts by dkrhardy
Old Apr 21, 2012, 11:02 AM
Joined Mar 2010
Tip stall solution
I did mention that I have been flying for many years? Used an incidence meter at root and near the tip, identical - no twist either way, also after trying the heat gun idea, no discernable effect - incidence meter again.
As for removing the covering, twisting with steam - sounds like a lot of trouble for a possibly hit and miss solution to me.
Old Apr 21, 2012, 11:16 AM
Justwingit is offline
Find More Posts by Justwingit
We got some flyin' to do!
Justwingit's Avatar
United States, TX, Fort Bliss
Joined Apr 2012
Expert advice....
slybolt123,
Reading your story and solution to your problem makes me say "Great job!"
It's sad you have to reiterate that you've been flying for a long time...I find that lots of times people only look at the number of posts you have as an indicator of your level of competence...as if that has anything to do with it.
I'll bet your solution is based on your years of experience, which is why you thought of it in the first place, so hats off to you.
Happy flying!
Justwingit is offline Find More Posts by Justwingit
Old Apr 21, 2012, 11:21 AM
Evan D is offline
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Still say twist some washout into it... but it is your airplane. Hope it works out for you, we all need better flying planes....
Old Apr 21, 2012, 11:30 AM
Justwingit's Avatar
Joined Apr 2012
Wingtip Washout...
Lots of famous, groundbreaking aircraft designs have had this feature--the Piper J-3 Cub and the Mitsubishi A6M Zero among some of the notables. (Just a couple of little known aircraft)
I'd almost bet that the full-size PT-19 had washout (It was a Primary Trainer after all, and tip-stall was a big killer of trainee pilots) and maybe the model designers didn't feel it was necessary.
Just my .02
Happy flying!
Old Apr 21, 2012, 12:06 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
That would be pilot error. Why come in to land at near stall speed in the first place?
Clearly you were flying approaches that were too shallow and too slow.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Apr 21, 2012, 01:05 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Just my .02
Happy flying!
The first versions of the T-6.. the BC-2s were very bad fliers! There was a significant redesign to add washout among other things.
Sparky Paul is offline Find More Posts by Sparky Paul
Question Does more dihedral cause more tip stall?? Pauliwog Thermal 10 Nov 12, 2011 07:44 PM
Help! Vicious Tip Stall rbwindover Electric Plane Talk 19 Jun 14, 2008 11:58 PM
Tip Stall? BNA Bob Beginner Training Area (Aircraft-Electric) 15 Sep 06, 2007 07:07 PM
Someone please descibe exactly what a tip stall is. slowflyer Electric Plane Talk 2 Jun 05, 2001 10:29 PM
