Old Apr 21, 2012, 05:22 AM
Arxangel is offline
Find More Posts by Arxangel
Arxangel's Avatar
Bulgaria, Sofia-grad, Sofia
Joined Feb 2012
Help!
Need help with T-Motor issue on Naza!!
Hi guys, I just finished building my final frame version and when I connected everything up, I got a strange behavior from Motor 1, that is front right motor. When I do the CSC all motors start, but this one stutters and sometimes does a little rotation in the opposite direction before going in the right one. if I throttle up it starts, but next time I do the CSC it stutters again. What could be causing this?
Everything worked perfect on the prototype frame, I haven't changed anything, just moved the motors and ESC over to the new frame.
Here is a video:
Motor problem (0 min 42 sec)
Any help would be appreciated.
Arxangel is offline Find More Posts by Arxangel
Old Apr 21, 2012, 06:12 AM
rinatka7 is offline
Find More Posts by rinatka7
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
Hello Arxangel!
I have same issue(maybe one time per ten motor run) with tiger motor(MT2216).. i didnt know why it jittering..
ESC calibrated via OpenPilot GCS.
What type of ESC do you use?
I use HobbyKing F-30A with SimonK firmware.
So, if you find solution..could you please let me know!
rinatka7 is offline Find More Posts by rinatka7
Old Apr 21, 2012, 07:15 AM
Arxangel is offline
Arxangel's Avatar
Joined Feb 2012
Originally Posted by rinatka7 View Post
Hello Arxangel!
I use HobbyKing BlueSeries 30A stock firmware, it didn't do it before, I will try to re-calibrate all ESCs. Do you have any problems once it starts up and you go flying?
Old Apr 21, 2012, 07:23 AM
rinatka7 is offline
rinatka7's Avatar
Russia, МО, Podolsk
Joined Dec 2010
it didn't do it before (same thing)!
No, i didnt see any problem while flying!
Its start jittering only when throttle in zero point..while throttle more than 0..its turns normal.
Old Apr 21, 2012, 08:02 AM
Arxangel is offline
Arxangel's Avatar
Joined Feb 2012
Good to know since I will maiden it either later today or tomorrow and need to be sure the motor won't stop mid air.
Discussion Need help setting up ER9-X with Naza tgreening Multirotor Talk 34 May 15, 2012 10:58 AM
Help! Noob with Witespy issues after just 2 flights, NEED HELP fullpotential Multirotor Talk 2 Mar 29, 2012 11:49 AM
Help! DJI Naza wind issue!!!! (help needed with throttle up issue in wind) Arxangel Multirotor Talk 11 Mar 07, 2012 01:47 AM
Help! Pls..Need help fixing Contrast issue on Fatshark googles GOURBI Multirotor Talk 1 Nov 18, 2011 12:37 PM
Discussion I want to know how and need some help on upgrading motor in PZ T-28 skarface Parkflyers 5 Nov 07, 2011 07:28 AM
