Old Apr 21, 2012, 01:31 AM
jasper7821 is offline
Find More Posts by jasper7821
United States, AZ, Tucson
Joined Mar 2008
AWESOME landing gear for DJI F550, easy build and totally sturdy, all parts fit great
Just wanted to say thanks so much for Rob in the UK for creating an awesome set of landing gear for the DJI F550.
It just came in the mail and only took about an hour to build, I only got the gear and a fixed mounting plate for my Sony Nex5n so I can't comment about the gimbal.
I did have another set or gear who many here have used and it took a day to build and I had to drill all the holes out so the bolts would fit. And when all put together it was a bit flimsy and the gimbal was pretty twitchy on the pitch. And the instructions were horrible.
I am very impressed with this Aeroxcraft landing gear, it's very sturdy and came with a 18 page assembly manual with detailed close up photos so I had no question at all about where parts went.
When I have more money I will add a gimbal.
Tomorrow I'll attach it to my F550 and get some photos from the Sony for the first time.
This link has someones uploaded photos of this landing gear and the GoPro gimbal and they are perfect shots. The photos are at about the middle of the page.
http://www.multirotorforums.com/show...-Gimbal./page2
Here's the link to Aeroxcraft if anyone is interested
http://www.aeroxcraft.com/index.php?...72c00ec6cc9431
jasper7821 is offline Find More Posts by jasper7821
Old Apr 21, 2012, 07:07 AM
rsun77 is offline
Find More Posts by rsun77
Danmark, Sjælland, Gørlev
Joined Jul 2008
That is my F550 you linked to...
I am mostly using it for stills, but will try out some more video later on, but not what I got it for...
Waiting for some new batteries to play with and do some more testing on the video side...
I like your setup too... just need to get a tilt on the nex for a bit of stabilizing...
rsun77 is offline Find More Posts by rsun77
Old Apr 21, 2012, 10:37 AM
blade strike is online now
Find More Posts by blade strike
Free Bird
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
looking good, Cant wait to get mine. I got the gimbal also so I will post some pics on that!
Thanks for posting about he quality and how you like it.
blade strike is online now Find More Posts by blade strike
Latest blog entry: It's time....
Old Apr 21, 2012, 10:53 AM
gilandar is offline
Find More Posts by gilandar
Germany, NRW, Cologne
Joined Apr 2012
Hello,
i can`t believe it...recieved my landing gear from Aeroxcraft a few days ago, and was getting headache, how i can rig my Sony Nex without a Gimbal on it. Did you get this plate from the homepage order, or was it some private thing...?
looks nice, but what about Vibrations?
gilandar is offline Find More Posts by gilandar
Old Apr 21, 2012, 11:34 AM
Joined Mar 2008
i just added another photo of the adapter plate Aeroxcraft made the universal mount for me so I can mount the Sony Nex5n in a fixed position.
Since you don't have one you could just use what it came with and buy a piece of plastic, lexan, or whatever and bolt the solid piece to the gimbal mount and drill a hole in it for the 6mm tripod mount bolt.
Old Apr 21, 2012, 11:40 AM
Joined Mar 2008
The only thing I may add to the landing gear is maybe 4 pieces of a pool noodle or foam to attach to the legs for some cushion on landings.
This gear is very rigid and stiff, there's no flexing at all. Very Very impressed with it.
I'm mounting it today and hopefully will get steady photos and video (gimbal is next on the shopping list.)
I also bought a piece of 4"x4" 1/4 thick square sorbothane to mount between the gear and bottom plate if there's any vibrations.
Old Apr 21, 2012, 05:56 PM
Joined Mar 2008
I finished installing my Aeroxcraft landing gear and bracket for my Sony Nex5n.
I still need to clean up some wires.
I installed my Dragon+v2 OSD, and the Gentled for remote shutter and video for the Sony.
My weight now is a whopping 5lb 11oz (2555 grams) with one battery and the camera.
With 2 batteries it's 6lb 10oz (3016 grams)
I haven't tried to hover yet, I'm going to make a foam casing for my brand new camera.
Old Apr 21, 2012, 07:20 PM
Joined Mar 2008
Here's the very first video with the Sony Nex5n attached to my DJI F550.
It's unedited except the Sony doesn't have a function to flip the video 180 degrees so I flipped it in Youtube.
Zero vibration, I didn't even use the sorbothane. it was a little windy as you can see from the flagpole.
This Aeroxcraft landing gear is AWESOME.
The video doesn't look that great, I used the Sony Youtube upload program and it only uploads in 640x480
http://youtu.be/LKUhIMAHHos
Old Apr 22, 2012, 09:20 AM
txflyboys2 is offline
Find More Posts by txflyboys2
txflyboys2's Avatar
USA, TX, Lancaster
Joined Nov 2004
Solid Vid there, Jasper! It is selling me on this gear. Did you spend a lot of time with the other vibration issues of pre-balancing the props and motors? Thanks for sharing! (nice place, BTW!)
Larry
txflyboys2 is offline Find More Posts by txflyboys2
Old Apr 22, 2012, 09:55 AM
Joined Mar 2008
I tried to balance the motors but I started doing one and gave up because I couldn't tell any difference.
I have 10" graupners and I also gave up on balancing them. I got them balanced vertically but I couldn't get the hub balanced perfectly.
So the answer no, my rig it not perfectly balanced but its good enough for me.
This landing gear is great, very sturdy and professionally designed. The two main frames are held together with about 20 zip ties, very creative how Aeroxcraft designed it.
And the 18 page instruction manual with detailed pictures is awesome. A little kid would be able to build it.
Obviously there was a great deal of time put into designing it.
I ordered it just from looking at the pictures and it looked cool and seemed sturdy.
Old Apr 22, 2012, 10:05 AM
Joined Mar 2008
Thanks, I saw the pictures of your F550 and loved the way it looked, so I thought I'd give it a try. So thank you very much.
Old Apr 22, 2012, 03:36 PM
Joined Mar 2008
Another quick video with the Sony Nex5n in better resolution.
this Aeroxcraft landing gear is very stable and pretty much vibration free.
Sony nex5n Hexacopter UofA (1 min 10 sec)
Old Apr 22, 2012, 08:40 PM
Price4Flight is offline
Find More Posts by Price4Flight
Price4Flight's Avatar
United States, TX, Austin
Joined Jan 2012
Nice!
Price4Flight is offline Find More Posts by Price4Flight
Old Apr 22, 2012, 09:19 PM
BenHayat is offline
Find More Posts by BenHayat
Always Excel >>>
BenHayat's Avatar
United States
Joined Mar 2012
I love that Sony Camera!
BenHayat is offline Find More Posts by BenHayat
Old Apr 23, 2012, 12:12 PM
Joined Mar 2008
Ya, I really light the video and photo quality and how light it is.
Discussion DJI F550 Hex Build, with 2-axis NEX-5N/GH2 Gimbal... GGoodrum Multirotor Talk 9560 May 28, 2014 12:06 AM
Discussion My DJI F550 landing gear SocalAstro Multirotor Talk 14 Apr 09, 2014 06:05 PM
Discussion Looking for landing gear for Flame Wheel F550, these are kinda like what I'm looking jasper7821 Multirotor Talk 1 Oct 23, 2012 10:30 AM
Discussion My DJI F550 with the X468 FlameGear XT landing gear and camera gimbal jasper7821 Multirotor Talk 3 May 30, 2012 11:36 AM
Wanted Looking for landing gear for Flame Wheel F550, these are kinda like what I'm looking jasper7821 Aircraft - Electric - Multirotor (FS/W) 1 Mar 06, 2012 06:28 PM
